How To: Lock Switch Lights (SVT) - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 07-18-2009, 06:03 PM   #61
SilverEagle
SilverEagle's Avatar
Fan#: 53070
What I Drive: 2002 Silver ZX5
FF Reputation: 2 SilverEagle Good Standing Member
Thumbs up Great Mod
This was a great mod., the door locks look great now in Blue!
SilverEagle is offline
Old 07-19-2009, 05:24 PM   #62
X-Rated
X-Rated's Avatar
Fan#: 55237
What I Drive: 03 Tan ZTW
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
FF Reputation: 4 X-Rated Good Standing Member
Buy-Sell-Trade Rating: (12)
[QUOTE=Rudel;1323411]Tools you will need:
Begin by using the 1/4 wratchet with the extention and T-20 torx bit and unscrew the bolt that is holding the door handle, lock, and switches.
Once that is done, pull on the face plate until it comes off. It may take some M.A.N.
Now take about 4 peices of wire, 8in each, and strip the ends about 1/4" inch, and start to twist the threaded end.
Now tin the ends of them so they will not bird-cage on you when they are pushed into the socket terminals.
For the following instructions there is no need to do any more soldering, all you have to do us snug the wire into the back of the sockets with the other wire(s). After that zip tie them so they are not all dangling around.......
On the back of the socket for the window switch do the following:
Put the ground (blue) wire into socket 1, with the Black Wire
NOTE: Passenger side is socket 4, with the Black Wire
Put the Hot (red) wire into socket 10, with the Blue/Green Wire
NOTE: Passenger side is socket 2, with the White/Green Wire
On the back of the socket for the lock switches do the following:
Put the ground (blue) wire into socket 4, which is the LED Ground.
Put the Hot (red) wire into socket 5, which is the LED 12V Supply.
And the outcome!
Here is a diagram incase you need more reference:
[QUOTE=unfknrl;1438027]Awesome write-up. I own a 2004 4dr so the wiring harness was a bit different. Here's for those who have 4 dr SVT's
Props to Rudel & unfknrl!!!!!!!! Just finished this mod, don't know if it worked yet cause it's still daylight so will have to wait until night time, if it needs more work well then thank god for drop lights! And just for the record, everything dashlight wise is green so for now it will stay that way.
2003 ZTW - 2.0L 16v Zetec: 9mm Racing plug wires, long style CAI, shorty header w/down pipe, glasspack for a resonator & raptor muffler
Drive it like you stole it!!
X-Rated is offline
Old 07-19-2009, 10:04 PM   #63
X-Rated
X-Rated's Avatar
Fan#: 55237
Originally Posted by TheMac View Post
Thanks OP! I just did this mod while I was cleaning my car. Just a note, you can wire the grounds on the lock switches to the grounds that are already on the plug, so you only have to run the power wire, and just jump the ground on the Lock plug.
Did that, worked perfect! Just 1 thing, I thought they were switched by the headlight switch? Apparently not, once the key is on so are the button lights but since they are L.E.D.'s they shouldn't burn out.
I guess my next mod will be changing the lights to red, anything to do with the dash lights. Any suggestions?
X-Rated is offline
Old 07-20-2009, 09:26 PM   #64
X-Rated
X-Rated's Avatar
Fan#: 55237
Not to jack this thread but does anyone know if the symbols and the dot on the dial light up on the power mirror control?
X-Rated is offline
Old 07-21-2009, 10:55 AM   #65
tkheaven
tkheaven's Avatar
Fan#: 59098
What I Drive: 2002 Pitch Black ZX3
Points 1,140, Level 18
Points: 1,140, Level: 18 Points: 1,140, Level: 18 Points: 1,140, Level: 18
Level Up 40% Completed
FF Reputation: 3 tkheaven Good Standing Member
I had a brainfart for a moment, you had me at "power mirror control".. lol
Mine have never lit, and I've never seen mention of it anywhere so I'm assuming no.
"possible" cloning of humans - check
"possible" evolution from non-living particles - check
"possible" time travel aka Big Bang machine - check
creating the perfect pres. candidate and send him back eight years ...impossible...
tkheaven is offline
Old 07-21-2009, 09:14 PM   #66
X-Rated
X-Rated's Avatar
Fan#: 55237
Yea, I haven't tried to pull it apart to check but I thought I would ask.
Here's a question that does pertain to this thread, when the door is locked you see the white emblem, don't know if it's painted on or has an led option for it. Anyone?
X-Rated is offline
Old 07-21-2009, 09:18 PM   #67
OrangeSVTguy
Get Squashed
OrangeSVTguy's Avatar
Fan#: 33384
What I Drive: '04 Comp. Orange SVT 3dr.
Points 69,698, Level 100
Points: 69,698, Level: 100 Points: 69,698, Level: 100 Points: 69,698, Level: 100
Level Up 0% Completed
FF Reputation: 44 OrangeSVTguy Great Standing Member
Buy-Sell-Trade Rating: (16)
No Ford cheap out on us. Those are painted, just like the cruise control buttons
Oh BTW: when you quote someone, it's proper forum etiquette to not quote the entire post, especially if there are lots of pictures, just remove the [IMG][/IMG] tags or any thing else that's not relevant
Lee
SVT Squad #227 || Build # 1329 of 1978 || FF ROTM Oct. 2006
OrangeSVTguy is offline
Old 07-21-2009, 09:53 PM   #68
X-Rated
X-Rated's Avatar
Fan#: 55237
Thanks orange for the advice, cleaned it up a bit. I am also assuming the "white" is painted on the the lock also when it's actually locked?
X-Rated is offline
Old 07-21-2009, 10:35 PM   #69
OrangeSVTguy
Get Squashed
Fan#: 33384
no problemo.
Yes its painted on that too.
Lee
Old 07-28-2009, 02:55 PM   #70
X-Rated
X-Rated's Avatar
Fan#: 55237
Originally Posted by BlazingCopper_ZX3 View Post
Nice write up on the Door Lock LEDs.
I'm not too hip on just stuffing the wire into the socket and hope'n they don't fall out or worst yet they don't corrode over time and stop working.
You need to take a look at my How-to if you want to replace the LED with a different color. I took the switch apart and photographed the LED and its current limiting resistor:
http://www.ineedawebsite.com/Blazing...ck%20LEDs.html
Look at the last photo.
Enjoy
Hey Blaze, can this be done with the window switch led's? And if so, do you have detailed pics like the lock one?
X-Rated is offline
