| Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more. Sponsored By:
#1 | ||||
Front Strut Brace Question
Alright.. I'm looking to buy the fs front strut tower brace.. if I use only a front one, will this cause the rear to kick out more?
Remove Advertisements |
Fan#: 1
#2 | ||||
SVT Fanatic
No. if you want oversteer, look into bigger rear sway bars. a front strut bar will not make the focus squirly at all. the front end will respong a bit better though. and the bar will also prevent the front from sagging on itself.
/ \ = no sway bar | | = sway bar
#2356 #610 |
#4 | ||||
GreyRice WOoT!
it may, it would keep the back struts straigt when you hit a turn, the rear sway helps more then the front does, i suggest getting both if you can afford it, also i still have mine for sale front strut, pm me about it.
and most likely you dont have a rear sway bar which is good or bad so i dont think youll have much oversteer, i only got over steer twice so
Focus Nation
Focus Revolution Chrenron 1 of 3 Velveeta Lover Shell#1 LOTH 00! |
#5 | ||||
Sückn' n Blown
Personally, it only works well in as acting as a brace to lean on while working on the engine. That, and adding weight in the front.
#6 | ||||
We seem to be talking about 2 different things at the same time.....strut braces are one thing, sway bars another. BOTH serve a purpose. The stiffer you make your chassis, the more it will respond to things like sway bar 'tuning'[adding or changing the size of the SWAY bars.]
Also, strut tower braces, both front AND rear serve to keep the car quieter over a protracted periods of time.........especially if you drive over crappy roads, like here in S.E. Michigan. SWAY BARS, keep the car 'flatter' thru a turn, and by careful selection can give you a car that you can drive from understeer thru oversteer using only the throttle .....now THAT'S fun ! |
#9 | ||||
Yep, a rear sway bar that is bigger in diameter than the front will push you in that direction..........I'm running the Eibach set, and I can go from understeer to oversteer controlling the car with only the throttle through the curve........FUN ! [Of course, it helps a BUNCH to have some smooth road under you ].
#10 | ||||
Just rememeber, while a bigger rear sway will induce a more neutral or increased oversteer, in bad weather (snow, rain) or on dirt or freshly oiled road, that oversteer tendency will be even more exaggerated. It will become a handful and snap oversteer is a possibility in those situations. Go for neutral handling and be vigilant in the situations I mentioned. Its best that you really know how to drive before you go to oversteer extremes.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| For Sale:FC 4-2-1 Header/FC front strut bar(red)/FS Rear strut bar(red) | BV40floz | Archive | 17 | 02-11-2007 12:59 PM |
| strut tower brace | roob | General Technical Chat | 9 | 03-03-2006 06:08 PM |
| strut tower brace | Morpheus | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 2 | 06-06-2005 12:52 AM |
| Front and Rear strut bars.. $80 shipped! *SOLD* | Rych | Archive | 21 | 05-08-2005 12:42 AM |
| Strut Tower Brace | blackandgold | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 5 | 10-19-2003 09:11 PM |
