I just bought this 2001 Focus ZX3 5 spd. Before I bought it, I had it for 2 days and tested it, and it seemed to be fine.
However after I bought it for about 2 days, I am having problems with my speedometer, which jumps/bounces to high speed and return to normal. It happens when it start, or sometimes when you hit the gas or so. When it happens, the car is not smooth, and it tembles or shakes back and forth a bit.
Before I bought it I did pre-purchase inspection and also the free AAMCO transmission check, because we thought we heard some kind of noise when we accelerate. They did not find anything wrong. One place said that the noise comes from transmission and the AAMCO transmission shop said the transmission is fine they thought they hear something under 2000rpm maybe from motor.
Now it seems the noise is gone and I am having the problem stated above. I have no idea what is going on and this is my first car. I hope it is nothing really serious. Should I just send it to a mechanic shop and checked out?
just a tip if you have a problem its good to list EVERYTHING that happens when your problem happens like what sounds does it make where are they coming from does the engine shake or the whole car itself seem to shake does it happen when your shifting how many miles are on the car did you have the 121 point inspection before you bought it do you have warrenty does the tach jump with the spedo do any check enigine lights come on...explain your problem throughly youll get a better diagnosis...ps WELCOME TO FF sorry it had to be under these circumstances
The speedometer is not related to the engine electrically any other way. However, I wonder if perhaps the bouncing speedometer is a RESULT of the engine running rough instead of the other way around as he's written it.
As THEONLY287 wrote... is there anything else that happens, like maybe the lights going dim at the same time that might point to another cause.
I am having the same issue with my wifes ZX-3.
At first, I suspected the fuel filter, since she's had the car 100,000km and never changed it. I had believed the speedometer jumping was just a symptom of the engine being choked by the filter, but now that I've changed the filter, it still happens.
If it is a VSS problem, do you know if it's possible to simply disconnect the speed sensor? (not as a solution, just to determine if it's the problem)
If you disconnect the VSS, which yes it can be disconnected, then you'll not have a speedometer at all. The two are related, but the other way around... deja vu... did I write this before?
You can replace the VSS, but it's likely to be expensive, and not be the problem. Try taking the car to Autozone or some other auto parts store and asking them to scan your car for codes. The best time to go is a time when there are not many people there, but they will do this for free. Write down the codes, and bring it in to check it against the list of engine trouble codes we have here. That will also help some in diagnosis.
If you take the car into a mechanic, ask him to thoroughly check wiring that's near the exhaust. LilDisco (I think) had a problem with weird things happening that was the result of wiring that was burnt by the exhaust which was not easily obvious because the part that was burnt was facing in the other direction. I'm fairly sure he had to get under the car to find it.
The mechanics said they think it's the problem with spark plugs and spark plug wires.
They said they "spot on ignition wire with electricity coming through". And the engine is misfireing erratically.
I and my friend will buy some spark plugs and wires to replace ourselves, as they said it cost almost $300 for them to replace it.
Any thought?
But I will post if this solve the problem.
That doesn't explain the speedo issue, but it's highly possible that the two problems are not related.
If you purchase "Lifetime warranty" wires, keep the box, or when you need to change the wires again, don't destroy the new wire's box, and put the old wires in the new box to return to get your money back. That is the only way to get plug wires for free for life.
JRPASMO mentioned a common problem with the Focus, and that's the wires leading to the coil, on some vehicles these wires are too short and one ends up being pulled out of the connector. This connector should be looked at with scrutiny. If you find yours to be suspect, then you can get a replacement part from the Ford dealer to fix it.
There is also the voltage regulator plug that goes in the back of the alternator. Several people have had problems with this plug also.
I must say that I prefer the old Ford OBD1 wiring connectors that you could pull on all day long without pulling a wire out.
I have replaced the spark plug and wires, which has lifetime warranty.
Bosch Platinum 2 spark plugs and Duralast wires. Saved $200 than let mechanic do it.
Now the shaking problem of the car seems gone. We had P0304 error code which means #4 cylinder misfire. It did not go back to normal once we replaced it. But after we fasten/enforced both end of the wires, the problem seems gone so far. I suspect it is contact problem, and replacement of spark plug and wire might not be needed.
The speedometer still jumps, but not as often or bad. I suspect that misfire worsen the speedometer problem, although they seem unrelated.
I replaced the plugs and wires also, about a day after that, the car threw a CEL on and started to shake even worse.. Turns out the coil was cracked... Replaced it, and the car runs perfect now, no more jerking of the speedometer or bucking of the car.
i had the same problem. its prolly your speed sensor malfunctioning. my car did the same thing. have someone replace it and it should take care of it. your speedo and tach and trip run off the speed sensor which is part of the tranny so when your speedo jumps around it makes the car feel like its shaking and what not.
I think u might be having a problem with ur Mass Air Flow sensor aka MAF sensor my 94 tbird had the same problem but the only diff was that the rpm and the Speedo would jump I bought 2 cats new wires spark plugs and coil pack and all to find out that the maf was the problem wich was worth on 8 buckaroos at AutoZone vs 400 for the cats and stuff
Hello,
I have been experiencing the same problems with my 2001 ZX3 including terrible misfire/backfire under heavy load, speedometer bouncing up and door ajar light coming on but when it wasn't under load, everything worked perfectly. After replacing the connection to the coil and putting new plugs in, the problem was nearly gone, but when i lugged it, it would still miss and show the same symptoms at a much lower severity. After reading through some forums, found similar problems solved by a new coil. I installed a new coil and the problem dissapeared.
All gauges doing a full sweep upon startup indicates a voltage issue, chk grounds and the small wires going to the + on the battery, make sure voltage on battery is good, ...
It's (full sweep) often a sign of the battery going bad. The sweep occurs when full power during sitting drops off, the gauges need it to keep memory in the chip of how they worked last time used, when that's lost they do the sweep to regain needle sweep calibration parameters.
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
