cfm tubular control arms install - Page 3 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 04-30-2013, 10:04 PM   #21
Blackhatch01
Blackhatch01's Avatar
Fan#: 67285
What I Drive: 2001 Black ZX3
FF Reputation: 1 Blackhatch01 Good Standing Member
I did not get a new inner sleeve. Looks like I have to call cfm in the morning
HATCH NATION #119
Blackhatch01 is offline
Old 05-01-2013, 01:22 PM   #22
Blackhatch01
Fan#: 67285
Cfm sent me an email of the same instructions. So in order to seperate the inner and outter housing. I have to burn out the bushing and cut the inner sleeve off? Am I correct?
HATCH NATION #119
Old 05-01-2013, 04:43 PM   #23
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 11,473, Level 70
Points: 11,473, Level: 70 Points: 11,473, Level: 70 Points: 11,473, Level: 70
Level Up 56% Completed
FF Reputation: 62 felixthecat Excellent Standing Member
The bushing goes between the arm & the shell housing which bolts up to the sub frame cradle w/ 2 bolts per side. Grab the stock arm & pull arm out of the bushing/sleeve combo & then press out the rubber bushing out of the shell. I found it easier to install the bushing w/ a press into the shell & then the leg of the arm goes into that.
felixthecat is offline
Old 05-01-2013, 05:43 PM   #24
Blackhatch01
Fan#: 67285
So i need to keep the sleeve?
HATCH NATION #119
Old 05-01-2013, 06:17 PM   #25
felixthecat
w/ my magic bag
Fan#: 80663
Yup, as that bolts up to the cradle for the rear leg of the arm. Looking at the arm= the rear leg of the arm gets bolted up to the cradle w/ the sleeve & the poly bushing goes between the arm/leg & sleeve.
Old 05-01-2013, 10:01 PM   #26
Blackhatch01
Fan#: 67285
I got one bushing out, went the torch route. Its gonna be a tight squeeze into the sleeve. Thanks for the help Felix
HATCH NATION #119
Old 05-01-2013, 10:09 PM   #27
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,112, Level 40
Points: 4,112, Level: 40 Points: 4,112, Level: 40 Points: 4,112, Level: 40
Level Up 81% Completed
Forum Activity 9%
Buy-Sell-Trade Rating: (17)
You guys are talking bout the inner sleeve right?
I now drive a Japanese Ford.
macdiesel is offline
Old 05-02-2013, 06:53 PM   #28
felixthecat
w/ my magic bag
Fan#: 80663
The sleeve or the housing/bracket for the rear of the control arm. For that the bushing fits over the leg of the control arm & the housing/bracket fits over the bushing & gets bolted down w/ two nuts & bolts. I use the box end of the wrench to hold the nuts & rattle the bolts on. I beleive the torque is 80lbs for the 2 rear bolts & the front bolt, that goes to the front part of the control arm.
Old 05-02-2013, 07:36 PM   #29
Blackhatch01
Fan#: 67285
Not sure why but every shop couldn't get the bushings in. I'm not sure if the 05 and up use a different size bushing. It took some thinking, I decided to cut one line all the way down the sleeve. This gave me a gap to put a screw driver in and spread the sleeve. With some grease I was able to push it in by hand. It worked out perfectly, its not going to come back out with out a press. Since the bracket clamps the sleeve into place it should close the gap
HATCH NATION #119
Old 11-07-2014, 06:28 PM   #30
daspazzZX3
D0th as th0u will
daspazzZX3's Avatar
Fan#: 133961
What I Drive: 02 ZX3 chcl gry - Dakota-PatE02 5sp
Points 3,692, Level 38
Points: 3,692, Level: 38 Points: 3,692, Level: 38 Points: 3,692, Level: 38
Level Up 28% Completed
Forum Activity 100%
FF Reputation: 2 daspazzZX3 Good Standing Member
anyone have a PDF copy of the instructions? I never got them, my arms came second hand! #
Focus Danielshan!! - Charcoal grey 02 Dakota-PatE02 Tune By Tom!
Luv ya Son, R.I.P. Pat - rollin TRILLl!
DP gawtZ Bawlz!!!!! HN #68 + 1 someday #Only2f00kzGiven
daspazzZX3 is online now
