Alternator Clip "How-To"... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-20-2006, 02:09 AM   #1
SVTFucus
SVTFucus's Avatar
Fan#: 23680
What I Drive: 2002 Pitch Black SVT
FF Reputation: 1 SVTFucus Good Standing Member
This Friday I decided to find out what was causing my electrical problems. The problems leading up this were:
-flickeing headlights and interior lights
-battery light coming on and off while driving
-"clicking" noise coming from underneath the dashboard
I had read many threads from various boards from buying grounding kits to replacing the alternator clip to correct this problem. Upon closer inspection I noticed that one of my wires had come out of the clip to the alternator, with hope that this was causing ALL of the above symptoms. I bought a new "wiring pigtail kit" from ford and followed the instructions to install it. Below are the pictures(still need to take some more pictures) showing the broken wire, the kit, the butt connectors I used to wire the new clip in place of the old one and the final result.
Sep-2010 Update:
Detailed instructions from FF member CaysE
Originally Posted by CaysE View Post
Remove the negative battery terminal connection.
Unplug the 3 or 4 connectors that are in the way.
Unplug the vaccuum line that's in the way (fuel pressure sensor?).
Unplug the 3-wire alternator connector. Remove the electrical tape and pull back the wire loom. You should see one wire has a fusible link on it.
Unlatch the main wiring harness from the firewall. You have to pop the harness out of 2 or 3 clips. This lets you pull the harness higher up so it's easier to solder.
Cut the 3 wires behind the fusible link (about halfway to the main harness). KEEP THE CONNECTOR! The replacement part does NOT have color coded wiring!
Keeping note of which wire goes where, cut the new plug's wiring to length, strip the ends, solder, and heatshrink.
Re-mount the main harness, plug everything back in, and you're good to go!
Sep-2010 Update:
Stay tuned for new pics.
Broken wire:
What the packaging looks like of the kit:
What the kit consists of(new clip, 3 wire connectors, 3 heat shrink tubes):
The butt connectors I used to connect the new wires of the clip, to the wires leading to the old clip:
I will have more of the wires connected, and then of the heat shrink wrapped around the connectors and wires. Just thought I'd show everyone how it looked. Total time it took to install was about 30 minutes.
Also, the clip can be removed from the alternator by using a small flat head screwdriver and sliding the clip off the bracket.
2002 Pitch Black SVT Focus w/Red & Black interior
#2852 of 4788
1997 White SVT Cobra....sure...it's all stock!!!
#4408 of 6971
SVTFucus is offline
Old 11-20-2006, 02:31 PM   #2
Bigfonsz
Bigfonsz's Avatar
Fan#: 20407
What I Drive: 2002 SVT Turbo ZX3
FF Reputation: 9 Bigfonsz Good Standing Member
Buy-Sell-Trade Rating: (10)
I will be doing mine tonight. Thanks
Bigfonsz is offline
Old 11-20-2006, 02:56 PM   #3
SVTFucus
SVTFucus's Avatar
Fan#: 23680
np man......I did cut the wires from the new clip about 2 inches from the clip and have about a 1/4" of wire going into the butt connector.
Just be SURE to put the heat shrink on the wire BEFORE you squeeze the butt connector down, THEN move the heat shrink over the butt connector and heat.
PM me if you have any questions......I have class tonight till 9pm Texas time.
#2852 of 4788
#4408 of 6971
SVTFucus is offline
Old 11-21-2006, 05:54 PM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
"Stickied"...
Till S2 (or me for that matter) gets it added to the Complete "How-To" Archive.
Thanks SVTFucus!
WD40 is offline
Old 11-21-2006, 07:02 PM   #5
SVTFucus
SVTFucus's Avatar
Fan#: 23680
thanks for making it a "sticky" WD40....just trying to do my part to help others out!!
It's been since Friday that the new clip has been on and there has been NO problems with lights flickering or the battery light coming on.
#2852 of 4788
#4408 of 6971
SVTFucus is offline
Old 11-22-2006, 10:36 AM   #6
remmargorp
remmargorp's Avatar
Fan#: 25755
What I Drive: 2005 Yellow ZX3 SES
FF Reputation: 2 remmargorp Good Standing Member
Since this is a sticky, I feel the title should be corrected to say alternator.
remmargorp is offline
Old 11-22-2006, 04:54 PM   #7
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^Thanks...fixed it.
WD40 is offline
Old 11-30-2006, 10:18 PM   #8
Aqua12632
Aqua12632's Avatar
Fan#: 41244
What I Drive: 2002 Blue Focus SVT
FF Reputation: 1 Aqua12632 Good Standing Member
Thumbs up Thanks!
Nice man great post - helped me to resolve a slightly different issue which actually caused the power to spike sometimes and dim other times (sometimes flickering). At first, when i took everything apart, i found that the center wire on the connector had broken out, so i attempted to repair the connector. afterwards, the issue was still there, although slightly less severely - most of my friends (and even a ford dealership) told me not to worry about it - and i wasnt too worried about it until one night it burnt out one of my headlights - after that i did some more research on the issue and came across this post - Thanks man - fixed my issue the same way (and replaced the alternator with higher performance model, although now i know the old one still works)
symptoms i noticed
-flickering power / power spikes (15-20% brighter) with headlights and interior lights (specifically on hard accel)
-battery light coming on and off while driving, sometimes it stayed on
-"clicking" noise coming from underneath the dashboard (sounds like a relay)
-alternator tested while problem existed (@2k RPM) ~25 Amps/12V
-tested voltage during power spike (reached 15V-16V at battery)
...hope this additional information can help someone else
btw : if anyone is interested in an OEM alternator - i am interested in selling, or possibly trading for other focus parts (anyone have an extra SVT IMRC )
Aqua12632 is offline
Old 01-25-2007, 07:21 PM   #9
DFv2
WWTPD?
DFv2's Avatar
Fan#: 42684
What I Drive: 2008 Lightning Red STi
FF Reputation: 31 DFv2 Great Standing Member
Buy-Sell-Trade Rating: (12)
I have all of the same exact symptoms, yet my wires look to be intact. Hoping it doesnt turn into a real issue before I can find the source.
DFv2 is offline
Old 01-31-2007, 08:52 AM   #10
ANTHONYD
ANTHONYD's Avatar
Fan#: 17728
What I Drive: Grabber Green Se Sedan 2002
FF Reputation: 1 ANTHONYD Good Standing Member
I have the same "flickering" but my car also whines (almost sounds boosted) From what I hear, this is an idication that the alternator is on it's way out.
Can anyone else confirm this for me?
Meh.
ANTHONYD is offline
