Im about to shave a head for circle track - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > ZETEC Performance (2000-2004)
Old 07-23-2013, 03:51 PM   #11
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
I meant thats where the valve hits piston with the valve closed.
04 ZX3 Mostly Stock [3/13 ROTM]["Best Non-SVT" FITF '12][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 07-24-2013, 02:03 AM   #12
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
FF Reputation: 1 GhostTribute Good Standing Member
If belt length is an issue you could try a shorter belt from another vehicle.
You can figure out a belt length with the following information
Belt Pitch =
Small Pulley (crank) Tooth count =
Large Pulley (cam) Tooth count =
Pulley Centers =
Belt pitch = Center to center measurement between the teeth.
Pulley centers = the center to center measurement between the center of the crank pulley and center of the cam pulleys.
Piston to valve contact would be a bigger concern. What compression do you want to achieve?
Just taking 0.02" should net you approx 10:1. If you take 0.02" off the head and the block both for a total 0.04" and you would hit a static CR of 10.5:1. My math could be of a little bit.
GhostTribute is online now
Old 07-24-2013, 06:25 AM   #13
disciplerocks
Fan#: 59330
Pretty sure you need to have the stock tooth count to keep it in time.
Old 07-24-2013, 11:19 AM   #14
GhostTribute
Fan#: 107929
It's all based on ratios..... if you change the distance between your pulleys you remove/add a tooth or two to keep the proper ratio. Tooth pitch is what remains consistent when changing the distance between the pulleys.
That being said you would have to remove 0.25" - 0.375" in belt length in order to require a tooth count change. Depending on tooth pitch.....
I just went through all this on a SOHC VTEC head swap on an Accord. SOHC Non VTEC used a 113 tooth count, while the shorter cam height VTEC head required a 112 tooth count belt. They use the exact same tooth count cam and crank pulleys. Only difference is the center to center measurement of the two gears. The VTEC blt was 0.375" shorter and therefore they removed a tooth, due to the tooth pitch being 0.375. If they didn't shorten the blt by a tooth the belt wouldn't tension properly.
Old 07-27-2013, 02:54 PM   #15
Belt tooth count means nothing, belt just speeds up or slows down, maybe it doesn't repeat teeth anymore like it did before. You're translating two teeth at crank for every one tooth at cam. Only thing you could do there was add or subtract a single belt tooth. Past that you're out of the ballpark. Belt only carries the motion in exact amounts, meaning individual tooth spacing not number of teeth. Actual ratio is the difference in upper and lower pulley sizes. You can use 70 inch or 70 foot belt and same ratio there.
'It's all based on ratios..... if you change the distance between your pulleys you remove/add a tooth or two to keep the proper RATIO. Tooth pitch is what remains consistent when changing the distance between the pulleys.'
Nope, distance, not ratio. Caps mine.
'I meant thats where the valve hits piston with the valve closed.'
Momma, that's close. However, the valves still in essence move sideways as they get closer to piston, either closed or open. They have to since they are not straight up and parallel to the cut effect, or dead straight up and down.
amc49 is offline
