thermostat housing leak? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-20-2006, 10:03 AM   #1
vito313
Fan#: 22771
What I Drive: 2002 pitch black svtf
FF Reputation: 1 vito313 Good Standing Member
Exclamation thermostat housing leak?
Does anyone know where to get a aftermarket thermostat housing? i have a leak and cannot figure it out. I replaced the o-ring gasket inside the housing but it still leaks. Any help with this would greatly be appreciated!
vito313 is offline
Old 11-20-2006, 11:07 AM   #2
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Very commom leak, actually not only on the focus but all Ford's in general. They 'tend' to loose coolant mysteriously but for the most part, all related to a cracked thermo housing.
I don't know of any specific brands, when this happenned to me, I replaced it with an OEM.
Chad (S2)
S2 is offline
Old 11-20-2006, 11:25 AM   #3
DilSVT
Fan#: 1793
What I Drive: 03 SVT Focus
FF Reputation: 1 DilSVT Good Standing Member
Buy-Sell-Trade Rating: (4)
I had same problem with my housing when I replaced the thermo. I noticed that there is not much room for error when putting item back together. The metal bracket has to be tight on the left side or you will leak constantly. The design is sub-par with those three screws, just make sure they are all in straight and that bracket is on tight or it will leak like a Sunofabitch.
03' SVT Focus w/YRF0
AEM CAI, FC 65mm TB, FS UDP, SCT by FS, Kent Cam Gear, MBRP, SD and Firewire, FC STS, All VF Mounts, CFM Silicone Couplers, Gear Balance Delete, NE ORP, EBC Green Stuff, FS Front - Rear Stress Bars, KW Springs
DilSVT is offline
Old 11-20-2006, 12:03 PM   #4
shftat6
Fan#: 36911
What I Drive: '04 CD Silver SVT Euro
FF Reputation: 1 shftat6 Good Standing Member
Just had mine done last week under warranty. (29k) I can't believe they use plastic for it. VW's are just as bad, they are a known issue with them too only they are harder to get to.
Proud Participant of The Car Lounge
shftat6 is offline
Old 11-20-2006, 12:07 PM   #5
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
^^ yeah plastic, my thoughts exactly......
Chad (S2)
S2 is offline
Old 11-20-2006, 05:31 PM   #6
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Moved to "Ford Focus Technical Chat"
Check here :
http://www.focusfanatics.com/forum/s...ad.php?t=75074
^^^ It may not be the housing itself, it could be the plug as shown in the linked thread.
And...Here's some more:
http://www.focusfanatics.com/forum/s...ad.php?t=62731
http://www.focusfanatics.com/forum/s...ad.php?t=74242
http://www.focusfanatics.com/forum/s...ad.php?t=37750
WD40 is offline
Old 11-20-2006, 06:38 PM   #7
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,049, Level 33
Points: 3,049, Level: 33 Points: 3,049, Level: 33 Points: 3,049, Level: 33
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 11 hEaT Great Standing Member
Mine was warped a bit on the inside. Looked fine until I held it up to the new one. Took about 30min to remove the old one, switch over the thermostat, and bolt the new one up.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 11-21-2006, 03:07 AM   #8
vito313
Fan#: 22771
Thanks a ton!!! Mine is also leaking from that plug in the thermostat housing, i will be sure to fix this weekend!!
vito313 is offline
Old 11-23-2006, 03:44 PM   #9
SVTF4243
SVTF4243's Avatar
Fan#: 4068
What I Drive: SVT 2002
Points 4,095, Level 40
Points: 4,095, Level: 40 Points: 4,095, Level: 40 Points: 4,095, Level: 40
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 2%
FF Reputation: 11 SVTF4243 Great Standing Member
S2 would you add bryanjw82's & JohnMichaels's write up to the How To Archive?
Most of us will need to go there at some point
Thanks!
Silver SVT 2002 svtf4243.com
Silver ST3 MR::: 02 11 2013
GO :: Cobb RRM | Accelerator petal mod| JBR OCC | STS | Springs| Rear Swaybar | Tune
SHOW :: Lights tint | Calipers Painted| Graphite colored wheels| Back up Cam | Window Tint
SVTF4243 is offline
Old 11-23-2006, 04:04 PM   #10
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
Thanks!
Yup definitely will...
Chad (S2)
S2 is offline
