Lowered tire wear issue - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-18-2013, 10:37 PM   #21
BeepBeep2
Fan#: 119597
What I Drive: 2012 Sterling Grey SEL Sedan
Points 178, Level 3
Points: 178, Level: 3 Points: 178, Level: 3 Points: 178, Level: 3
Level Up 56% Completed
FF Reputation: 2 BeepBeep2 Good Standing Member
Originally Posted by wrc_fan View Post
Incorrect toe settings are pretty much a killer of tires on the focus, especially in the rear. Factory rear camber is not adjustable, and most cars have a bit much, combine this with bad toe and techs that are too lazy to adjust it, you get bad tire wear. Also note that the suspension design changes the toe dynamically as the suspension functions.
In the front on the focus, it's pretty much impossible to get too much front camber:)
Are you assuming this to be the same for all Foci or are you talking specifically of the MKIII?
Ironically my left front tire is showing extra wear, but my alignment has been a bit off for 4000 miles. I think the front end toe is positive.
BeepBeep2 is offline
Old 10-19-2013, 09:32 AM   #22
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
That could go for all years.
I'd have your tires rotated & a 4 wheel alignment & of course check your air pressure too.
felixthecat is offline
Old 10-19-2013, 09:48 AM   #23
anarchy0392
Fan#: 102873
What I Drive: 2002, Silver, SE
Points 1,634, Level 23
Points: 1,634, Level: 23 Points: 1,634, Level: 23 Points: 1,634, Level: 23
Level Up 34% Completed
FF Reputation: 2 anarchy0392 Good Standing Member
Buy-Sell-Trade Rating: (9)
Camber and toe are wear angles, and caster is not. If you get ajustable camber arms that might fix it if you fand a tech who isnt so lazy to put in factory spec of 0.28 of a degree. But if you want a cornering set up you can go to as much as -1.5 but I wouldnt go past -1.0 if you DD this car.
When you change camber, toe changes at the same time. So if you get camber arms your toe should be in spec or close enough to it till you can get the toe arms, and be good enough to stop the crazy amount of wear on your tires.
anarchy0392 is offline
Old 10-21-2013, 11:17 AM   #24
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
On my MkI I have never had to consider toe arms due to to them not being able to get back in spec in the rear. They still use the same style control blade rear in the MKIII so I would be willing to bet he won't need those still. He needs to find an alignment shop that will take the time to zero out your toe. As stated above it is a primary killer of tires on the focus.
The MKIII and MKI share many similarities in suspension design over the years with minor updates and changes.
I always moderate naked!
bringler26 is offline
