Fog light mod Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-13-2006, 05:01 PM   #1
wordyahurdd
coooookie monster
wordyahurdd's Avatar
Fan#: 41401
What I Drive: 13'ST, 04'SVT, 03'XB9s
Points 14,606, Level 78
Points: 14,606, Level: 78 Points: 14,606, Level: 78 Points: 14,606, Level: 78
Level Up 39% Completed
Forum Activity 9%
FF Reputation: 7 wordyahurdd Good Standing Member
Buy-Sell-Trade Rating: (16)
I did the fog light modification http://www.focusfanatics.com/howtos/foglight/ and i was wondering if this has had any effect on the life of your fog lights or just any electrical problems along with the spade crimp termials in your fuse box
wordyahurdd is online now
Old 12-13-2006, 05:12 PM   #2
R3d_RovrZX3
Official FF Sanjaya
R3d_RovrZX3's Avatar
Fan#: 39824
What I Drive: 2001 Infra-Red ZX3
FF Reputation: 26 R3d_RovrZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
all the mod does is prevent the car from checking whether or not the headlights are on when u try to switch on the fog lights...
before:
"car, please turn on the fog lights"
"headlights are you on?" "no"
"sorry, no can do...turn on the headlights if you want fogs"
after:
"Car, please turn on the fog lights"
"ok, if you insist"
doesnt change their life at all...except you will probably use them more frequently now, so they may go dead from more use...
and as long as you got the spade crimp terminals on well enough and have them inserted sturdily enough...should be good to go...a lot of people have done this mod and i havent heard any complaints...anything goes wrong, just put the relay back in
Focus on a budget!
R3d_RovrZX3 is offline
Old 12-13-2006, 05:21 PM   #3
SpecialEd
Guest
Fan#:
Posts: n/a
haha good example
Old 12-14-2006, 03:06 PM   #4
wordyahurdd
coooookie monster
Fan#: 41401
Forum Activity 9%
thanks, i just wanted to make sure
Old 12-14-2006, 05:13 PM   #5
CowboyCasper
CowboyCasper's Avatar
Fan#: 38717
What I Drive: 2001 White ZX3
FF Reputation: 1 CowboyCasper Good Standing Member
Erm, correct me if i'm wrong here, but due to the design of the headlamp switch, you can't turn on the fogs without the headlights, hack or no hack.
What the 'fog light mod' does is allows you to run your fogs while the highbeams are on. Normally, when you flip on the highbeams, it cuts out the fogs.
White 2001 ZX3
17" FRPP White Rally Wheels, KW Cup Kit (1.6"), Progress 22mm Rear Sway, Short Ram Intake w/K&N Cone, Steeda 65mm TB, Ported 2k Manifold, FRPP 9mm Wires, MAC UDP, Clear Markers, OBX 4-1 Shorty Header, OBX ORP, FS Flex, 2nd Gen. MBRP Exhaust, FS/SCT Multi Chip
CowboyCasper is offline
Old 12-14-2006, 05:22 PM   #6
BlazingCopper_ZX3
BlazingCopper_ZX3's Avatar
Fan#: 23208
What I Drive: 2005 Blazing Copper ZX3
FF Reputation: 1 BlazingCopper_ZX3 Good Standing Member
Your Wrong.
At least here in the US.
A realy in the fuse box prevents the fog lights from being turned on when just the running lights are on. The mod alows you to turn on the fogs before you turn on the headlights.
Color Matched Grill, Mid-Wing Spoiler, Clear Side Lights, Audiophile Sound System, Stealth CAI, SVT Suspension and EAP wheels, FRPP Strut Tower Brace and STS.
BlazingCopper_ZX3 is offline
Old 12-14-2006, 05:24 PM   #7
focusin
FF Cleaning Squad
focusin's Avatar
Fan#: 4322
What I Drive: All Focus' sold
FF Reputation: 63 focusin Excellent Standing Member
Buy-Sell-Trade Rating: (17)
The fog light mod does what the others above are saying, it will allow them to be on with out any headlights. The switch will pull out without the headlights being on they just will not come on that way unless thge mod is done.
Retired Moderator
GumpCrew #1 (dismantled)
focusin is offline
Old 12-15-2006, 09:41 AM   #8
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Actually, it does both. The only time foglights can be on are when the low beams are on. With the foglight mod, they can be on with running, lows, and highs.
Egz is offline
Old 12-17-2006, 04:30 AM   #9
NorCaLarry
NorCaLarry's Avatar
Fan#: 22999
What I Drive: 2005 Liquid Grey ZX3 SE
FF Reputation: 1 NorCaLarry Good Standing Member
Reading this forum it seems some think the fogs will work with the HIGH beams after the mod. My 2005 came with functioning fogs in LOW beam, not HIGH beam. I have done no fog mod. The fogs have always worked with just the parking lights on.
Does the fog mod actually enable fog lite with HIGH beams? Thanks.
Ford Sport Group Option
Ford Convenience Group Option
ATX - Moonroof
Duratec 20 PZEV
NorCaLarry is offline
Old 12-17-2006, 05:08 AM   #10
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Yes...basically, the fog lights work as long as the switch can be pulled out to activate them. The stock setup uses a relay that checks for the low beams to be turned on...if they are, it completes the circuit and turns the foglights on. Doing the "mod" deletes the relay and completes the circuit with the wire, putting them in an "always-on" mode.
Really, I could never understand why Ford did it like this (I guess they did away with it in the 2006/2007 models) when it can be bypassed with elementary wiring skills and a two-inch piece of wire. AFAIK, there aren't any laws on the books that you cannot turn your fog lights on without the low beams also being on, and that they must switch off with the highbeams. Prehaps its a design retention from the original European design that simply never got worked out of the system until now...
SkaAddict is offline
Similar Threads
Fog light question 2005 FranticFocus05 General Technical Chat 2 10-10-2005 07:28 PM
Question about fog light mod. focuszx3r General Technical Chat 8 08-10-2004 12:15 PM
Fog light Mod??? DilSVT MK1 Focus 3 02-26-2004 12:38 PM
Fog Light Mod Question??? chuka Ford Focus & General Car Chat 3 12-02-2003 11:29 AM
Fog light Mod question?!?!?! fast5 Ford Focus & General Car Chat 8 10-21-2003 11:32 PM
