my very slow forced induction build! - Page 14 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Forced Induction
Old 10-14-2014, 10:39 AM   #131
700whpfocus
Fan#: 40899
What I Drive: 2000 zx3 twillight blue focus
Points 5,389, Level 47
Points: 5,389, Level: 47 Points: 5,389, Level: 47 Points: 5,389, Level: 47
Level Up 20% Completed
FF Reputation: 2 700whpfocus Good Standing Member
Buy-Sell-Trade Rating: (11)
still in a stump with the fuel system. new pump in place and still no strong output
700whpfocus is offline
Old 10-14-2014, 05:39 PM   #132
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
Buy-Sell-Trade Rating: (13)
You did check the sock. No junk in the tank ? Pull line off from before the fuel filter. And use a manual fuel pressure gauge to check pressure.
iroc34 is offline
Old 10-14-2014, 10:39 PM   #133
700whpfocus
Fan#: 40899
there is no junk in the tank. the sock? i pulled off all the lines before and after the fuel filter........i turn the key on and the fuel drips out. not forceful at all. i put on a new filter and hooked everything up......still no gas to the fuel rail. i am getting so fed up. I am not giving up on the car. i just wanna make the stock engine is running properly. i changed the fuel pump driver module too
Old 10-14-2014, 10:47 PM   #134
NotReal
NotReal's Avatar
Fan#: 162482
What I Drive: Several svtf.
Points 1,555, Level 22
Points: 1,555, Level: 22 Points: 1,555, Level: 22 Points: 1,555, Level: 22
Level Up 55% Completed
Forum Activity 44%
Activity: 44% Activity: 44% Activity: 44%
FF Reputation: 6 NotReal Good Standing Member
What's you volts to pump. I'm pretty sure you know the rubber grommet above the pump plug so you don't have to drop tank. Do a key on voltage check. Is pump continually running or does it switch off. Also did you state that before filter you had strong stream of fuel spraying out??
Look at that.
NotReal is online now
Old 10-14-2014, 10:48 PM   #135
NotReal
NotReal's Avatar
Fan#: 162482
Forum Activity 44%
Sock is the little pre-filter on the pump inside the tank.
Look at that.
Old 10-15-2014, 12:03 AM   #136
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
Points 50,433, Level 100
Points: 50,433, Level: 100 Points: 50,433, Level: 100 Points: 50,433, Level: 100
The seal over the pump on the canjster is probably not sealing correctly. Need whole new unit maybe. That's what solved it for me
ZXthrizzle05 is offline
Old 10-16-2014, 11:52 AM   #137
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 50,975, Level 100
Points: 50,975, Level: 100 Points: 50,975, Level: 100 Points: 50,975, Level: 100
Forum Activity 33%
Buy-Sell-Trade Rating: (28)
Are you trying to turn on the key and get continuous fuel coming out of the fuel line for as long as the key is on ? and it is falling off after a few seconds ? thats what it is suppose to do
You have to start the engine and when it starts check your fuel psi with your xcal scanner and see what it is at idle
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 10-17-2014, 08:10 PM   #138
700whpfocus
Fan#: 40899
I will check it out again Sunday.
