Status
Not open for further replies.
*The official ZETEC dyno thread*
36K views 11 replies 2 participants last post by  iminhell
#1 ·
Ever want to know how much power that intake will get you? How much power you are making stock? This thread is just for that. This is for ZETEC equipped Focus's ONLY. Please send us your dyno's (stock or modified) so that we can post them up in this thread. This thread will be stickied and locked so that you will have to PM any SENIOR Moderator (or a FFR Moderator if they are assigned to this part of the forum).
THIS IS FOR N/A ZETEC'S ONLY. NO F/I PLEASE. THANKS
Please include in your PM:
* Picture of dyno
* Manual or automatic
* Modifications (if any)
* Year of car
Remember, you can send us stock dyno's as well. A lot of people like to know what they are starting out with before they modify[thumb]
-Focusfanatics.com MODERATOR TEAM
Save
#2 ·
Member name: CELT44
Year: 2003 (ZTW)
Transmission: Automatic
Modifications: SVT Borla, RT Hi-Flo cat, SVT long tube header.
113 WHP 115 WTQ
Save
#3 ·
Member name: osiris_vdc
Year: 2003 (ZX5)
Modifications: Stock
Modifications: Volant Intake, SVT Header, Random Technology Hi-Flo Cat, Borla SVT Catback, Focus Central 65mm Throttle Body, AFX Underdrive Pully, Fully Ported 2000 Intake Manifold, Esslinger Tuneable Cam Gears Dyno Tuned, Ford Racing Stage 2 Cams, FS/SCT Dyno Tuned. Focus Sport 8mm Spark Plug Wires, Motorcraft Copper Spark Plugs, VF Lower Motor Mount, Royal Purple 5W-20 Motor Oil, Royal Purple ATX Fluid, Royal Purple Water Wetter, and 180° Thermostat.
126 WHP 125 WTQ
Save
#4 ·
Member name: hEaT
Year: 2001
Transmission: Manual
Modifications: Volant Intake and SVT Borla Exhaust
113 WHP 122 WTQ
  • Like
Reactions: teddyrob
Save
#5 ·
Member name: NikiterZTS
Year: 2002
Modifications: Volant with Cold Air setup, FC 65mm TB, Ported early 2000 intake manifold, SVT snorkel, OBX 4-2-1 header, 2.25" Truebenz flex pipe, MBRP catback, FC UDP kit, MAC rear engine mount, APC 9.3mm wires, Platinum sparks
125 WHP 129 WTQ
Save
#6 ·
Member name: BigRed03
Year: 2003
Modifications: FocusSport CoolFlo SRI, RT high flow cat, 2.25" flex, Magnaflow 2.25" catback, Steeda 8mm Racing wires.
118 WHP 125 WTQ
Save
#7 ·
Member name: Zx3'dUrSvt
Year: 2001
Modifications: new shortblock, FRPP head, Crower II's, Crower valvetrain, VF rear & passenger mount, MSD coil & wires, FC UDP, FC T.B., Ported 2k mani, Fidanza flywheel, centerforce clutch, high flow fuel rail, 24lb injectors, svt fuel pump, CAI, grounding kit, 180 thermostat, 4-2-1 header, FS flex, 2.25 cat-back, denso iridium plugs, oil separator, xcal2 tuned by McNews, EGR delete
160 WHP 140 WTQ
Save
#8 ·
Member name: Kfokus
Year: 2001
Modifications: crane stg 2 cams, aem cam gears,K+N intake,4-1 long tube race header,2.25 flex,2.25 obx exhaust,FS UDP,65mmTB,Sct excal2,MSD wires.
134 WHP 137 WTQ
Save
#9 ·
Member name: sleepyboy
Year: 2001
Modifications: Cone Filter stock MAF and tube, Ported TB, OBX long tube header wrapped in header wrap, Magnaflow custom exhaust, SD coil, Mac adjustable cam gears dyno tuned of course, Unorthodox UDP, Center Force dual friction clutch w/ stock flywheel.
119 WHP 124 WTQ
Save
#10 ·
Member name: dimorf26
Year: 2001
Modifications: SCT Xcalibrator 3 Flash Tuner, AEM Cold Air Intake, Steeda 65mm Throttle Body, SVT Exhaust Conversion Kit, Ford Racing SVT Conversion Long Tube Race Header, Ford Racing High Flow Cat Pipe, SVT Flex Pipe, Borla 2.5" SVT Performance Exhaust, Steeda Water and Crank Underdrive Pulleys, Steeda High Flow Fuel Rail, Bosch 30lb Fuel Injectors, Live Wires 10mm Plug Wires, Screamin' Deamon Coil Pack, Autolite Double Platinum Spark Plugs.
127 WHP 132 WTQ
Save
#11 · (Edited)
Member name: iminhell (John)
Year: 2001
Modifications: SVT intake manifold swap (no DSI), Esslinger adjustable cam gears, Focus Central underdrives (crank and alternator only), Focus Central 4-2-1 header, Magnaflow exhaust with high flow cat, 180* thermostat, removed A/C, PRO-M 70mm Mass Air Meter, Diablo Sport chip, cheap cone filter, 1 step colder Autolite platinums
134WHP 126WTQ
Status
You have insufficient privileges to reply here.
