Zetec Powered MGB Build Thread - Page 26 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 02-03-2014, 10:08 PM   #251
Brosuh
Brosuh's Avatar
Fan#: 120175
What I Drive: 2001 Silver SE
FF Reputation: 1 Brosuh Good Standing Member
Subbing. Awesome build!
Brosuh is offline
Old 03-19-2014, 09:23 AM   #252
79mgb
79mgb's Avatar
Fan#: 105006
What I Drive: 1979 MG MGB, 2008 Mazda 3
FF Reputation: 3 79mgb Good Standing Member
Time for another update! I figured I'd be bored waiting around for my MGB to come out of the paint shop so I started another little project. Since new wheels and tires are one things I'd like to install on the car once it's back, I decided to work on them now. Unfortunately, I burned through this so fast that I'm done with the wheels before my car even reaches the paint shop.
One of the early wheel options for the MGB was a steel disc wheel. I think they look pretty decent but they're relatively hard to find, they're 14x4 (very narrow), and they're designed to use tubes.
In order to retain a vintage look while being able to use a more modern tire size, I decided to buy a set of 2003-2006 Nissan Sentra 15x6 steel wheels from the junkyard and modify them to correct the offset. I read online that the Sentra wheels have a +41mm offset but that's way too high for the MGB. Could I use spacers? Probably. But I didn't want to for a few reasons.
The wheels have a two-piece construction so the center of the wheel is welded to the barrel. Step one to fixing the offset was (carefully) grinding away the welds from the edges of the center to free it from the barrel.
After that, I marked the inside of the barrel to where the offset should be. I then (carefully) pounded the turds out of the wheel centers with a sledgehammer to move the centers to the marks. Here's what the wheels look like on my Dad's MGB GT.
You can kind of see the difference between the two wheels here. The stock Sentra wheel is on the left while the modified wheel is on the right.
The tedious part to this is fine tuning the balance of each wheel. I had to mount each wheel and set up a dial gauge to measure the run out as I slowly spun it by hand. I had read online that the acceptable lateral run out is .050" but I was able to get the wheels within about .020" (not too shabby). I had to tack weld the wheels, verify the run out, weld them solid, and then verify the run out one last time. I found the steel on these wheels is pretty thick so warping isn't really a concern. Yes, the welds are solid. No, I'm not going to die. At least not because of the wheel welds.
The other day I painted one of the wheels Argent Silver with some VHT rattle can paint and mounted it to my car. I taped a Chevy rallye wheel baby moon on to show a more finished look.
I photoshopped an image of my wheels and baby moons onto an MGB. Hopefully this is what the finished result looks like:
I suppose I'll have to find some other projects to work on in the meantime. I can't wait to get this thing done!
Driving a Zetec Powered MGB. :)
79mgb is offline
Old 03-19-2014, 09:40 AM   #253
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 SCrew 5.0
that's some very nice work right there. hope i can see this thing in action sometime.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Kipp is offline
Old 03-19-2014, 09:47 AM   #254
Mustangsix
Mustangsix's Avatar
Fan#: 106702
What I Drive: 32 Ford, 73 MGB GT
FF Reputation: 1 Mustangsix Good Standing Member
The best part of all this was him grinding and hammering on the wheels in my driveway late into the evening so that all my neighbors could enjoy his work as well. Sledgehammer + wheel sounds like a large gong!
I have to admit, they do look good! And they were a lot cheaper than my wheels.
Mustangsix is offline
Old 03-19-2014, 10:23 AM   #255
79mgb
79mgb's Avatar
Fan#: 105006
Well DUH. I certainly didn't want to piss off my neighbors.
I'm sure your neighbors have learned to tolerate you by now.
79mgb is offline
Old 03-19-2014, 09:12 PM   #256
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 46 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (11)
^^hahaha
Nice work on the wheels!
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 03-20-2014, 01:23 AM   #257
"Elder"
FF Reputation: 57 sailor Excellent Standing Member
Good work, still busy with Fab. over purchase when you can I see.
Nice to mention the detail on getting them straight. Without mentioning that someone might try to copy the idea by ruler & eyeball!
Cheers
"Rubber Side Down"
S.R. #275
sailor is online now
Old 04-09-2014, 12:12 PM   #258
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 0 smallblockfever Newbie
All of this. A+++. Im hungry for updates.
"Never miss a good chance to shut up."
smallblockfever is offline
Old 04-09-2014, 12:36 PM   #259
ztecpower
ztecpower's Avatar
Fan#: 20083
What I Drive: 2002 Infra-red Ford Focus ZTS-S2
FF Reputation: 5 ztecpower Good Standing Member
My God.... This thread = WIN!! Great job you guys! I hope to do some of these modifications to my Zetec, to see this in an MGB is an awesome thing.
Troy. :)
You know... That guy.
SR# eleventybillion
ztecpower is offline
