What's the yellow bottle cap light with the exclamation point - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-02-2006, 05:54 AM   #11
QQQQ
Fan#: 38163
Points 2,033, Level 27
Points: 2,033, Level: 27 Points: 2,033, Level: 27 Points: 2,033, Level: 27
Level Up 22% Completed
FF Reputation: 3 QQQQ Good Standing Member
No,I was not driving the car.I had just started it and it stayed on for about 3 minutes.Coolant level is fine and heat guage normal.I scanned the car and found no diagnostic trouble codes.Only came on that one time.
QQQQ is offline
Old 12-02-2006, 07:39 AM   #12
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,271, Level 100
Points: 51,271, Level: 100 Points: 51,271, Level: 100 Points: 51,271, Level: 100
Level Up 0% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Buy-Sell-Trade Rating: (28)
The " ! " is a MAJOR warning light that something is not operating in the safe zone , something the ECU has no control over , a lot of times this is when the ECU goes into fail safe mode
Water temp to high
Oil temp to high
Low Oil Psi
Charging system
This will NOT show up as a ECL code and once the issue goes away (engine cools down) this light will go off by it self
For that light to come on it had to be something major
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 12-02-2006, 09:13 AM   #13
QQQQ
Fan#: 38163
Hmmm...Oil pressure is good.Oil temp is good.Water temp is normal.My battery was a bit run down from sitting...could that have caused it?I know we don't have an amp guage or voltmeter,but mabye that yellow light is how it warns of a low voltage condition?
QQQQ is offline
Old 12-02-2006, 10:12 AM   #14
Toolman
Toolman's Avatar
Fan#: 27202
What I Drive: 2005 Ford Focus ZX3,Egg Yolk Yellow
FF Reputation: 1 Toolman Good Standing Member
what are you driving??
Your profile doesn't even say what year vehicle you have. "anything I can get my hands on" is cute, but uninformative. Go here to get your Owners Manual in pdf format:
https://www.fleet.ford.com/maintenan...ls/default.asp
Team Duratec #20, ATX Faction #11
Enkei wheels,HPS Intake, Ported TB, Tein S Tech springs,SVT shocks,Billet Grills,Debadged,Custom Exhaust,Black Headlights,tinted tails & markers,12" Polk GNX124 Sub, Polk db571 front speakers, Panasonic HU.
Toolman is offline
Old 12-02-2006, 01:36 PM   #15
QQQQ
Fan#: 38163
I am posting on SVT performance chat and I called my car a Piranha so...anyway,thanks for the link toolman.It really does not specify in the owners manual about the probable cause if the car is a manual transmission.I am guessing the battery voltage was below specs (from sitting)and triggered the ECM into an alarm state,causing the yellow pop cap light to illuminate.Has not done it since so I guess I'm OK...
QQQQ is offline
Old 12-02-2006, 03:28 PM   #16
Aqua12632
Aqua12632's Avatar
Fan#: 41244
What I Drive: 2002 Blue Focus SVT
FF Reputation: 1 Aqua12632 Good Standing Member
Cool
i would venture to say that the low battery would not cause that light to come on. thats why you have a battery light... possibly a sensor malfunctioning if everything is fine -?-
Aqua12632 is offline
Old 12-02-2006, 03:36 PM   #17
QQQQ
Fan#: 38163
Well,the battery light only shows when the alt. is not charging.It may not be able to see a static low voltage condition.When this all happened,the car just turned over enough to start.The light stayed lit for about 3 minutes;possibly enough for the voltage to read OK again?I really don't know.What I don't understand is why Ford (or any manufacturer for that matter) would put a warning light on the dash that makes no sense unless you have read the manual or have access to one.After all I'm as much of an idiot as the next guy and I couldn't figure it out....
QQQQ is offline
Old 12-02-2006, 04:46 PM   #18
qbert442
FoFo Quebec!
qbert442's Avatar
Fan#: 21591
What I Drive: 2002 Liquid Grey ZX3 MTX
FF Reputation: 7 qbert442 Good Standing Member
Buy-Sell-Trade Rating: (8)
That's why onwer's manuals exist
Jeff
The Beatles were singing "All you need is Love". Partying with friends is Fun. You'll find both in a Focus : Love & Fun!
qbert442 is offline
Old 12-02-2006, 04:51 PM   #19
knightriderzx3
knightriderzx3's Avatar
Fan#: 274
What I Drive: 2008 Black SRT4
FF Reputation: 2 knightriderzx3 Good Standing Member
Buy-Sell-Trade Rating: (4)
When I had that light come on, I had major corrosion on my battery and also a weak ground cable. After I fixed that, I never heard from the mystery light again. And everyone lived happily ever after.
ractive short ram ai, 65mm throttle body, 9mm ford racing spark cables, pacesetter header, Focus Central UDP
knightriderzx3 is offline
Old 12-02-2006, 05:56 PM   #20
mmmoose
Bunneh Fanatic
mmmoose's Avatar
Fan#: 39963
What I Drive: 2008 United Gray VW Rabbit
FF Reputation: 9 mmmoose Good Standing Member
When in doubt, take it in to have it checked out. I don't mean to insult you, and I know that's probably not what you want to hear, but unfortunately that warning light can mean quite a number of things. They might as well just nickname it the "miscellaneous, yet very important" light. But that just sounds stupid.
Of course you could always go with your gut instinct and try to fix what you think is wrong. But if the problem persists I'd highly recommend spending the time and money in having it checked out by a dealership or local mechanic. You don't want bigger headaches in the long run.
-Moose
mmmoose is offline
