atx transmission fluid - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-03-2006, 12:56 AM   #1
xbox4414
xbox4414's Avatar
Fan#: 10921
What I Drive: 2007 Sunlight Silver MazdaSpeed3
FF Reputation: 1 xbox4414 Good Standing Member
I've never changed the fluid of my transmission by my self. I just started doing my own oil. So I was wondering what type of transmission fluid should I use and how often do I change it? Also were exactly is the drain and place to put the new fluid in? thanks.
xbox4414 is offline
Old 12-03-2006, 10:28 PM   #2
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
You change it every 30,000. You drain it by dropping the transmission pan, and there will be a filter in there to change also. You buy the filter kit (it's a kit because it comes with a pan gasket and there might be an O ring involved also, I don't remember. Anyway, when you're done, you spill in about 4 (not sure of exact quantity) quarts of Mercon V (as in "5") transmission fluid thru the dipstick tube. Don't overfill it, whatever you do... Most autoparts stores can tell you the amount and type of fluid your car needs.
When you're all done you will have changed about 1/2 of the fluid in the transmission. The rest was hiding in the torque converter and valve body. You will hear much talk about "flushing", which is a procedure that changes all of it. In my opinion, if the trans works OK and is sound, flushing is a total waste of money. If the trans is soft, flushing is still a total waste of money- and can actually hasten the demise of a marginal unit.
I think you're best bet is to stick to the simple 30,000 fluid/filter change, but then make sure that you actually DO it every 30K, because it IS important to the trans.
Often wrong but never in doubt.
Blurvfocus is offline
Old 12-03-2006, 10:32 PM   #3
Bubba Bob
Bubba Bob's Avatar
Fan#: 21448
What I Drive: 05' ZX4 SE.
FF Reputation: 1 Bubba Bob Good Standing Member
You can remove the rest of the fluid by disconnecting a cooler line and running the car.
Also, when I dropped my pan I added 4 qts (as advised on this forum) and the reading was "off the dipstick". In other words, 4 qts was way too much. 2-3 qts would have done it. So, put in two qts, check, and fill as nessecary.
How is this? The trans. is not put under any more pressure than when your car is running.
2005 Ford Focus ZX4 SE, ATX
Bubba Bob is offline
Old 12-03-2006, 10:38 PM   #4
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
What I Drive: '03 CD Silver SVT, '11 Mazda CX-9
FF Reputation: 112 Peregrine Excellent Standing Member Peregrine Excellent Standing Member
Buy-Sell-Trade Rating: (23)
Are you talking about topping off the fluid thru the dipstick tube??? That seems a little absurd to me..
Peregrine is offline
Old 12-03-2006, 10:56 PM   #5
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
Also, when I dropped my pan I added 4 qts (as advised on this forum) and the reading was "off the dipstick". In other words, 4 qts was way too much. 2-3 qts would have done it. So, put in two qts, check, and fill as nessecary..
Yeah, come to think of it, 2-3 qts is right. That's why I have 3 qts still sitting on my shelf here.
The presence of new fluid is the problem. If the transmission is old and the fluid shot, deposits will have built up on everything. Now you add all that new fluid, and the detergents go to work and break all that crap loose, which clogs the filter and also gets between the clutches' friction surfaces and presto- slipping transmission. A friend of mine used to run a Cottman Transmission shop and he told me they would never do that to an old unit- they didn't want the headaches that will surely follow.
Old 12-03-2006, 10:59 PM   #6
Bubba Bob
Bubba Bob's Avatar
Fan#: 21448
durn double post.
Old 12-03-2006, 11:00 PM   #7
Bubba Bob
Bubba Bob's Avatar
Fan#: 21448
In that case dropping the pan and adding fluid will be harmfull also. Just maybe only half as harmfull
Is there another way?
Old 12-03-2006, 11:06 PM   #8
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
Not at all. That's how automatics are. But I'm told some of them don't even have dipsticks anymore. For pete's sake now what.
Old 12-04-2006, 12:03 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
That's the easiest way to drain the transmission before changing the filter. Be sure to disconnect the upper line at the radiator which should be the supply line. The lower line is the drain back to the trans. Have a large, deep container down there, mucho fluid will come out quickly. You will also be draining the torque converter when you start the engine to do it this way. I just can't remember how to disconnect that fitting. I think you slide the collar up, and then pull back or something.
Change the filter, your transmission will last longer with routine maintenance.
I am not worthy of talking because I have not changed my fuel filter and I have 36k miles.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 12-04-2006, 08:06 AM   #10
Bubba Bob
Bubba Bob's Avatar
Fan#: 21448
whynotthinkwhynot, is it safe to drain all the fluid out through the cooler line the the car running?
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
Transmission Fluid focus4dr General Technical Chat 9 12-16-2005 05:39 PM
Transmission Fluid ZX5 Manual 5 speed Transmission walkerjw99 ZETEC Performance (2000-2004) 2 09-07-2005 08:45 PM
Mobil 1 synthetic ATX fluid? 2000FordFocus General Technical Chat 7 11-09-2004 08:35 AM
