HRW intake mod testing results - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-28-2004, 01:16 PM   #1
HotRodWagon
CostraNostraTabasco
HotRodWagon's Avatar
Fan#: 145
What I Drive: 02 Infra ZTW
Points 16,463, Level 82
Points: 16,463, Level: 82 Points: 16,463, Level: 82 Points: 16,463, Level: 82
Level Up 23% Completed
FF Reputation: 25 HotRodWagon Great Standing Member
Buy-Sell-Trade Rating: (38)
I took intake air temp readings today. These are the results:
HRW Intake testing 03/28/2004
All measurements obtained with Auterra Dyno Scan software reading the ecu sensors through the OBDII port.
Ambient air temp 46. All testing done at highway speeds with absolutely no traffic. Car fully warmed, with coolant temp reading of 201 degrees.
Test#1 Stock intake system with ITG panel filter:
Speed 50mph 60mph 70mph 80mph
Temp 66 65 64 63
Test#2 Blocked snorkel, with ITG panel filter and HRW mod
* The is feeding the engine through the small resonator opening/cowl tube to resonator only.
Temp 65 63.5 61 57
Test#3 Stock snorkel with ITG panel filter, and HRW mod
Temp 63 61 59 57
Test#4 Modified grille cover (removed the portion of the grill cover on the backside of the large debris ridge), ITG panel filter, stock snorkel
Temp 48 48 48 48
Test #5 Modified grille cover, ITG, & HRW mod, stock snorkel
Temp 46 48 48 46
HotRodWagon is offline
Old 03-28-2004, 01:17 PM   #2
HotRodWagon
CostraNostraTabasco
Fan#: 145
Summary:
The grille cover mod made the largest difference. Temp drop averaged 12 degrees or so from 50 to 80mph. The HRW mod, dropped another 1 to 2 degrees from no HRW mod. Running the engine with the blocked snorkel/grille cover mod produced similar results, however airflow was noticeably insufficient.
Conclusion: the modified grille cover, stock snorkle, and HRW mod kept intake air temps within a degree or two of ambient air temp. This is a huge improvement over the stock system. It is apparent thegrille mod & HRW mod work. A better set up would be the grille mod, SVT snorkel, and an enlarged resonator opening of some sort. But considering the results of the last test #5, the better setup would probably not drop temps much more, but increase intake airflow. As a side note,
The HRW mod produces a distinct “whistle” under full throttle.
Considering the outside air temp was only 46 degrees, the full intake setup should result in much better power when air temps increase to 80 degrees.
Old 03-28-2004, 01:21 PM   #3
Vassili95
Fan#: 371
FF Reputation: 1 Vassili95 Good Standing Member
Very nice write up with full numbers to prove it....pretty impressive...can you post pictures of test #5 with the ful set-up??...........
Peace..................
Vassili95 is offline
Old 03-28-2004, 01:32 PM   #4
HotRodWagon
CostraNostraTabasco
Fan#: 145
sure...
Old 03-28-2004, 01:41 PM   #5
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
Nice work, HRW... forgive my ignorance, but what is the HRW mod exactly? Maybe the pictures will clarify.
Lil PZEV is offline
Old 03-28-2004, 01:47 PM   #6
HotRodWagon
CostraNostraTabasco
Fan#: 145
The HRW mod is the hose going from the resonator to the cowl.
Old 03-28-2004, 04:05 PM   #7
awebb
awebb's Avatar
Fan#: 259
What I Drive: 2003 ZX3 Sangria Red
FF Reputation: 1 awebb Good Standing Member
Pretty slick man...How long did it take you to rig that up?
~Mods~
Speed: AEM Short Ram Intake, Focus Central Race Header, Custom 2.25" Header-Back Exhaust.
Looks: Red Shorty Antenna, Superblue headlights.
awebb is offline
Old 03-28-2004, 04:17 PM   #8
HotRodWagon
CostraNostraTabasco
Fan#: 145
About 15 minutes
Old 03-28-2004, 04:51 PM   #9
SVT4ME
Fan#: 61
FF Reputation: 4 SVT4ME Good Standing Member
Me = stupid. I don't quite get how you modified the cowl/grille area?? Can you explain that? Interesting idea, I like it. Would one of the standard Zetec intake silencers fit into the SVT intake box in place of the SVT "short snorkel" - the box itself looks the same so I'm guessing the opening for the silencer is the same, too. Then we could make the mod too!
SVT4ME is offline
Old 03-28-2004, 05:33 PM   #10
HotRodWagon
CostraNostraTabasco
Fan#: 145
Take a look at the part of the grill cover right infront of the snorkel intake. I used a dremel to remove the portion after the large debris hump. This allows air fom the grille to flow to the snorkel. There is a Euro grille cover available from european-parts.net, but it requires the use of a Euro grille which has thinner mounting tabs. I believe the intake resonator is the same, so yes you could do this mod too. I used a hole saw to make both holes...the cowl where I drilled is just plastic.
Similar Threads
Basic Bolt Ons: Intakes And Induction focaltech ZETEC Performance (2000-2004) 108 08-01-2014 07:39 PM
So you want to buy an intake? mofocus ZETEC Performance (2000-2004) 270 03-05-2013 06:28 AM
Cold Air intake mod question Aaronsfocus DURATEC Performance (2003-2007) 5 08-09-2007 06:20 PM
The HRW intake mod HotRodWagon ZETEC Performance (2000-2004) 38 07-21-2005 08:53 PM
Intake mod question (Plz look) silverfoci ZETEC Performance (2000-2004) 6 04-12-2004 10:57 AM
