ZX3 ride height? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-10-2013, 10:56 AM   #11
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,788, Level 76
Points: 13,788, Level: 76 Points: 13,788, Level: 76 Points: 13,788, Level: 76
Level Up 35% Completed
Forum Activity 100%
Originally Posted by my_beautious_ZX3 View Post
My suspension = stock (Monroe); springs & dampeners on front & rear about a year old. (No junk in my trunk, except factory spare tire & jack; photo taken with ~1/4 tank of gas.)
The Monroe springs & dampers, I'd be looking at. Did you not notice the ride height difference when you installed these at the time? What was wrong w/ the oem springs?
felixthecat is offline
Old 05-10-2013, 03:29 PM   #12
my_beautious_ZX3
Fan#: 32386
Points 1,374, Level 20
Level Up 74% Completed
I didn't pay attention to the ride height until after I installed the rear shocks, because that's when I noticed that the ride got harsher (too firm). But, that's a natural reaction when a person's been driving on old shocks for a long time - the new shocks can seem harsh because you were accustomed to the soft, sloppy feel of the old ones. (I installed Gabriel shocks first, and they were super firm, so I returned those and got the SensaTracs, which were noticeably softer.)
I replaced the rear coil springs because a) they were deteriorating, b) the LCA's were being replaced, and, c) there was some bad camber going on back there. The new LCA's & Moog springs didn't improve nor worsen the ride quality (but they fixed my camber).
Monroe has been supplying OEM-like ride quality for forever, so I don't think they're to blame. Plus, the Gabriel's were even worse, so it's not likely that I got ahold of two different brands of defective parts from two different stores.
On the rear, I did not replace the upper control arm nor the trailing arm. I rarely see those mentioned on the forum - would they contribute to ride quality issues while driving straight on smooth, flat pavement?
my_beautious_ZX3 is offline
Old 05-10-2013, 10:47 PM   #13
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
The ride quality depends on your springs & shocks. If you had poly bushings in your trail arms & a pair of aftermarket camber arms, it'd just feel tighter then oem rubber bushed parts. For the height= it depends on what springs you have for their determine your ride height. Say like frpp's springs drop the ride height down 1.5'' from stock height. So the springs you have are the wrong springs for a focus. You could take then out & cut a whole coil out to get your ride height down. Is your front ride height the same or what?
Old 05-10-2013, 11:47 PM   #14
my_beautious_ZX3
Fan#: 32386
measured @ top of wheel well lip: rear = 27.5 inches, front = 26 inches (see post #1 on this thread)
10-4 on the coil springs determining ride height. But, I'm wondering if some other component could be contributing? Eg., if something is binding-up. IIRC, I thought it was the Focus Haynes manual which mentioned a need to manually check/adjust ride height.
I'm discounting the springs as the source of the problem, because Moog wouldn't make that kind of glaring mistake - and if they did, they would have fixed it years ago.
