Quick Question
Installed AEM UEGO Wideband yesturday
Got everything hooked up.
Hooked up the ECU ( bolted it back into place since sending it out for BBK upgrade )
I am now throwing the code of P1233 ( fuel pump module offline)
The car runs ok, havent gone into boost due to the code thrown
I checked fuses there wasone fuse blown under hood but it was ABS fuse. ( 30 )
I checked the wiring and also checked the reset switch thinking i might of bumped it when putting the ecu back in. Same issue
no i'm driving to work this am and notice that my oil temp gauge is barely moving up and my engine temp gauge is lower then normal i drove 30 miles into work and the oil temp gauge barely moved. ( which throws a red flag ) I don't know if these two are related or what but i think they are.
Could this be a wiring issue since it happened only after i hooked up the wideband?
Anyone know of a good way to troubleshoot this dct?
