2005 oem stereo and sub quandries... - Focus Fanatics
Old 11-17-2013, 04:09 PM   #1
MandoboyF12
Fan#: 123105
What I Drive: 2005 grey zx4
FF Reputation: 1 MandoboyF12 Good Standing Member
Howdy!
So, I'm a newbie here (though I've had the car since new)...I recently changed out the original 6CD non-audiophile out with an audiophile...sub out is on the back. Of course, the car has no sub, yet there is a plug in the harness behind the unit. Digging around in the trunk, for the life of me, I can't find the other end...if in fact there is one? Is it cut short somewhere? I'd like to put a sub in. The audiophile sounds great...may be wrong, but I can tell it's missing the sub in the mix. I don't really want to change everthing out with a new unit, amps, big rattling sub boxes, etc....would even consider using a used factory if the connection can be found.
How about a small unit in the trunk (or under the seat)? Can I use an adapter from the head's sub out? I see this Metra harness out there...
Advice is most appreciated, though I know this stuff has been covered somewhere or another here.
MandoboyF12 is offline
Old 11-18-2013, 06:58 AM   #2
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
I don't know if all cars were wired for the sub, but if so, the plug should be behind the cloth trim piece over the DS wheel well in the trunk. There's a large wiring harness that run along there and contains the plug for the subwoofer.
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
Old 11-18-2013, 08:13 AM   #3
MandoboyF12
Fan#: 123105
Thanks for the reply! I've looked back there, and found some wiring and connections, but no obvious connector hanging or taped up. The couple connectors there are connected...looks like mostly for the lights.
Old 11-18-2013, 12:52 PM   #4
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
FF Reputation: 2 ferret15 Good Standing Member
When you plugged in the radio did you have enough connectors? Also do you have the OEM sub? If not I'd advise you just to pick up a powered sub, they are similarly powered. It sounds like you have to run wires anyway. Most non sub cars didn't have the wiring for it.
ferret15 is online now
Old 11-18-2013, 01:06 PM   #5
MandoboyF12
Fan#: 123105
Yes! There are three connections, and then the antenna. I'm positive the sub connector is at the back of the head, from the harness to the radio, I plugged it in. I unplugged it before closing up, I do not have a sub, stock or new...yet...I'm looking at one of these little micro jobs, powered and ready. I'm not looking to ratlle teeth..just solid sound, top to bottom. I'm pretty sure I can use that Metra harness (70-5521)? Just the sub connector, from head out to RCA's. Sounds simple enough, but I've learned to never count on anything to be simple.
Old 11-18-2013, 03:06 PM   #6
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
The plug for the woofer is a foot or two back from the plugs you saw. At least on Zx3
's and 5's
Old 11-18-2013, 03:22 PM   #7
MandoboyF12
Fan#: 123105
Interesting. On the back of the head, the plug beside the radio plug is the sub, yes? If so, the plug is there. I plugged it up...now where it is in the trunk? Go fish.
Old 11-18-2013, 03:34 PM   #8
mainest
mainest's Avatar
Fan#: 60163
FF Reputation: 7 mainest Good Standing Member
Buy-Sell-Trade Rating: (10)
My '05 ST had the harness and plug on the driver side in the trunk, as well as all of the mounting points for the Audiophile sub/amp brackets, etc. However, when I added an SVT sub/amp and plugged it in, I got no sound. My guess is that Ford rewired the sub harness/ connector for the Mk1.5 Foci. I still have that sub/amp, as well as (I think) the mounting hardware and carpet (for a ZX3) if you are interested. Here are links to several threads with photos of the plug and pin out for the sub/amp. http://forums.focaljet.com/ice-car-e...-amp-help.html
http://forums.focaljet.com/ice-car-e...p-install.html
Good luck.
mainest is online now
Old 11-18-2013, 03:42 PM   #9
MandoboyF12
Fan#: 123105
Thanks!
I think I'm gonna get the Metra harness, use the sub plug (head unit to RCA's), and try a different powered sub. May try an under-seat piece. I know those are sorta frowned on, but I don't need anything to make the car rattle.
