car stalls with heater/AC fan on - Ford Focus Forum, Ford Focus ST Forum
Old 01-24-2011, 11:25 PM   #1
Lorijohn
Fan#: 82788
What I Drive: 2004 Silver 2.0L SPI
FF Reputation: 1 Lorijohn Good Standing Member
A few days ago my 2004 2.0L SPI Focus started running very rough and stalling whenever I would turn the heater/AC fan on...with AC on or off. Runs fine w/o fan on. I've seen many posts regarding problems with the AC and engine performance, but this one seems to occur even when the AC is off. Any help is appreciated.
Thanks,
john
Lorijohn is offline
Old 01-25-2011, 01:27 AM   #2
"Elder"
Points 9,766, Level 66
Points: 9,766, Level: 66 Points: 9,766, Level: 66 Points: 9,766, Level: 66
Level Up 29% Completed
FF Reputation: 70 sailor Excellent Standing Member
Posted via FF MobileA/C is on automatically in most heater positions (anything that includes defrost) even if the light doesn`t come on... That is just a switch position indicator..... Sounds like IAC issues Didle air control) as that is supposed to raise the idle for A/C use, cold starts, high charging load etc.. If you hit the fan switch O it stalls at idle, the idle rpm adjustment isn`t working.....
sailor is offline
Old 01-25-2011, 06:46 AM   #3
Lorijohn
Fan#: 82788
I was thinking it wasn't the IAC because this model has a separate pushbutton and indicator light on the dash for A/C. I assumed the compressor was not on unless the indicator light is lit, but haven't looked to see if it was turning. Is that not the case? The car also surges then stalls even if I rev the engine.
Lorijohn is offline
Old 01-25-2011, 07:36 AM   #4
Points 27,103, Level 97
Points: 27,103, Level: 97 Points: 27,103, Level: 97 Points: 27,103, Level: 97
Level Up 76% Completed
You're confusing the Idle Air Control (IAC) with the Air Conditioning (AC). The idle air control is what makes the idle go up when the air conditioning turns the compressor on. Now the AC compressor will run whether the button is pushed in or not, when the vent selector is in either the DEF/FLOOR, or DEF position. The AC light will not light up, but the AC compressor will be turning. This is to dry out the air blowing over the windshield.
Will the engine remain idling when the AC is switched on in any other vent selection?
Old 01-25-2011, 11:47 AM   #5
Lorijohn
Fan#: 82788
The engine fails no matter what setting the AC selector is on. Even on heater.
Lorijohn is offline
Old 01-25-2011, 10:09 PM   #6
Lorijohn
Fan#: 82788
input from whynotthinkwhynot to check ground wires was the solution. Corroded wire found, repaured and now working.
Thanks.
Lorijohn is offline
Old 01-26-2011, 07:34 AM   #7
I think there must be some problem with your ground to chassis connections so that when you turn the blower on, the resulting current lowers the voltage enough that the coil no longer works. I have seen one SVT where all the grounds had become disconnected except the ground connection to the cylinder head- and it was partially burnt through.
I'd check the connections to the negative battery terminal first. There should be at least 2 chassis ground connections (small wires) connected to the negative terminal as well as the large ground that bolts between the neg terminal and the engine. Trace that one down and make sure it is still connected. Then check to be sure there is a ground connection to the back of the cylinder head, or the passenger side motor mount.
Once you check all that out, look in the owner's manual to find the fuse location and size for the blower motor. Find the fuse, make sure it is the correct size.
That's my hypothesis. I thought I wrote it in here a few days ago, and now it's not there.
Old 03-07-2013, 03:43 PM   #8
pisces1974
Fan#: 111015
What I Drive: 2002, Silver, ZX3
FF Reputation: 1 pisces1974 Good Standing Member
2002 ZX3 Stalls at idle when heater is on
I have a 2002 ZX3, and at an idle it stalls if the heater is on. When the heater is off it is fine. Also if I make many stops (where I turn the car off) in a short period of time the car will not stay running unless I have my foot on the gas, but if i let it sit for an hour it is fine again. I need to know what is wrong with the car, and if the problems are related.
Thank You,
Christina
pisces1974 is offline
Old 03-07-2013, 05:43 PM   #9
Lorijohn
Fan#: 82788
Sounds a lot like what what happening to my 2004. I found a bad ground wire at the battery; fixed it, and that solved the whole problem. Good luck.
Lorijohn is offline
Old 03-07-2013, 06:26 PM   #10
pisces1974
Fan#: 111015
Thank you I will try that
