Old 02-26-2013, 12:54 AM   #31
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
FF Reputation: 2 150mphzetec Good Standing Member
Originally Posted by finalfantasy View Post
Oh you must mean the $cheaper cover w ribbs. I think it was also used in the contour. It looked as if the screw holes were spaced differently though, like a different shape that wouldn't mate to the zetec housing.
Wondering now if I'm going to regret later not getting a new RH122 cover instead of using the old one. Think it will leak/explode from that pic?
you are confused. The "cheaper" housing with the ribs is the better one. The screw holes don't line up with the original version because they have two different bolt patterns on the water neck. The water neck from the contour should be the one used because it is made of the same material as the thermostat housing. The bolt pattern for the head is the same
if you did not get the contour version, you will regret it when you realize that you could have saved yourself the hassle of having to replace it again soon.
150mphzetec is offline
Old 02-26-2013, 08:28 AM   #32
finalfantasy
Fan#: 86774
What I Drive: 2001 SE
FF Reputation: 1 finalfantasy Good Standing Member
Ok and by cheaper I did not mean in anyway it was inferior. For some reason it is half as expensive as the Zetec housing cover. 8592 (RH81) is the contour housing? Are most fanatics replacing with that?
Would I regret the ribbed leaking problem?
finalfantasy is offline
Old 02-26-2013, 11:13 PM   #33
FF Reputation: 15 amc49 Great Standing Member
A long shot to do so, the major housings cause more trouble. May go to small leak later though.
amc49 is offline
Old 03-12-2013, 11:35 PM   #34
finalfantasy
Fan#: 86774
just got a thermostat housing, cover, t-stat and waterpump. All "motorcraft" parts. The housing cover has a slighly raised edge seam around the surface where it should meet the t-stat oring.
The housing is kinda dusty and also has some raised plastic edges near the mold seams.
The t-stat bleed/check valve ball is rattling a lot more than the one I held in my hand at the dealership.
Are the quality control guys in dearborn mi sweeping the floor stuff amazons way? Ill post some pics later.
Old 03-13-2013, 05:35 PM   #35
I always do whatever it takes to remove that little ball valve or poppet to leave simply a hole. The valve has a tendency to corrode shut and then you lose the bleeding that occurs every time motor starts up. The engine never sees that small hole when running, silly to have the valve in there. I actually drill a 1/16" hole in every stat I put in a car that does not have one. It needs to face straight up at 12 o'clock.
amc49 is offline
Old 03-13-2013, 07:17 PM   #36
finalfantasy
Fan#: 86774
interesting. thank you for that comment. I have read about this on jeepforum as well.
Old 03-15-2013, 01:36 AM   #37
finalfantasy
Fan#: 86774
Do you think I should return the thermostat cover, it's got all these burrs around the mating surface to oring?
