P0705 - Transmission Range Sensor Circuit Malfunction - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-30-2006, 07:24 PM   #1
madamut
Fan#: 41003
FF Reputation: 1 madamut Good Standing Member
I have a 2001 Focus Se, Zetec engine.
Today I got the check engine light on, the code I got was P0705 meaning Transmission Range Sensor Circuit Malfunction (PRNDL Input).
Does anybody know what exactly this sensor does and what to do about it?
Thanks.
madamut is offline
Old 11-30-2006, 07:34 PM   #2
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
im assuming you have an automatic (ATX). sounds like the ECU lost track of what position the shift lever was in. possibly just a fluke.
this is what i would do
reset the ECU by disconnecting the negative terminal on the batter for 15 minutes.
reconnect and go for a drive. more than likely, this code will not pop again. do you have any noticable issues with your tranny?
scrammer is offline
Old 11-30-2006, 08:01 PM   #3
madamut
Fan#: 41003
Thanks scrammer,
Yes, I have an automatic transmission. I bought the car 1 month ago, so far no problems with the transmission. The car has 60k miles and I had the transmission fluid changed already a couple of days after I bought it.
Now that I think of it, when I started driving today, by mistake I put the transmission in "2" not "Drive". This was before actually starting driving, just for a couple of seconds. After a couple of minutes I noticed the engine light came on.
Now that I think of it, this may cause the problem.
I will disconnect the battery cable and see what happens afterwards.
madamut is offline
Old 11-30-2006, 08:19 PM   #4
incubus625
incubus625's Avatar
Fan#: 38414
What I Drive: 2012 Blue Fiesta Hatch 5 speed
FF Reputation: 2 incubus625 Good Standing Member
i had the same thing on my 04, i figured "lets see how she drives in 2nd" after about 3 weeks of owning it. um my advice, dont use it, cause i got the same code with mine. luckly the dealership fixed it, they asked "have you been manually changing the gears while driving?" i was like no.... it did drive different too, felt like it took longer to shift and would kinda jolt when it did. also the over drive light went on, then after a while the check engine light too. o yeah and mile gas milage sucked too, for the week or so it took till i got it fixed.
incubus625 is offline
Old 08-07-2007, 07:19 PM   #5
tekilazo
Fan#: 49279
What I Drive: 2001 Yellow ZX3
FF Reputation: 1 tekilazo Good Standing Member
Arrow
did you get that fixed???? I have the same problem but I can feel the transmission that it looses track of where it is.
i.e. I put it in reverse and it kicks back but the backup lights don't turn on.
Did you replace the sensor? did you clean it? how did you replace it? is there a DYI somewhere?
thanks for any help!!!
tekilazo is offline
Old 08-19-2009, 09:16 PM   #6
SuperJoe
Fan#: 61213
What I Drive: 2003 Dark Grey ZTS
FF Reputation: 1 SuperJoe Good Standing Member
i just got this same code today and the car was driving like crap before it came on. my wife has been driving the car quite a bit lately, i dont know if that has anything to do with it and yes mine is an automatic as well.
03 focus ZTS 2.0 ZTECH
do i need to replace the sensor or should i try reseting the computer?
SuperJoe is offline
Old 03-08-2010, 02:26 PM   #7
itskeiser
itskeiser's Avatar
Fan#: 45549
What I Drive: 01 Silver SE(RIP),01 Gold SE
FF Reputation: 1 itskeiser Good Standing Member
ditto-dealer put in a used tranny after mine blew, and a week later i had his issue-now they want another 150 just to look at the tranny rather than the actual code issue,the sensor
sensors easy to find when on ramps, but Im havin a hell of a time gettin it unhooked from the wire-any suggestions for making it easier? I wanna give cleaning it a shot,or at worst replacing it myself
00 Harvest Gold Se aka Betty Boop II
itskeiser is offline
Old 03-08-2010, 02:29 PM   #8
SuperJoe
Fan#: 61213
For me the problem actually ended up being one of the screws that holds the selector came out and there for was not actually shifting, once i replaced the screws cleared the codes i was rocking and rolling again.
SuperJoe is offline
Old 03-09-2010, 06:45 PM   #9
itskeiser
itskeiser's Avatar
Fan#: 45549
I'll jack it up and take a look tomorrow, didn't see any screw issues when I glanced at it
Old 04-20-2010, 08:57 PM   #10
guy48065
Fan#: 50317
What I Drive: I maintain my daughter's 2000 SE
FF Reputation: 1 guy48065 Good Standing Member
Big *BUMP*
In searching for a fix for P0705 I found several threads asking for how to fix/replace/adjust with no answers in any of them. Now I'd like to give it a try.
Is the sensor position adjustable like neutral safety switches used to be? How do you align it properly?
IF nobody here knows then just ignore this plea like all the rest...
guy48065 is offline
