Alternator Clip "How-To"... - Page 3 - Focus Fanatics
Old 06-04-2008, 05:54 PM   #21
digdug18
Fan#: 35100
What I Drive: ???
FF Reputation: 1 digdug18 Good Standing Member
if you havent it would also help to upgrade your big 3 as well, meaning your 2 ground leads and your alt to battery lead, with atleast 4ga wire
digdug18 is offline
Old 06-21-2008, 04:28 AM   #22
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Memberbluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
There's an easy way to check for alternator problems......get a digital volt meter that plugs into the lighter socket. (Walmart, other places) You can easily monitor the voltage as you're driving along.
Normal just sitting there nothing on......about 12.0-12.5V depending on the temperature.
While starting......drops way down 8-9v (varies)
while idling everything on......around 12v
while driving.......around 14v (varies with temperature and battery state of charge)
really cold weather......slightly higher voltage, maybe 14.5v.
weak battery.......slightly higher voltage, maybe 14v+ (it's trying to charge)
You got a problem if......you start seeing voltages, or voltage spikes over 15V or so. You'll start burning bulbs, maybe hear relays clicking. The battery will boil out the fluid, you'll see corrosion around the terminals. Or your battery will start going dead.
Apparently these newer Focus models have a main ECU relay that controls other relays (might go by another name), so if you turn the key and nothing happens, your battery voltage may be too low to energize the starter relay. Check the volt meter that you just bought. Much lower than 11V and you really got a problem.
You can check the battery itself by the use of a battery load tester (Harbor freight). Do this after you charged it up for a long time with an external charger. Auto parts stores do this for free....but remember they want to sell you a battery.
If your battery tests good after charging.....blame the alternator or a broken wire like the OP. Alternators sometimes make strange/loud noises as they're beginning to fail (sounds like a bad bearing or something). But not always. A flickering battery lite on the dash is a good sign of alternator problems.
But that little volt meter can tell you quite a bit....
bluefront is offline
Old 07-13-2008, 01:17 AM   #23
rosefocus
Fan#: 48647
What I Drive: 2002 Silver SVT
FF Reputation: 1 rosefocus Good Standing Member
My alternator clip looks intact, and I have all of these issues, including more than just the battery light;
1. the entire intrument cluster goes crazy, including the tach and speedometer going to zero, and the cd changer resets and has to cycle through the cds in the changer again.
2. the vehicle "stumbles" anywhere above 4000 rpm.
3. turning the car completely off and back on fixes the issue, but there is always a "dead spot" where the car will not turn on, and I have to play with various electronics in the car (ie the brake pedal, interior lights etc) to get the vehicle to bring up all the lights/guages and be able to start again.
4. after the restart of the car, generally the CEL light is on, but if I turn the car off and on again once more, the CEL goes away. This is a big problem because autozone/oreilltys/advance all have to turn the car off and back on to test CELs, and as such the light disappears and no code is given.
5. This only seems to occur when the lights, a/c, radio, and/or windshield wipers are all on. No problems unless all of these things are operating at the same time. Of course you could say "just dont run them all at the same time" but I cant stop the rain or the heat or both at the same time in Indiana.
Any help is appreciated, I want to do my homework before I start replacing things.
Edit: 2002 SVT, 72k miles
rosefocus is offline
Old 08-19-2008, 04:48 AM   #24
MVent
MVent's Avatar
Fan#: 17635
What I Drive: 2012 Focus Hatchback SE
FF Reputation: 2 MVent Good Standing Member
I'm also having problems with my car's interior and exterior lights dimming while I'm driving. Notice the lights always go dim when I'm on the gas. I hope it's just the wiring, extended warranty expired in June. :(
2003 Focus SVT - SOLD
2012 Focus SE Hatchback
MVent is offline
Old 08-19-2008, 10:44 AM   #25
polishlanman
polishlanman's Avatar
Fan#: 50932
What I Drive: 2003 ZX5 2.3L
FF Reputation: 2 polishlanman Good Standing Member
Buy-Sell-Trade Rating: (12)
Originally Posted by ANTHONYD View Post
I have the same "flickering" but my car also whines (almost sounds boosted) From what I hear, this is an idication that the alternator is on it's way out.
Can anyone else confirm this for me?
I like that sound :)
Actually, on my dad's Ford Van, before the alternator went out for a few thousand miles it had a slight whine to it.
Funny thing is, when ford replaced it, it was still there.... but then it went away after a few thousand..... weird huh?
polishlanman is offline
Old 12-25-2008, 01:53 AM   #26
big_daddy
big_daddy's Avatar
Fan#: 59311
What I Drive: 2002 black sedan. The Kona is gone.
FF Reputation: 1 big_daddy Good Standing Member
I can confirm it. Mine did the exact same thing then got really loud before the alt locked up on me.
big_daddy is offline
Old 01-12-2009, 07:45 AM   #27
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO' Archive.....
Chad (S2)
S2 is offline
Old 01-12-2009, 10:24 AM   #28
bdnld4482
Fan#: 46063
What I Drive: 2012 black focus titanium
FF Reputation: 37 bdnld4482 Great Standing Member
nice write up.
bdnld4482 is offline
Old 01-12-2009, 10:38 AM   #29
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
Just in case anybody missed the first two that said this:
If at all possible, solder all connections on your car. Cars shake rattle & tug, they see drastic temperature changes, etc. Your electrical connections take lots of abuse, so any connections (especially ones that have already failed once) should be soldered if at all possible.
SCT PRP FTMFW!
mellephants is offline
Old 03-13-2009, 02:50 AM   #30
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
FF Reputation: 47 DrkKnight614 Great Standing Member
Yay....problem after problem after problem. My car was doing this last night, and earlier today with the relay clicking thing and my lights flickering, was wondering what it was. God I love this site, but God I'm annoyed crap keeps happening to my focus. Hopefully its just the relay is messed of I accidentally mess it up the other day when I was wiping things down in my engine bay. I really don't feel like having to pay for a new alternator. And now that somebody mentioned a whine, I felt like I was hearing something last night when I was driving as well.....great.
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
