Drag strip times stock 2006 zx5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 10-08-2006, 01:56 PM   #1
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,866, Level 74
Points: 12,866, Level: 74 Points: 12,866, Level: 74 Points: 12,866, Level: 74
Level Up 4% Completed
Forum Activity 4%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Ran at Pittsburgh Raceway Park yesterday.
Definitely not my first time at the track but first time with this car.
Full weight (plus some junk in the back), 1/4 tank gas, stock tires full psi.
I do have a poly trans mount and a shortened stock shifter with a mustang shift knob.
Track elevation is 1250'. Temperature was around 60*F.
60' 2.491
1/8 10.485 @ 66.32
1/4 16.351 @ 84.32
I shifted around 6500 and powershifted every gear.
I rode out 3rd but feel I should have shifted into 4th (did on the 2nd run).
The clutch didn't like a 6500rpm powershift on the 1-2.
I could feel it slip, but never did smell it burning.
I got a bit of wheel hop the first run but not enough to lift.
Second (and last) run was after the slick cars ran and got the track very sticky.
I got some violent wheel hop and had to lift for a 16.5 sec run.
What advice do you all have for eliminating wheel hop, other than riding the clutch and creeping out of the hole?
What rpm do you duratech guys usually shift at?
I'm not at all disappointed with that time, given there's room for improvement on the 60' time and possible shift point tweaks.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 10-08-2006, 02:19 PM   #2
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
What I Drive: 2012 Sonic Blue SE Sport 5 Spd
Points 18,754, Level 86
Points: 18,754, Level: 86 Points: 18,754, Level: 86 Points: 18,754, Level: 86
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 67%
Activity: 67% Activity: 67% Activity: 67%
FF Reputation: 43 Duffman355 Great Standing Member
not bad times btw. Slipping the clutch might help wheel hop, and I have the 2.3 duratec but I shift just past 6000 rpms(probably not evn 6100).
ST Crew #11 / SSR #5
Official Mayo Hater #1
Randomie's Lover #8
Duffman355 is offline
Old 10-08-2006, 02:49 PM   #3
nomoreavril
Fan#: 31008
What I Drive: 06 Chevy Cobalt LS 5speed
FF Reputation: 1 nomoreavril Good Standing Member
what exactly is slipping the clutch vs. dumping the clutch..i never found out what those terms meant
06 Ultra Silver Cobalt LS 5 Speed
PERFORMANCE: -Custom 2.5 SS/Magnaflow Catback -Pacesetter Race Header -GM CAI
EXTERIOR: -Razzi body kit
*FOR SALE*NEEDS TO GO: FS DURATEC STRUT BAR 50$ -ZX3/ZX5 SIDE SKIRTS PM ME!!
nomoreavril is offline
Old 10-08-2006, 03:05 PM   #4
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
Forum Activity 67%
dumping is when you say have the engine revving 3000 rpms say and you let it complety out in one fast moition, where slipping you slowly let out the clutch or feather it basically. SLipping on our cars is a better launch method, but is detremental to the clutch.
Randomie's Lover #8
Old 10-08-2006, 11:17 PM   #5
MightyMouse
Scuba Edition
MightyMouse's Avatar
Fan#: 34537
What I Drive: 2006 Liquid Gray ST (Scuba Edition)
Points 3,508, Level 37
Points: 3,508, Level: 37 Points: 3,508, Level: 37 Points: 3,508, Level: 37
Level Up 6% Completed
FF Reputation: 20 MightyMouse Great Standing Member
Re: Drag strip times stock 2006 zx5
[/B]
Slipping the clutch is your best bet to eliminate the wheel hop/spinning through first.
I shift at 6500 rpms.
ST Crew #32
FocusFest 2008 and 2009 Fastest NA, 2009 Fastest FI Runner-Up, and 2008 Bracket Winner
MightyMouse is offline
Old 10-15-2006, 01:01 AM   #6
firemanfrank
firemanfrank's Avatar
Fan#: 5254
What I Drive: n/a
FF Reputation: 1 firemanfrank Good Standing Member
Re: Re: Drag strip times stock 2006 zx5
6500 rpm's?
I shift at 6,000 rpm, because I thought our ST's didn't make power much past 5700 rpms.
"Hypocrisy is the greatest evil of our time." -St. Padre Pio
firemanfrank is offline
Old 10-15-2006, 01:25 AM   #7
mlowery
mlowery's Avatar
Fan#: 14715
What I Drive: flame blue metallic 2010 focus se
FF Reputation: 5 mlowery Good Standing Member
yeah, i saw you run, pretty good times BTW.......i say you need to start working on the performance of that thing now that way i am not the only focus in fairmont that is modified.
mlowery is offline
Old 10-15-2006, 01:30 AM   #8
MightyMouse
Scuba Edition
Fan#: 34537
Re: Re: Re: Drag strip times stock 2006 zx5
Originally posted by firemanfrank
6500 rpm's?
They do peak at about 5700 rpms but the thing is you are making a less power at 6500 than 6000 but once you shift you'll be making more power if you shifted at 6500 than 6000. Does that make sense?
ST Crew #32
Old 10-15-2006, 02:41 AM   #9
firemanfrank
Fan#: 5254
What I Drive: n/a
Re: Re: Re: Re: Drag strip times stock 2006 zx5
Ok, I think I know what you're saying.
If we shift at a higher rpm, then the next gear you catch is gonna be at a higher rpm, thus putting you into the meatier part of the engine's powerband.
Right?
So if we take that info and apply it in an example of the 1/2 shift:
1st gear @ 6500 rpm = 35.1mph
35.1 mph for 2nd gear puts us at 3990 rpm
Now if we shifted at only 6000 rpm:
1st gear @ 6000 rpm = 32.4mph
32.4 mph for 2nd gear puts us at 3680 rpm
So by shifting at 6500 rpm, we go up 300 rpms further into the engine's powerband at the next shift.
Now (going by zx3chick's stock dyno sheet below), if we shifted out of 1st at 6000 rpms, we would be in 2nd gear at roughly 3700 rpms making 87hp.
But if we shifted out of 1st at 6500 rpms, that would put us into 2nd gear at about 4000 rpms making 102 hp.
So what we should ask ourselves then, is how much hp do we "lose" when prolonging the shift to 6500 rpms versus 6000 rpms?
Well, at 6000 rpms we're making about 127hp, versus about 117hp at 6500 rpms. So we lose 10 hp in extending the upshift.
But, we gain 15hp by being higher up in the engine's powerband in the next gear.
So all in all, we're a little ahead of the game by shifting at a higher rpm.
Right?
Man, I've got a headache ....
Old 10-15-2006, 02:43 AM   #10
MightyMouse
Scuba Edition
Fan#: 34537
Yep. I tell everyone that and your like the first one who actually understands it.
EDIT:
Your numbers are a little off as well.
The shifts are 6500-4064 and 6000-3750.
6500 is 124.61
6000 is 129.71
4064 is 102.66
3750 is 93.03.
6500-6000 is -5.1hp
4064-3750 is 9.63hp.
Which gives you a difference of 4.53hp.
So you were close on the difference.
ST Crew #32
