Cannot remove my break calipers - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-24-2006, 06:12 PM   #1
Jekster
Fan#: 36475
FF Reputation: 1 Jekster Good Standing Member
Hello,
So I went to change my break pads today. Jacked up the car, removed my tire, removed the caliper bolts and then when I attempted to remove the break caliper itself it wouldn't budge. It was almost like the break pad was constantly depressed on the rotor. People talk about being careful to watch the caliper falling off and hurting the break lines. However, I literally could not pull the darned thing off. Anyone ever have this happen or know why this might happen?
Thanks in advance!
Jekster is offline
Old 10-24-2006, 09:54 PM   #2
SVT_N_BLK
SVT_N_BLK's Avatar
Fan#: 22560
What I Drive: 2004 Black SVT_Rocket
FF Reputation: 1 SVT_N_BLK Good Standing Member
Sometimes there stuck on there. Try a rubber mallet and hold bottom of caliper and tap top of cal. up towards hood....or take a long pry bar and pry top of it off.
Also welcome to FF
Foglight Mod/Night Shade/2.5"Exhaust with ORP/2-15" subs/Calipers and grills painted
SVT Squad -=274=-
SVT_N_BLK is offline
Old 10-24-2006, 10:01 PM   #3
bananaboat
Fan#: 39414
What I Drive: Mazda 2 but still own the 2 Focis
FF Reputation: 1 bananaboat Good Standing Member
Have you decompressed the brake piston? I've got a large 6" C-clamp and short 2x4 that I've used to push the piston and let off the pressure. Be careful since decompressing too much can overflow your brake fluid reservoir. You might have to drain off some fluid.
I don't know about the Focus but on most vehicles, your caliper will be hanging by the brake line afterwards. A good reason to have a few feet of baling wire close at hand to hang the caliper once it's removed so you don't have all that weight on the brake line.
In the driveway...11 M2 (mine), 09 Focus (daughter), 02 Miata (my toy), 10 GMC SUV (spouse), 00 Focus (son)
bananaboat is offline
Old 10-24-2006, 11:59 PM   #4
Darth Focus
I miss my Turbo SVTF
Darth Focus's Avatar
Fan#: 6849
What I Drive: 1988 Mazda 323 GTX
FF Reputation: 1 Darth Focus Good Standing Member
Buy-Sell-Trade Rating: (8)
If its a rear caliper....check and make sure the e-brake isnt on. Thats what happened to me.
Russ Rudez
1988 Mazda 323 GTX; 1 of 1,243 Imported
AEM CAI, VJ11 Turbo @ 20psi, 2.5" IC Pipes,
Corksport IC, CFDF Clutch, 2.5" Turboback, Konis,
Suspension Tech Springs, 22mm Rear Sway, + More.
Darth Focus is offline
Old 10-27-2006, 12:20 AM   #5
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Odds are there's a thin strip of metal on the outer edge of the rotor that is hanging over the pad just enough to keep it from coming off. You just need to apply some brute force to the caliper to get the piston to back off just enough for you to slip the pad past the rotor.
SkaAddict is offline
Old 10-30-2006, 05:55 PM   #6
Jekster
Fan#: 36475
I'm guessing it's either stuck on like Ska said (and I just need to tap it with a mallet) or that I need to decompress the piston a bit. My only question is how do you access the piston without taking off the caliper? There isn't much room to get a C clamp in there let alone with a piece of 2x4. Can you describe this process a bit more?
Jekster is offline
Old 10-30-2006, 11:09 PM   #7
SkaAddict
Fan#: 1690
I don't think a mallet is necessary...when I pulled my stock calipers off, I just unbolted them and then just pushed and pulled on them until they loosened up enough to slide off the rotor.
Old 10-30-2006, 11:16 PM   #8
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
What I Drive: '03 CD Silver SVT, '11 Mazda CX-9
FF Reputation: 112 Peregrine Excellent Standing Member Peregrine Excellent Standing Member
Buy-Sell-Trade Rating: (23)
If you slide the caliper back and forth a little, it should clear the indentations on the rotor enough. But you won't be able to pull that caliper off without pulling those Torx bolts off first.
I found that the best thing for me to compress the pistons once the rotor is off is to use an old rollerblade wheel (not a deck wheel, it's too fat to fit in between the caliper!!!) Then I just use a pair of channel locks to compress the piston.
Peregrine is offline
Old 10-31-2006, 06:59 AM   #9
Jekster
Fan#: 36475
Ska:
So you never actually compress the piston until the caliper is off? That's where I was confused, I thought you said there was some way to compress the brake piston with the caliper still on the rotor.
As for sliding the caliper back and forth I'll give that a try. Last time I was putting some decent muscle into pushing outwards. Darn thing wouldn't budge though. Does it usually take quite a bit of power to pull off the caliper when it's having this problem? I've just always learned that power is very seldom the answer when doing anything. I don't want to risk breaking anything.
Thanks again for everyones help!
Jekster is offline
Old 10-31-2006, 12:31 PM   #10
SkaAddict
Fan#: 1690
If you push the caliper back and forth it will compress the piston, if only slightly, which will allow the pad to slip past the edge of the rotor. You don't need to worry about being gentle with the calipers (at least short of hitting them with a sledge hammer), they're made from cast iron and will hold up to just about anything aside from hitting them with a blunt object, which could shatter them.
