*The official F/I dyno thread* - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 01-24-2007, 02:52 AM   #11
Chick
Moderator
Chick's Avatar
Fan#: 151
What I Drive: '13 Taffeta White Civic Si Sedan
Points 185,708, Level 100
Points: 185,708, Level: 100 Points: 185,708, Level: 100 Points: 185,708, Level: 100
Level Up 0% Completed
Forum Activity 5%
FF Reputation: 133 Chick Excellent Standing Member Chick Excellent Standing Member
Buy-Sell-Trade Rating: (37)
Member name: Pitch Black216
Engine: Zetec
Transmission: Manual
Method of FI: Turbo
Modifications: Turbonetics T3/T4 CBB Turbo, Focus-Power Mani/Down Pipe
Custom Blow Through IC Piping, Greddy Type S BOV, CGI WRC Block w/ Oil Squirters, Diamond 9:1 Compression Pistons, Crower Connecting Rods, Focus-Power Main Caps, ARP Bolts On Everything, Custom P&P Head, McNews Turbo Grind Cams, Ford Racing Valve Springs, Focus Central Cam Gears, Focus Central 3-Peace UDP, Focus Central TB, 3” Exhaust, Diablo MAFia, Diablo Sport Chip, 72lbs Injectors, VF Engineering Rear Mount, Clutch Master Stage 4 Clutch, Focus Sport Flywheel, Quaife LSD
279 WHP 270 WTQ
February 2005 ROTM
Chick is offline
    Quick reply to this message
Old 03-20-2007, 01:23 AM   #12
Chick
Moderator
Chick's Avatar
Fan#: 151
Forum Activity 5%
Member name: EnixIV
Engine: Duratec 2.3 (2003)
Transmission: Automatic
Method of FI: Turbo
Modifications: FocusSport Stage 2 Turbo kit@9.5 PSI/BS Delete/2.5" SS TrubendZ w/Hi-Flo Cat
217 WHP 213 WTQ
February 2005 ROTM
Chick is offline
Old 04-26-2007, 01:45 AM   #13
Chick
Moderator
Chick's Avatar
Fan#: 151
Forum Activity 5%
Member name: tls_bmx
Engine: Zetec
Method of FI: Turbo
Modfications: Roush Turbo Kit, converted to blowthrough and is using a type rs bov, 3" down pipe and exhaust, a 65mm tb, and tuned by Tom at Focus-Power @ 11.5psi.
219 WHP 213 WTQ
February 2005 ROTM
Chick is offline
Old 04-26-2007, 01:54 AM   #14
Chick
Moderator
Chick's Avatar
Fan#: 151
Forum Activity 5%
Member name: Jason2o
Engine: SVT Zetec
Year: 2002
Method of FI: Supercharger
Modifications: Jackson Racing Supercharger BBK, Fidanza, K&N Air Filter, 67mm TB, Borla CatBack w/CFM HighFlow Cat & Royal purple oil in everything.
Tune: Stock Ford Racing
215 WHP 169 WTQ
February 2005 ROTM
Chick is offline
Old 07-09-2007, 01:30 AM   #15
Chick
Moderator
Chick's Avatar
Fan#: 151
Forum Activity 5%
Member name: focuzed1
Engine: Zetec
Year: 2002
Method of FI: Turbo
Modifications: Garrette t3/t04e 50trim .63 a/r housing stg 3 compressor wheel, greddy ic, fc 65mm tb, wrc block (mannley rods, diamond pistons, billet main caps), diablo chip, diablo mafia, trubends 3in stainless steel mandrel bent exhaust, nuiken equal lenth turbo mani and 3in down pipe, cam gears, fidanza flywheel, clutch master stg 3 clutch (might be slippin not sure yet), quaife diff, greddy boost controller, turbonetics waste gate, greddy bov, 71lb injectors, steeda fuel rail, fuel return setup, modified factory pump, head and cams.
358 WHP 380 WTQ
February 2005 ROTM
Chick is offline
Old 07-22-2007, 10:14 AM   #16
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
Member name: FRRIBTR_Foci
Year: 2000 (ZTS)
Modifications: MagnaFlow Exhaust, JBA Header, HD Torque Conv, ACT Performance Clutches, Recalibrated Valve Body w/23 Spline Shaft, Eibach PRO Plus w/SB, SSBC Force-10 12" Brakes, Corbeau 4-point harnesses, 18" Panther RPMs wrapped in Toyo T1Ss, FS Front Strut Bar, Short Ram AI, 65mm TB, PWSC...
196 WHP 185 WTQ
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 10-14-2007, 11:05 PM   #17
Chick
Moderator
Chick's Avatar
Fan#: 151
Forum Activity 5%
Member name: jrpasmo
Year: 2002
Engine: SVT Zetec
Modifications: ATI Procharger SC , 8 PSI, 60lb injectors, MAFia, Tune done via email by Tom
236 WHP 190 WTQ
February 2005 ROTM
Chick is offline
Old 12-20-2007, 01:58 AM   #18
Chick
Moderator
Chick's Avatar
Fan#: 151
Forum Activity 5%
Member name: whetman
Year: 2000
Engine: Zetec
Method of FI: Turbo
Modifications: Roush turbo kit, probe pistons (9to1), Eagle Rods, Ford Racing Head, Crower stg 1 cams, Mafia, 2003 fuel pump, 3 inch exhaust downpipe back, 65mm throttle body, greddy type-s boost controller.
7 lbs of boost, stock Roush tune
150 WHP 167 WTQ
17lbs of boost, custom tune, still on roush injectors
248 WHP 276 WTQ
February 2005 ROTM
Chick is offline
Old 03-19-2008, 09:06 PM   #19
Chick
Moderator
Chick's Avatar
Fan#: 151
Forum Activity 5%
Member name: nitetimebolher
Year: 2004
Engine: Duratec (2.3)
Method of FI: Turbo
Modifications: Focussport Stage 2 turbo kit @ 11.5 PSI, Trubendz 2.5" exhaust, BS Delete
252 WHP 235 WTQ
February 2005 ROTM
Chick is offline
Old 04-02-2008, 04:32 PM   #20
Chick
Moderator
Chick's Avatar
Fan#: 151
Forum Activity 5%
Year: 2003
Engine: Zetec
Method of FI: Turbo
Modifications: P.O.S. T3/TO4E 50 trim .63 ar turbo, roush manifold, open wastegate, converted to blow through w/ 3" maf & mafia, greddy bov, 2k IM, 65mm tb, eagle rods, je pistons, FP main caps, SVT block, custom FP head, mcnews turbo cams, esslinger adj cam gears, full return fuel system, 3" exhaust, dyno tune by Focus-Power... more to come.
353 WHP 313 WTQ
February 2005 ROTM
Chick is offline
Closed Thread
