pin lay out for pcm - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-13-2006, 05:49 PM   #1
kylebal
kylebal's Avatar
Fan#: 27512
What I Drive: 2003 silver svt focus
FF Reputation: 1 kylebal Good Standing Member
pin lay out for pcm
does any one have the pcm pin lay out for the 2003 svt focus it would be a great help if any one could give me it thanks
svtjrsc(w/11 lb pulley it is the regular focus stock jrsc pulley), meth injection, 61lb injectors, tuned by myself,APR head studs,focus central 65mm bored throttle-body
kylebal is offline
Old 11-13-2006, 07:37 PM   #2
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
I had one... I'll see if I can find it.
Try doing a search on here and over at Focaljet... I know one of these sites has it posted as well.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 11-14-2006, 11:23 PM   #3
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,747, Level 78
Points: 14,747, Level: 78 Points: 14,747, Level: 78 Points: 14,747, Level: 78
Level Up 75% Completed
Forum Activity 11%
FF Reputation: 90 goinloco1 Excellent Standing Member
actually, i kinda combined several pinouts for the focus and have a complete pinout. the others were missing a few pins.... in still working on this, but bear with me. im waiting for a printout from the dealer to verify everything since diferent vehicles had different setups.
Focus ecu pinout http://teamfocus.mywowbb.com/forum32/5975.html
goinloco1 is offline
Old 11-16-2006, 01:27 PM   #4
finalley
Fan#: 386
What I Drive: 04SVTF, 03SVTF,08F150 4x4, 2013ST3
Points 1,311, Level 20
Points: 1,311, Level: 20 Points: 1,311, Level: 20 Points: 1,311, Level: 20
Level Up 11% Completed
FF Reputation: 5 finalley Good Standing Member
don't you guys want to sticky this kind of info somewhere here??
...Success or Failure is not an Event, It is a Process... 04SVT custom pressurized intake,@20lbs..340HP/338TQ, by Tom...
..............ridden Hard and put away Wet...
finalley is offline
Old 11-16-2006, 02:32 PM   #5
03OrangeSVT
LETS TURN DIRT!!!!
Fan#: 19169
This was posted by TFXO over at fj
Pin number function color
1 shift solenoid - B gn/bu
2 not used
3 IMRC module signal wh/rd
4 Transmission range sensor - reverse gn/bu
5 not used
6 not used
7 transmission range sensor - 1st / EVAP vent valve gn/wh - bk/og
8 transmission range sensor - 2nd gn/og
9 Barometric absolute pressure sensor wh/bk
10 not used
11 transmission range sensor - drive gn/bk
12 switched ground bk/wh
13 Flassh EEPROM power supply og/bk
14 not used
15 SCP - bu/bk
16 SCP + gy/og
17 switched ground bk/wh
18 not used
19 TX signal gy/og
20 Injector 3 control bk/bu
21 crankshaft position sensor + wh/rd
22 crankshaft position sensor - bn/rd
23 ground bk/ye
24 ground bk/ye
25 ground bk
26 switched ground CDA (coil 1-) bk/og
27 start inhibit relay circuit bk/rd
28 vehicle speed signal output wh/vt
29 overdrive cancel switch input gn/bk
30 not used
31 Power steering pressure sw input / press. sensor bk/yel / wht/vt
32 sensor return (refrence/ground) bn/ye
33 Output shaft speed sensor - bn/bu
34 turbine speed sensor + wh/vt
35 HO2S 2 signal wh/rd
36 MAF return bn/bu
37 transmission fluid temp + wh/gn
38 cylander head temp / coolent temp sensor wht/vt / wh
39 MAF input wh/vt
40 fuel pump monitor gn/bk
41 A/C clutch pressure cycling switch input gn/ye
42 PATS indicator control bk/og
43 sensor signal wh/bu
44 Pressure control solenoid A + gn/og
45 Camshaft timing actuator control bk/rd
46 Low fuel indicator bk/wh
47 electronic vacuum regulator solenoid valve control bk/gn
48 not used
49 CAN bus L bu/rd
50 CAN bus H gy/rd
51 ground bk/ye
52 switched ground CDB bk/gn
53 RX signal wh/gn
54 fuel pump output / switched ground bk/wh - bk/bu
55 hot at all times rd
56 EVAP purge valve control bk/bu
57 Knock sensor + wh/bk
58 VSS / OSS + wh/bu - wh/bu
59 generator monitor circuit gy
60 HO2S 1 signal wh
61 not used
62 fuel tank pressure transducer sensor signal wt/vt
63 fuel rail pressure transducer sensor signal wh/gn
64 transmission range sensor P/N / clutch switch grn/yel / wht
65 exhaust pressure transducer signal wh/bu
66 not used
67 EVAP canister vent control bk/og
68 switched ground bk/bu
69 switched ground bk/ye
70 injector 1 control bk/wh
71 power hold realy output (VPWR) gn/ye
72 generator communicator command lb
73 shift solenoid - A / check fuel cap light grn/yel / blk/wht
74 not used
75 gnd (power return) bk/wh
76 turbine speed sensor - / signal return / sig rtn bn - wh/vt - bn/wh
77 power ground bk/ye
78 not used
79 not used
80 IMRC control bk/wh
81 pressure control solenoid A- bk/rd
82 Shift solenoid C gn/bk
83 idle air control valve control grn/yel
84 not used
85 camshaft position sensor signal / sensor sig rtn wh/vt - bn/wh
86 sensor signal wh/rd
87 knock sensor - bn/ye
88 MAF output wh/bu
89 throttle position sensor signal wh
90 VREF ye
91 transmission fluid temp - bn
92 stop lamp switch input gn/rd
93 HO2S 1 control bk/ye
94 not used
95 injector 4 control bk/og
96 injector 2 control bk/ye
97 power hold realy output gn/ye
98 not used
99 shift solenoid D gn/og
100 HO2S 2 control bk/bu
101 not used
102 shift solenoid E gn/wh
103 ground bk/ye
104 not used
Well CRAP... I should have clicked the link first...
[/b]
Old 11-17-2006, 12:21 AM   #6
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
Forum Activity 11%
lol
i found the list on a kitcar site along with other info from other sources and updated it to note what all pins are. such as pin 48 and a couple others.
took alot of research time to find all the info. but ran into 1 problem... pins 95&96 for the injectors are listed as 100&101 on another list i found, otherwise they were the same. should have a pinout from a buddy at the dealership soon to verify everything for sure.
Old 12-27-2007, 12:56 PM   #7
my8950
Fan#: 28831
What I Drive: 04 SVTF XR4ti
FF Reputation: 1 my8950 Good Standing Member
Is this listing also for the SVT?
my8950 is offline
Old 12-27-2007, 12:59 PM   #8
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
What I Drive: 1991 BMW 318is
FF Reputation: 20 SVT_BMXer Great Standing Member
Buy-Sell-Trade Rating: (17)
That's what the OP was asking for, so yes.
02 Jackson Racing supercharged SVT
SOLD
Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler
SVT_BMXer is offline
