Rear Window Regulators - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-16-2006, 10:33 AM   #1
mdbgx2
Fan#: 41189
What I Drive: 2001 Sangria Red SE
FF Reputation: 1 mdbgx2 Good Standing Member
so both of my rear window regulators broke within a day of each other and now the windows fall on their own (lots of fun in the rain i tell ya). The shop was going to charge me between $500 and $600 to fix them, so I went to South West Ford Parts's website and entered my VIN and they sent me an email with the parts I need. Now that my regulator assemblies have arrived, I was hoping someone would be able to give me a pretty good idea of what to do to replace them. My brother is going to be doing it, and he "knows" how, and from the little bit of instructions I've managed to find online it sounds pretty straightforward anyways, but I just want to double check. Can anyone help me out?
Thanks!
mdbgx2 is offline
Old 11-16-2006, 11:28 AM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
I'd check out either a Chiltons or Haynes repair manual. They're only about $15-20 bucks and typically have illustrations or pictures of procedures.
penguin is offline
Old 11-17-2006, 09:37 PM   #3
jimshady97
Fan#: 22856
What I Drive: 2005 gray zx4 st
FF Reputation: 1 jimshady97 Good Standing Member
you will need a 20 torque bit and 1/4 socket to remove the door panels.8mm socket to remove the regulator.the glass in held in the regulator with a plastic pin (wedge style) you wil need a punch to knock out the center of the plastic pin.remove the pin push the window all the way up and use tape to hold it up.remove the regulator transfer the motor if you have power windows.install the push pin in the glass first.install the regulator lower the glass so it just touches the regulator then push down hard and it will lock into place.hope this helps
jimshady97 is offline
Old 11-18-2006, 02:31 PM   #4
mdbgx2
Fan#: 41189
hey thanks a ton for that explanation, it really helped. now both windows are fixed =) hopefully they will stay that way
mdbgx2 is offline
