valve cover torque spec? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-23-2011, 09:24 PM   #11
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 14,960, Level 79
Points: 14,960, Level: 79 Points: 14,960, Level: 79 Points: 14,960, Level: 79
Level Up 22% Completed
Forum Activity 11%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
confirmed
52in/lbs
please make sure you tighten to INCH/lbs and not FT/LBS. but if your ft/lb torque wrench accurately reads and works that low then you can set it to 4.3ft/lbs i think if my math is right. dont trust my math right now though because ive been awake for almost 2 full days working and piddle farting around and im finally crashing for the night.
start on the bolts in the center of the VC and work your way out. no particular order
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is online now
Old 01-23-2011, 09:26 PM   #12
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
No your about right, it takes 12 inch pounds to equal 1 ft-lb. I used FT-LB's because I got two torque wrenches one that you set and it clicks and one with a little needle that move across a board down near the handle. Either way will work, now you know what it is in either in ft-lb or in inches-lb's.
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-23-2011, 11:20 PM   #13
drlucchesi
Fan#: 82810
What I Drive: 2001, Red, ZTS
FF Reputation: 1 drlucchesi Good Standing Member
Thanks
Thanks Focusmaniac. That's what I needed. Appreciate the help.
drlucchesi is offline
Old 11-06-2012, 05:00 PM   #14
StephenElsbree1986
StephenElsbree1986's Avatar
Fan#: 104271
What I Drive: CD Silver 2003 SVT
Points 1,135, Level 18
Points: 1,135, Level: 18 Points: 1,135, Level: 18 Points: 1,135, Level: 18
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 3%
FF Reputation: 1 StephenElsbree1986 Good Standing Member
Yes, yes, necro thread but how important is this I don't havea torque wrech can I just tighten em down? and not worry about it.
175WHP/153TQ N/A
StephenElsbree1986 is offline
Old 11-06-2012, 08:28 PM   #15
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,477, Level 57
Points: 7,477, Level: 57 Points: 7,477, Level: 57 Points: 7,477, Level: 57
Level Up 64% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
Pretty much. Just get them nice and tight. Nothing crazy. Most of us in Houston crew don't use a torque wrench for this and have never had a problem or leak.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is online now
Old 11-06-2012, 10:32 PM   #16
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
I would not refer to it so much as 'nice and tight'. The bolts are shouldered meaning they go down to hit solid and then anything more you put on you are simply twisting the bolt in two and pulling threads too. I simply go down evenly until I feel them hit and then just enough more to verify they did hit. Using torque wrench there is quite frankly irrelevant since the hit tells you to stop.
6 mm.-1.0 thread pitch like these typically strip aluminum threads at anything over like 9 ft.lbs. I'd stay at 4-6 but if using ft.lbs. wrench you probably have one that is too big for the job, what's needed is a short 6 inch one with a torque that low. The bigger one is simply too big to be accurate with torque that low.
Doesn't matter anyway, I never torque them. Once you figure out all they can do is hit and no further gasket squeezing can occur after that, it becomes easy to simply feel it hit and pretty much stop there. Never broke a bolt or pulled threads, and never have leaks either.
Same thing with the thermostat housings on these, the bolts hit to limit of part, no tightening you can do after that helps a thing, all you are doing is breaking or cracking your stat housing, the damage then shows up later because you preloaded the plastic part too much. The parts were not meant to be that tight, once you hit part solid you have compressed all the gasket that is possible anyway. I love it when guys here talk about going back to retighten more when part leaks, I can practically hear the part crack. Look at how many people have to buy new housings here, I've got 3 zetecs back to '98 and have had housings off all 3 many times and never failed one yet. I don't torque these either, you again look for the part hitting solid, no torque wrench needed.
amc49 is offline
Old 11-06-2012, 10:39 PM   #17
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Forum Activity 40%
^exactly.
Team Focalize
Hatch Nation #9
Old 11-07-2012, 01:08 PM   #18
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
I can't get my bolts out... am I missing something they're all lifted but they're catching on something... I gotta be doing something wrong... I have them all loosen i can just keep turning them I can even pull up a little bit but they feel like they're hooking on something, I do have a SVT not sure if that makes a diffrence.I even poped the garment up with a screen driver and tried prying it off... nothing.. What am I doing wrong
175WHP/153TQ N/A
Old 11-07-2012, 06:19 PM   #19
amc49
Fan#: 96610
Forum Activity 9%
You're freaking out over nothing is what. The bolts are trapped in the rubber grommet molded into cover. Grommets can be part of overall gasket or separate, either way they trap bolts in place so valve cover has gasket/bolts already together to quickly throw it on motor at the factory.
amc49 is offline
