What's the yellow bottle cap light with the exclamation point - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-02-2006, 05:57 PM   #21
knightriderzx3
knightriderzx3's Avatar
Fan#: 274
What I Drive: 2008 Black SRT4
FF Reputation: 2 knightriderzx3 Good Standing Member
Buy-Sell-Trade Rating: (4)
^+1
Amen.
ractive short ram ai, 65mm throttle body, 9mm ford racing spark cables, pacesetter header, Focus Central UDP
knightriderzx3 is offline
Old 12-02-2006, 07:45 PM   #22
nickouellettesvt
nickouellettesvt's Avatar
Fan#: 33575
What I Drive: 2002 focus svt
FF Reputation: 2 nickouellettesvt Good Standing Member
I had this happen also would come one while driving, but I would just shut the car off and restart it and it would clear. I found out later that it was caused by the battery, cause I replaced it a few days later and have not had it come back yet.
My formally owned SVT was repoed
nickouellettesvt is offline
Old 12-02-2006, 08:02 PM   #23
knightriderzx3
Fan#: 274
that's two votes for the battery so far. Maybe we should start a poll. Maybe involve a little gambling and see what the outcome is.
Old 12-02-2006, 09:24 PM   #24
Aqua12632
Aqua12632's Avatar
Fan#: 41244
What I Drive: 2002 Blue Focus SVT
FF Reputation: 1 Aqua12632 Good Standing Member
Originally Posted by mmmoose View Post
Manual says...
Multi-function: Automatic
transaxle/cooling system (On
SPI, Zetec E or automatic
transaxle vehicles only):
Momentarily illuminates when the
ignition is turned to the ON position and the engine is off. If the light
illuminates while driving, have your vehicle serviced.
(from the 2002 Model Focus Owner's guide)
Originally Posted by QQQQ View Post
My SVT is a manual shift.So is the SE.WTF?
note that it says
Zetec or automatic
- i think this should apply to you if you have a zetec manual transmission
Aqua12632 is offline
Old 12-02-2006, 09:25 PM   #25
Aqua12632
Aqua12632's Avatar
Fan#: 41244
Originally Posted by knightriderzx3 View Post
When I had that light come on, I had major corrosion on my battery and also a weak ground cable. After I fixed that, I never heard from the mystery light again. And everyone lived happily ever after.
Well, i stand corrected. I recently went through a lot of problems with power in my SVT including a low charge on the battery, but if this is a battery voltage problem or a connection problem, i havent seen it before.
you are correct though QQQQ, your battery light will turn on when the alt. is not charging the battery, but i believe it could indicate other problems as well.
in my opinion, it sucks that the owner's manual doesnt specify what the problem is. it only says "have your vehicle serviced". by the name of it, since you do not have an automatic trans, it would seem that it would be the cooling system.
(from http://www.myfordfocus.com/underthehood.htm)
Engine Cooling System
If your Focus has the 2.0L Zetec engine, your have what is referred to as "fail-safe cooling". This is a handy system, should for some reason your engine's coolant supply become depleted, the fail-safe cooling allows the vehicle to be driven temporarily before any incremental component damage occurs. The fail-safe traveling distance depends on ambient temperatures, vehicle load, and terrain.
If your engine begins to overheat, the coolant temperature gauge will move into the red area, and the multi-function automatic transaxle/cooling system light on your instrument panel will be illuminated. When the engine reaches a preset over-temperature condition, the fail-safe cooling system will activate. The engine will switch to alternating cylinder operation, each disabled cylinder acts as an air pump, thereby cooling the engine.
When this happens, your vehicle will still operate, however... the engine power will be limited, since you are not running on all four cylinders, the air conditioning system will be disabled, and your check engine light on the instrument panel will illuminate. Continued operation will increase the engine temperature and eventually the engine will shut off, and you will loose your power steering and bracking. If at all possible, you should pull off the road and let the engine cool. If you car does shut off, and once your engine cools down, you should be able to start the car again. You should however get your car to a service facility as soon as possible.
Old 12-02-2006, 10:45 PM   #26
QQQQ
Fan#: 38163
Points 2,104, Level 27
Points: 2,104, Level: 27 Points: 2,104, Level: 27 Points: 2,104, Level: 27
Level Up 70% Completed
FF Reputation: 3 QQQQ Good Standing Member
THAT ^ scenario def did not happen.The car was just started and was NO WAY overheating AND the light went out after 3 minutes.I drove away after that and had plenty of power.I still think it had something to do with battery voltage being too low.
QQQQ is offline
Old 12-03-2006, 01:54 AM   #27
02blksvt
02blksvt's Avatar
Fan#: 37546
What I Drive: 2002 Pitch Black SVT Focus ZX3
FF Reputation: 1 02blksvt Good Standing Member
that light is your air bag light
02blksvt is offline
Old 12-03-2006, 07:33 AM   #28
QQQQ
Fan#: 38163
??? the air bag lite is much different looking and you can actually figure that one out without a manual...this is the one below the air bag lite.
QQQQ is offline
Old 12-03-2006, 12:37 PM   #29
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
Well with all the information at hand so far, I'm willing to guess that the problem is with the fail-safe itself. I don't know what components make up the fail-safe (just a temp sensor and the ECU? maybe more?), but this is the best place to start. Perhaps the bad battery causes a voltage issue with the sensor?
Normally I'd think that this kind of system would run off the alternator when the car is running, but perhaps it is wired to the battery because of its fail-safe operation?
Just some educated guesses... hopefully we can make more of the situation from here.
CaysE is offline
Old 12-06-2006, 12:58 AM   #30
Primaris
Primaris's Avatar
Fan#: 35639
FF Reputation: 1 Primaris Good Standing Member
This light is not applicable to the SVTF.
[size=4][color=orange][b]2003 Focus SVT Euro Package[/b][/color][/size]
[size=1][color=blue]I.C.E: [/color]
[i]Valentine 1
My Lead Foot[/i][/size]
[url=http://www.scca.com/Inside/Index.asp?IdS=0014AA-AB5D000&Reference=RegionalSites&~=]Get autocrossing with the [color=red]SCCA[/color][/url]
[size=1][url=http://autocross.mellow-one.com]My Autocross Page[/url][/size]
Primaris is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
