will these fit over my calipers?
"Set of 4 VOLVO STEEL WHEELS - Perfect for Winter Snow Tires
KFZ STAHLRAD AR-0993 7J x 16
Lug Pattern 5 x 108.0 mm
Hub Opening Diameter 65 mm
Offset 49 mm
Max Load 1,320 lbs
Made in Switzerland
Fits following VOLVO models:
60 Series (2001-2009)
70 Series (2001-2007)
80 Series (1999-2005)
Very good condition, run true, no curb damage, valve stems included, ready for snow tires.
On the ST the stock offset is 55 mm, but it's also on an 8" wide wheel. The 49 mm offset is 6mm less than the stock wheels, and those wheels are 1" narrower. The hub bore being larger is an issue if you don't tighten down the lugs properly, but the biggest risk is clearance to the front calipers with balance weights, especially for alloy wheels in the 16" size.
16" is the minimum requirement, but 17" wheels fit better/ easier.
Moved to Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Related Threads
Focus Fanatics Forum
5.8M posts
189.4K members
Since 2003
