2005 Focus ZX4 Tune Up - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-20-2006, 05:04 PM   #1
carpenter64
Fan#: 41267
FF Reputation: 1 carpenter64 Good Standing Member
I own a 2005 Focus ZX4 with 46,000 miles on it and it needs a tune up. I am told that it only needs plugs and a fuel filter. How about a cap and rotor and the such. I cannot see paying the dealer $250 for 4 spark plugs and one fuel filter. The dealer is no help whatsoever. I would appreciate any specs anyone could give me. It has the 2.0 I believe. It has the reaplceable air filter by the battery box. Thanks crowd!
carpenter64 is offline
Old 11-20-2006, 05:10 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Welcome to the world of moden engine electronics. Distributers have long gone away, so there is no cap or rotor to be maintained. In fact, instead of one coil power all spark plugs, there is a coil for each spark plug, sitting right on top, so there are no spark plug wires either.
Also, your air filter isn't servicable. All Duratecs have a lifetime air filter.
Your manual should outline the service needed. It should only be an oil change, maybe a fuel filter, and a bunch of inspections.
Egz is offline
Old 12-01-2006, 03:56 PM   #3
carpenter64
Fan#: 41267
Do you have any idea what would be the best plugs to get for my 2005 ZX4 and how do I determine motor size and whether or not it is a Duratec?
Old 12-01-2006, 08:27 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,590, Level 98
Points: 27,590, Level: 98 Points: 27,590, Level: 98 Points: 27,590, Level: 98
Level Up 24% Completed
Forum Activity 12%
How do you have a 2005 with a filter you can replace from under the hood- if it's stock? Just curious, as far as I know the factory only supplied the non-removeable lifetime filters which are located inside the fender.
If your intake manifold is in the front of the engine compartment- then your motor is a Duratec, if it's in the back of the engine compartment, then it's a Zetec. I don't know if these engines have plugs with the same heat range or not. Motor size will be listed on the VECI (in small print)- that's the sticker on the bottom of the hood of the car that has the vacuum routing and emissions diagram on it.
Autolite 104's have been the change plug of choice. They only last 20k miles, but only cost $5 total for all. Platinum is much lower in conductance than the copper core used in the 104's, but will last longer- and costs 3x much.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 12-01-2006, 08:30 PM   #5
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 12%
Oh, you can also look for coil on plug ignition. The Duratec has this type of ignition- the little coils bolt on top of the valve cover one on top of each plug. A Zetec motor will have a coil with 4 ouputs, and standard plug wires. The Duratec motor does not have plug wires like other types of ignition systems.
Be eclectic.
Old 12-01-2006, 08:40 PM   #6
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
carpenter64 -
See also this thread:
http://www.focusfanatics.com/forum/s...t=100388&pp=12
drjkel
drjkel is offline
Old 12-02-2006, 02:19 PM   #7
carpenter64
Fan#: 41267
Thanks a ton. The air filter box is inside the drivers side fender and the top is held on with 1 or 2 bolts and the filter just lifts right out. It was that way when I bought it. The only other thing I have noticed since you seem very knowledgable is that the car seems to have a little bit of a buzz in the steering wheel during idle that it has never had. the car has 47,000 miles on it and I thought perhaps it needed new plugs and a fuel filter. I don't guess either would hurt. I also have the noisest Goodyear tires I have ever seen. The make the most road noise and that is a a shame out of a car so good otherwise. Any ideas on tire choice? Ohh and based on your description, mine is a Duratec. It has one coil and the manifold is in the front. Thanks for all your help!
Old 12-03-2006, 10:10 PM   #8
snake eyes
snake eyes's Avatar
Fan#: 41431
What I Drive: 2004 EAP black SVT
Points 434, Level 8
Points: 434, Level: 8 Points: 434, Level: 8 Points: 434, Level: 8
Level Up 68% Completed
FF Reputation: 1 snake eyes Good Standing Member
um if its making noise when turning check your power steering fluid, its prob getting low causing that to happen.
I like kuhmo 712's, shorter life span, awesome grip for the money
<l><l>
2004 EAP SVTF, one of 350.
Dammit CHUCK
snake eyes is offline
Old 12-04-2006, 07:48 AM   #9
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Can you get a picture of this change-able filter? I'm curious.
Egz is offline
Old 01-19-2007, 07:19 PM   #10
Sonicbluezx3
.....NObama.....
Sonicbluezx3's Avatar
Fan#: 8674
What I Drive: 05 Sonic Blue ZX3
Points 11,348, Level 70
Points: 11,348, Level: 70 Points: 11,348, Level: 70 Points: 11,348, Level: 70
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 2%
FF Reputation: 18 Sonicbluezx3 Great Standing Member
Buy-Sell-Trade Rating: (9)
<l><l>
don't buy kumho tires....
Buy something good like BFGs or Pirelli...
just for the love of God, don't buy Kumho tires...
Sonicbluezx3 is offline
