SVT Performance Upgrades *opinionated* - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-30-2006, 09:30 PM   #1
blkthunder
Fan#: 34375
What I Drive: 06 G35
Points 3,559, Level 37
Points: 3,559, Level: 37 Points: 3,559, Level: 37 Points: 3,559, Level: 37
Level Up 40% Completed
FF Reputation: 5 blkthunder Good Standing Member
Buy-Sell-Trade Rating: (4)
So you're thinking about getting more power out of your svt huh? Theres a few options you have... Naturally Aspirated or Forced Induction.
Naturally aspirated (aka non-supercharged, non turbo'd, non nitrous) is a path chosen by many in the Focus realm mostly because initally its cheaper and overall much more reliable. Not to mention out of the factory our cars were NA. Normally the mods for this catagory dont raise hp and tq levels all too much but they overall give you a much more pleasant driving experience. Here is a few examples of NA mods.
Intake - Offers moderate gains. Mostly a noise upgrade offering only a few extra horsepower. Dyno tests have proven that the stock intake box with a highlfow panel filter makes the same power.
Cold Air Intake - draws air from outside the engine bay close to the ground. has issues with water injestion. Can be cured with a bypass valve
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=142
http://www.pipercrossdirect.com/show...969&desc=Focus - Viper Intake
Short Ram Intake - essential a cone filter located in the engine bay. Has issues with heatsoak on warm days and during stop and go traffic. IAT's become dangerously high when the engine is warmed up. Some companys such as Focus Sport help alleviate this problem by providing a heatsheild but I personally would choose a different route. Problem is compounded when used with a roots type blower.
http://focussport.com/coolflo.htm
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=144
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=613
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=901
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=381
Panel Filters
http://focussport.com/filters.htm
http://focus.c-f-m.com/index.asp?Pag...PROD&ProdID=61
Modifying Stock - There are a few mods that can be done to improve the efficiency of the stock intake system. Namely removing the Hump in front of the snorkle on the radiator cover and rerouting the pressurized cowl air into the resonator port on the intake box.
LINK to testing data
Throttle Body - Mostly a driving style upgrade. on naturally aspirated engines there is little to no gains however the "throttle response" which is a result of the different butterfly design that reaches WOT faster. Gains are significantly better with a roots style supercharger.
65mm Focus Central Throttle Body - industry standard! Description above.
67mm C-F-M Throttle Body - will work well with the JRSC. Better flows with a 3" maf tubing housing (76mm) providing a less restrictive intake passage.
http://focus.c-f-m.com/index.asp?Pag...ProdID=83&HS=1
Ported Stock Throttlebody
The ultimate compromise. The SVT TB is about 63mm so slightly porting a small lip and grinding down the wedge shaped stock butterfly results in similar performace gains as the 65mm tb.
Exhaust - Some users have noted that an Offroad Pipe with the stock exhaust sounds raspy and "ricerish" so the catback is normally a tone altering device to go with the HFC or ORP.
High Flow Cat - Replaces the stock catalytic converter with a highflow unit that offers both less restriction and reduced weight.
http://focus.c-f-m.com/index.asp?Pag...OD&ProdID=1125
Off Road Pipe - a pipe that completely replaces the catalytic converter. Think of a straight through exhaust
http://focus.c-f-m.com/index.asp?Pag...PROD&ProdID=76
Cat Back Exhaust - some are offered with only a muffler, others provide a resonator as well.
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=441
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=472
http://focus.c-f-m.com/index.asp?Pag...PROD&ProdID=82
Engine
Performance Tune - The absolute first mod that should be done to the svt. it helps drivability, increases power over the entire powerband and has the ability to grow with your car!
www.focus-power.com - talk to this guy first!!!
http://focussport.com/chips.htm
http://focussport.com/sct_flasher.htm
http://focussport.com/sct_proracer.htm
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=869
Electrical - These mods have more to do with drivability than overall gains. Most are considered DIY mods but if you want to pay someone to do it, they'll be more than happy to take your money.
Coil Pack -
MSD
Screamin Demon
Performance Plugs -
Performance Wires -
MSD
Screamin Demon
Grounding Kits - 4 gauge wiring that is used to replace your pre-existing electrical grounds. This mod is useful with underdrive pulleys and with any upgrades that require a large amount of electrical draw (nitrous, stereos, neons, etc...). Dyno results have not shown any visible gains but there are supposedly gains in the performance of some electrical equipment.
Big 3 Upgrade - DIY Style
Hyperground Kit
Adjustable Cam Gear - good for adjusting the powerband to suit your driving style. Can only be used on the exhaust cam. some have claimed increases of 5-8 hp from this but it must be taken with a grain of salt. Must be installed very carefully or will result in issues with the Constant Variable Intake Cam.
http://focussport.com/camgears.htm
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=752
http://focus.c-f-m.com/index.asp?Pag...OD&ProdID=1101
Camshafts
Custom Order. Not enough info for any judgement. SVT's have already got some pretty aggressive cams.
Cylinder Head Porting
In R&D phase from CFM. Many prominent Focus Tuners have claimed that the SVT head is already pretty much perfect but there are some pretty convincing flowcharts out there that show room for improvement especially on the exhuast side.
Higher Compression Head Gasket - ZX3 headgasket will raise compression resulting in more power. A good upgrade to go with the ported cylinder head. No dyno numbers available.
http://focus.c-f-m.com/index.asp?Pag...OD&ProdID=1110
Forged Internals - a must for any real build. is a safeguard to protect against detonation and potentially increased displacement.
http://focussport.com/cosworth_connecting_rods.htm
http://focussport.com/cosworthblock.htm
http://focus.c-f-m.com/index.asp?Pag...OD&ProdID=1053
Underdrive Pulleys - a controversial upgrade. typical gains come from reduced rotating mass and an actual underdriving of accesories that reduces parasitic drag on the motor effectively increasing whp without actually increasing engine horsepower. Controversy comes from the lack of harmonic balancer reducing engine life. I'll not go into this but note that there have been no documented catastrophic engine failures do to this.
http://focussport.com/udp.htm
http://focus.c-f-m.com/index.asp?Pag...PROD&ProdID=19
http://focus.c-f-m.com/index.asp?Pag...OD&ProdID=1102
Custom Intake Manifold
Custom unit that will help in High RPM race engines.
Transmission
Lightweight Flywheel - Reduced rotating mass. Quicker throttle response and acceleration. Due to reduced rotating mass the engine will be quicker to rev and also to fall thus allowing for effective engine braking and a more sport feel to the car. Reports of gas milage loss due to higher rpms needed to start and keep up engine rpm. Is said to help reduce turbo lag yet has issues with idling with belt driven superchargers. (not enough mass to keep an idle with the extra parasitic loss from the blower)
http://focussport.com/flywheel.htm
http://focus.c-f-m.com/index.asp?Pag...ROD&ProdID=923
Limited Slip Differential - a must for anyone putting down serious power. uses tq biasing to spread power equally to both wheels. Incredibly helpful with turning while accelerating.
http://focussport.com/quaife.htm
http://focus.c-f-m.com/index.asp?Pag...OD&ProdID=1162
High Torque Clutch - *someone wanna give me a good explination on these cuz i really dont know*
http://www.clutchmasters.com/shop/?p...02&ToYear=2004
www.specclutch.com
Weight Reduction - of any kind is beneficial to overal performance of your cars performance. Below is a list of weight reduction mods that are commonly found on the focus. LINK
Daily Driver Friendly
Lightweight battery, Carbon Fiber Hood, Carbon Fiber Hatch, Wheels (most important), Flywheel (2nd Most important), Front Race Seats, Rear Seat Delete, Receiver only with only the front door speakers
Track Oriented
Remove the AC stuff, Remove the Powersteering stuff, Remove the Dash accept for the gauges, Swap all of the glass for Lexan, Remove the wheel well guards, Remove the rear bumper support, Remove both the air bags, scrape off all the sound barrier stuff, Remove all interior panels
It is my personal opinion that there are a few "beginner mods" that anyone should follow. I say beginner mods but it would be more acurate to call them "build up mods" from NA to FI with the minimal loss in investment. (ie... less wasted money) They are as follows.
Performance Flash Tune... I prefer the SCT with the Pro Racer Package so you dont have to rely on someone else. only use this if you're comfortable with your abilities to keep it within reason. its your car, nobody else will care about it as much as you do.
Panel Filter of choice... I prefer ITG
Ported Stock Throttle Body
Highflow Cat... for the somewhat environmentally conscience.
2.5" Catback Exhaust
Gap fresh spark plugs - start at 0.065 and work your way down till you get no mis-fires.
and for good measure (aka no power gains)
Rear Engine Mount
Short Throw Shifter
Big Three - For better electrical grounds. works well with all upgrades.
Weight Reduction - Lightweight battery, Carbon Fiber Hood, Carbon Fiber Hatch, Wheels, Flywheel, Front Race Seats, Rear Seat Delete, Receiver only with only the front door speakers
06 Lakeshore Slate Infiniti G35 Coupe. Deceptively Stock!
Gone But not forgotten: 2004 SVT Focus... the way a SVT should drive.
blkthunder is offline
Old 11-30-2006, 09:32 PM   #2
blkthunder
Fan#: 34375
Now for the fun Stuff
Forced Induction (Supercharger) is a path chosen by a few in the Focus community. I chose to go this path becuase it seems as though the available supercharger systems are simple, effective and least likely to need urgent maintenance work. Not to mention everyone assumes that all SVT's are supercharged... I'd hate to disappoint them
Jackson Racing Supercharger - Old Faithful.
http://www.supercharger.com/Shop/Vie...eIndexID=37672
The Jackson Racing Supercharger is the oldest of the bunch. It is an Eaton m62 blower on a focus specific intake manifold with extremely short runners. It is the cheapest and lowest yielding of all the forced induction options. Not saying its bad, but with the addition of the Ford Big Boost Kit the blower is pretty much maxed out. It is un-intercooled and maxes out at about 10psi. Some have tried, with disasterous effects, to up the boost and have had good effects until the IAT's were high enough to detonate the engine to failure or melt a piston. Due to the inefficient nature of the roots blower, the JRSC is prone to heatsoak. This can be solved by both lowering the temperature of the engine bay and chemically by water meth injection.
Would be a good idea to upgrade...
Clutch for increased tq capacity.
Works well with beginner mods...
Could benefit from the 67mm Throttle Body.
Functional Hood Vent, removing the cowl-hood seal to release heat, creative ducting to introduce cool air onto the blower itself.
Typical Output
220f whp
180 fwtq
PowerWorks Supercharger - great kit if u can swallow the asking price.
http://www.powerworks.net/focusforce.html
Big Brother to the JRSC in output, refinement, and $$$ price. It is a m62 eaton blower with *key difference* factory intercooling. The kit includes a bbk 65mm tb, short ram induction, Tune and a factory warranty. Aside from the initial tune being a tad too agressive, there have been no real downsides to the PWSC. Some say that because the intercooler obstructs the airway after the blower and due to the nature of roots blowers (not really compressing the air, more stacking air on top of air) that it is an inefficient design as well. I agree with this statement but i have yet to hear anyone complain about the kit.
There was supposed to be a big boost kit available for the PWSC but IIRC it was dropped from production. When adding boost to the base kit stronger internals are a highly suggested. This option can be done with overdriving the crank or the blower itself but IMO its not worth it.
Brakes!!! Brakes!!! Brakes!!!
Typical Output
250 fwhp
???200??? fwtq
Procharger - My personal favorite. Is a stealth option... from the top of the engine it only looks like a Cold Air Intake.
http://www.procharger.com/SPORT_COMP..._compact.shtml
The ATI procharger kit is only sold as a tuner kit meaning upon purchase you'd also have to buy Injectors, a bigger MAF, and get it dyno tuned. The kit makes power by adding 8-10 psi of boost via an intercooled centrifugal superchager model c-1b. Since the centrifugal style supercharger is more efficient than even an intercooled roots type blower there is a much higher power potential. The power delivery is quite different than both the JRSC and PWSC in that the tq and horsepower are more progressive... ie building with RPM. Some say that output is "peaky" and that may be true regarding low rpm tq, but my arguement is... in a drag how often are you below 4k rpm anyway? This kit can give about 24 psi max (theoretically)
Would be a good idea to upgrade...Clutch for increased tq capacity.
Injectors... 42+ lbs per min
Bigger MAF... or MAF converter to increase stock MAF capacity (Diablosport MAFia)
Wideband Air-Fuel Ratio Gauge
Knock Sensor Enhancer (J&S Safeguard)
Colder Range Spark Plugs
Intercooler placement is lower than desired. Could benefit from a custom Front Mount if you plan on lowering the car any.
Typical Output
Highly Subjective due to the Tuner-Kit Nature... we'll take the conservative guess and say
240 fwhp
190 fwtq
Higher outputs can be seen with getting the 10psi kit, overdriving the crank pulley or getting an even smaller supercharger pulley
Old 11-30-2006, 09:33 PM   #3
blkthunder
Fan#: 34375
Any additions... i dont want to touch turbos for a while becuase there really isnt any kits available but what do you think so far???
Old 11-30-2006, 11:43 PM   #4
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
Show me a report of "water ingestion problems" on a focus with a cold air intake that doesn't involve someone driving through a foot and a half of water.
CaysE is offline
Old 12-01-2006, 01:08 AM   #5
turbovation
all grown up
turbovation's Avatar
Fan#: 29834
What I Drive: 2006 Toyota tacoma work truck
Points 11,191, Level 69
Points: 11,191, Level: 69 Points: 11,191, Level: 69 Points: 11,191, Level: 69
Level Up 86% Completed
FF Reputation: 7 turbovation Good Standing Member
It's a rarity, but it is also a possibility, so I think it is legit to add that in there.
Solid reviews Blkthunder!
this is bob. bob has bitch tits.
turbovation is offline
Old 12-01-2006, 02:39 AM   #6
FrozenFoci
FrozenFoci's Avatar
Fan#: 41195
What I Drive: 2002 InfraRed SVTF
Points 237, Level 4
Points: 237, Level: 4 Points: 237, Level: 4 Points: 237, Level: 4
Level Up 74% Completed
FF Reputation: 3 FrozenFoci Good Standing Member
Though they're still in the beginning stages with the SVT kit, might want to check out www.xiosmotorworks.com
I'd definitely want to go with an all-in-one turbo kit if I got magically loaded and could throw $4k+ into forced induction... but I don't know enough (or have a magic source of lots of expendable cash) yet.
FrozenFoci is offline
Old 12-01-2006, 08:14 AM   #7
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,884, Level 100
Points: 51,884, Level: 100 Points: 51,884, Level: 100 Points: 51,884, Level: 100
Level Up 0% Completed
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
Buy-Sell-Trade Rating: (28)
What did fs and cfm pay you for those reveiws there is better product at better prices then fs yet you didnt list any of them
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 12-01-2006, 08:59 AM   #8
blkthunder
Fan#: 34375
didnt pay me anything. i used their pictures becuase they're easier one stop shop kinda places. i would have added some products from mcnews but it seems they're primarily zetec kinda guys... in fact i'll go through and add some just for you .
It is also one of the reasons i included the *opinionated* in the title. you may be right, but i could also take out the links and the article would be no different being as the "reviews" arent product specific. I wanted this to be a comprehensive guide for those damn V8 guys that come in here all lost and such. Not the ... here's the best of the best at the cheapest price. That sounds like a job for the consciencious consumer.
Old 12-01-2006, 09:08 AM   #9
Charged SVTF
Was that our exit?!?
Charged SVTF's Avatar
Fan#: 22047
What I Drive: 2002 Sonic Blue Supercharged SVT
FF Reputation: 30 Charged SVTF Great Standing Member
Nice work.
2002 Sonic Blue SVT #246 of 4788 cardomain.com/ride/2483606
- JRSC BBK - Exhaust - Intake - Suspension -
First Place 2007 Season SJR-SCCA Solo and 2007 Rookie of the Year SJR-SCCA #20 SM
Charged SVTF is offline
Old 12-01-2006, 01:30 PM   #10
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Wow! Thanks blkthunder!
I hate to say this, but a bunch of your links are hosed.
You might want to check all of them that are truncated in the post with "...".
For example, all the c-f-m.com links only go to their main page.
WD40 is offline
