2008-2011 Picture Thread!! - Page 793 - Focus Fanatics
Old 03-07-2014, 11:50 AM   #7921
z4nder
z4nder's Avatar
Fan#: 103345
What I Drive: 2010 Sangria Red SES
FF Reputation: 1 z4nder Good Standing Member
Originally Posted by crice8 View Post
I have them in mine. I will see if I can get you a pic tonight. They really make the Halos looks good.
That would be awesome! Yeah I'm getting tired of seeing the white/blue halos and LEDS with the amber. Doesn't blend well.
Sedan Revolution #287
Tennessee Focus Owner #12
z4nder is offline
Old 03-07-2014, 12:02 PM   #7922
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
For everyone with switch back lights, resistors will be needed.
When buying resistors (6 ohm 50 watt) make sure you get the kind with braided wire insulation. You can find them here: CLICK ME. Even though the site says "Tail Light Load Resistor Kit", they are the correct resistors for your switch back turn signals.
Why do I want braided insulation on my resistor wires?
Short answer: They last longer
How do you know?
The resistors I originally used had rubber coated wires. They both failed after being exposed to cold temperatures and salty water that are common during Minnesota winters. The rubber coating cracked because of the cold temps, then the salty water from the roads corroded the exposed wire. One of my resistor wires actually snapped off completely when I was putting in my retrofit headlights.
To attach the resistor, splice them into the following wires:
Driver Side Green/Violet wire & Black/Green wire
Passenger Side Yellow/Violet wire & Black wire (I think the black is solid)
You do not use the violet/grey wire for anything on the drive/passenger side. That is the power to the running lights, you don't want to tap into that. The pictures above show the resistors spliced in using quick connect wire splices. I would highly encourage you to solder your splices and use heat shrink at the solder point. If you don't, you may have problems in the future due to corroded wires.
Originally Posted by 2010SVT View Post
Yeah my switchback are bright as hell but they make my blinkers blink fast. Think I need different ones
That fast blink is called Hyper Flash. The same thing happens when a blinker burns out on a car. The load on the wire harness isn't the same which results in the faster blink. Switch back LED bulbs don't require as much power as the standard filament bulb so the car thinks the bulb is gone, or burnt out. Once you install a load resistor CLICK ME, the blinker speed should go back to normal.
I didnt think I'd need them but guess I do. My buddy has some on his car and he didnt need them
Did his car come with LED turn signals? If it did, your buddy wouldn't need resistors.
Originally Posted by Rubix View Post
What would be the correct ones? Mine seem to work unless its a warm day. Then they flash white right before amber. Only when it's a hotter day though?
The correct resistors can be found HERE
Could you please clarify what you mean when you say, "Mine seem to work unless its a warm day. Then they flash white right before amber." I am not sure I follow what you're saying. A video would be very helpful.
I will try to get a video of my switch back turn signals tonight to clear up any confusion.
Hope that helps, if not, post any other questions you may have.
Thanks!
If you can't wear it out, burn it off
DarderSauce is offline
Old 03-07-2014, 01:34 PM   #7923
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
^ That is the one's that I have.
http://www.superbrightleds.com/morei...r-kit/190/831/
Galatians 6:14
crice8 is offline
Old 03-07-2014, 11:29 PM   #7924
2010SVT
2010SVT's Avatar
Fan#: 93835
What I Drive: 2010 Focus Se 1998 Ford F150
FF Reputation: 2 2010SVT Good Standing Member
Got her out the shop today. Probably the only white "SES"
[IMG][/IMG]
[IMG][/IMG]
sedan revolution #215 2010 SE Sedan, SES conversion front and rear, Ksport coilovers, Fswerks CAI, 93 tune, Race header and flex pipe, stealth exhaust, upper front stress bar and engine cover.
2010SVT is offline
Old 03-07-2014, 11:44 PM   #7925
Focus On Me
Focus On Me's Avatar
Fan#: 94526
What I Drive: 2008 Black Ford Focus S
FF Reputation: 3 Focus On Me Good Standing Member
[IMG][/IMG]
[IMG][/IMG]
Damn that's a sexy car..
2008 FoFo Coupe:
Custom Exhaust Work, FSWerks Intake (Green Filter), FRPP Suspension, Front and Rear SVT Sway Bars, Front Upper Stress Bar, Power Slot Rotors, EBC GreenStuff Pads.
Focus On Me is offline
Old 03-07-2014, 11:54 PM   #7926
2010SVT
2010SVT's Avatar
Fan#: 93835
Thanks man. I've been working hard on it.
2010SVT is offline
Old 03-08-2014, 07:57 AM   #7927
Rubix
Rubix's Avatar
Fan#: 109903
What I Drive: 2011 SES
FF Reputation: 1 Rubix Good Standing Member
Looks good man. I need to find a deal on that 3d spoiler.
http://www.focusfanatics.com/forum/showthread.php?t=309357
For my build
Rubix is offline
Old 03-08-2014, 08:36 AM   #7928
Snyper
Snyper's Avatar
Fan#: 96688
What I Drive: 2009 Black SE
FF Reputation: 2 Snyper Good Standing Member
The 3D Spoiler is great. Such a nice upgrade over the OEM spoiler or not having one. I love it.
Also, am I blind or was there some pictures here concerning wiring for the switchbacks? I can't seem to find them and I had questions!
Snyper is offline
Old 03-08-2014, 03:43 PM   #7929
crice8
crice8's Avatar
Fan#: 84830
My X10's came in this morning. These things are monsters! Here is a pic with a sundown sa10 on the left and x10 on the right. The can in the middle is a normal size can for size comparison.
I will post up some more pics once I get the enclosure sealed from the trunk.
Galatians 6:14
crice8 is offline
Old 03-08-2014, 04:36 PM   #7930
Rubix
Rubix's Avatar
Fan#: 109903
Oh my... What's it take to push those beasts
For my build
Rubix is offline
