How-To flush ATX fluid and change filter - Page 10 - Ford Focus Forum, Ford Focus ST Forum
Old 04-17-2014, 11:21 PM   #91
ProdigyRacingLA
Fan#: 86736
What I Drive: 2008 Black Coupe SE
Points 437, Level 8
Points: 437, Level: 8 Points: 437, Level: 8 Points: 437, Level: 8
Level Up 74% Completed
FF Reputation: 1 ProdigyRacingLA Good Standing Member
great read! I feel confident giving it a go now.
Nice Job!
ProdigyRacingLA is offline
Old 04-18-2014, 08:43 AM   #92
frednumber15
frednumber15's Avatar
Fan#: 83585
What I Drive: 2003 2dr ZX3
FF Reputation: 5 frednumber15 Good Standing Member
I'd do a full trans flush or at least drop and clean the pan and put in a new Ford filter. Try to find the rubber gasket for the pan? I'd use a synth fluid...Mobile or Redline and the right bottle of Lubegard additive (used by the pros). The synth and Lubegard will cost a bit...but not nearly as much as a trans rebuild.
Ironically...I have the same year and mileage car. I flushed the trans 2-3 years ago in fear of the same shifting issue you have.
The oil light is engine oil pressure...keep the level up and check viscosity? If it uses some oil...up the viscosity?
Check under the hood for a sticker showing the t-belt has been changed?
Originally Posted by Jason1906709 View Post
well this will be my first post here... i have just bought a 00 ZX3 everything seems well but oil light flashes sometimes? i check fluid and seems normal maybe im getting something from the filter of loss of pressure? also this is a great guide 120k on motor and tranny and deff replacing tranny fluid a little slip going into 3rd (auto = hate it but have to deal with it) would you say any other products to put in like LUCUS? or just all tranny fluid?
2003 2dr ZX3 2.0 L Zetec auto 205/50/16s
...and I am unanimous in that position.
frednumber15 is offline
Old 09-27-2014, 02:26 PM   #93
60DRB
60DRB's Avatar
Fan#: 183697
What I Drive: 2010, blue, Focus SE
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Level Up 21% Completed
FF Reputation: 1 60DRB Good Standing Member
I'll be showing/teaching my grandson how to drop the pan (and install a drain plug kit) and change the filter and partial fluid change this evening.
60DRB is offline
Old 09-27-2014, 05:20 PM   #94
Marde
Marde's Avatar
Fan#: 115991
What I Drive: 2004 ZTW PZEV 2.3 ATX
Points 1,539, Level 22
Points: 1,539, Level: 22 Points: 1,539, Level: 22 Points: 1,539, Level: 22
Level Up 39% Completed
Forum Activity 42%
FF Reputation: 9 Marde Good Standing Member
^^ You can add this bit of info into your lesson:
Before I did mine, I was having a hard time finding the torque spec on the pan bolts. Pretty sure I read this entire thread and other threads too. First post in this thread said 5 ft lbs, but I was looking for verification. What I found or settled on was 60 to 70 inch pounds, so it is equal to what the OP said. Auto Zone had an inch-pound torque wrench in their free tool loan program.
You've got to ask yourself one question: Do you feel lucky? -and could you really drive a Focus ATX Wagon?
Marde is offline
Old 09-28-2014, 04:39 AM   #95
60DRB
60DRB's Avatar
Fan#: 183697
Points 11, Level 1
Yes, I think I read somewhere in all the posts that the torque is 60 inch lbs. Thanks. I showed him how to use the TQ wrench (I have inch lb and foot lb versions) when he learned how to change the spark plugs a month ago. The old fluid was very dark, but the magnet only had the normal goop on it. I was kind of surprised how easy the pan came off-there was a very small amount of gray sealant on it. We used the rubber gasket that came with the filter. I still have sealant on hand if the gasket doesn't hold up. Located the drain kit at the driver side forward corner, clear of wires.
Replaced a measured 3 qts and 6 oz of fluid after the pan drop. Shows at just over the minimum level after a 1/2 mile quick drive. We'll recheck after a couple days.
60DRB is offline
Old 09-28-2014, 10:14 AM   #96
Points 27,399, Level 98
Points: 27,399, Level: 98 Points: 27,399, Level: 98 Points: 27,399, Level: 98
Level Up 5% Completed
Forum Activity 19%
I think somewhere in there I recommended the Permatex kit because the rubber gasket has adhesive on it.
Similar Threads
MTX Fluid Change? Coolant Flush? Djmike2485 General Technical Chat 13 12-16-2007 10:04 PM
ATX fluid change with RP? Mr.Bergner ZETEC Performance (2000-2004) 6 02-08-2007 06:01 PM
How change ATX fluid at 30K cking General Technical Chat 0 08-28-2006 09:22 AM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
ATX Shifts Hard After Fluid and filter change 2k2zx3 General Technical Chat 5 02-16-2006 09:03 PM
