PRODUCT FAQ: Zetec/SVT Oil Separator Kit - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Central Florida Motorsports
Central Florida Motorsports Discuss about performance and appearance upgrades for your Ford Focus.
Sponsored By: C-F-M.com
Old 07-29-2006, 05:10 PM   #1
cfmfocus2
FF Affiliate
Fan#: 22843
What I Drive: Ford focus svt
Points 8,364, Level 61
Points: 8,364, Level: 61 Points: 8,364, Level: 61 Points: 8,364, Level: 61
Level Up 72% Completed
FF Reputation: 9 cfmfocus2 Good Standing Member
Buy-Sell-Trade Rating: (6)
Click image above to view more information or purchase product
Here you will find all information relevant to this product. Please only post questions or information that will be useful to others who own or are considering purchasing this product. Thanks!
William - Sales Dept.
407.339.9211
Please e-mail or call me for quicker response.
cfmfocus2 is offline
Old 08-13-2006, 12:38 AM   #2
2.0TooSlow
Fan#: 27765
What I Drive: 02 SVT
FF Reputation: 1 2.0TooSlow Good Standing Member
On the Vortech ZX3, how is the PCV valve ran?
Is it to the intake manifold, with a catch can inline?
Also, what about the valve cover hose? Where does it go, and is there a catchcan anywhere inline with it?
2.0TooSlow is offline
Old 08-15-2006, 07:33 PM   #3
CFM Focus
FF Affiliate
CFM Focus's Avatar
Fan#: 1021
What I Drive: '01 ZX3 w/ Vortech
Points 2,055, Level 27
Points: 2,055, Level: 27 Points: 2,055, Level: 27 Points: 2,055, Level: 27
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 3 CFM Focus Good Standing Member
Please do not post same question on diff forums. Thanks!
CFM Focus is offline
Old 08-26-2007, 10:35 AM   #4
BlkMamba03
BlkMamba03's Avatar
Fan#: 37662
What I Drive: 03 SVT F
FF Reputation: 3 BlkMamba03 Good Standing Member
I chose a blue hose but you can choose a different color.
Here is one way to correctly install your C-F-M oil seperator.
The above photo shows the left blue hose connecting to the stock PCV valve that i cleaned out with WD40 and some light burst of air untill it rattled freely and let dry over night. The right hose shows the stock elbow connecting to the intake manifold. The elbow to the manifold is glued and will take some
force to come off.There is a metal rod in between the elbow and the manifold alowing you to twist the elbow upward on the metal rod while still keeping connection to the manifold. The glue on the elbow will heat after a few runs and keep the elbow in place. I then used the supplied 90 deg. plastic elbow to connect to the blue hose on the right connecting to the intake manifold.
The lower picture shows the air-water seperator connected to the battery box. The blue hose on the left is the hose from the PCV valve. The blue hose on the right is from the intake. About every 1000 miles i put around half the bottle back in the crankcase depending on if i am autocrossing or not. I hope this helps i see it set up from the crankcase to the air intake a lot and i dont know how that helps. BlkMamba
BlkMamba03 is offline
Old 04-03-2008, 02:51 PM   #5
Yocrew
Fan#: 54713
What I Drive: 02RedSVT #306
FF Reputation: 19 Yocrew Great Standing Member
Buy-Sell-Trade Rating: (12)
I just purchased this. Do you need the original PCV hose for install? Mine rotted out and I dont wanna pay ford 40bucks for something im not sure if I need.
Yocrew is offline
Old 04-03-2008, 03:11 PM   #6
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
let me get this right
for the seperator...
take the pcv valve and instead of plugging into the hose that runs to the intake, route the supplied hose to the seperator. and then from the seperator, route the supplied hose to the intake?
i have heard of people filing down the pcv valve and removing the guts. is this beneficial to this style of "catchcan" setup?
is it truely safe to deposit the oil that is "caught" back into the crankcase?
also, can we get some EXPLODED views of where each hose connects? i have been confused by this for a year now.
scrammer is offline
Old 04-03-2008, 03:44 PM   #7
Yocrew
Fan#: 54713
Im not sure, but I dont think it goes into your intake. Best bet would be to call CFM. If you install it, be careful. The hose for my PCV was rotted and unuseable. CFM is trying to track one down so I dont have to over pay from ford.
Yocrew is offline
Old 04-03-2008, 08:56 PM   #8
Tbones00SE
Tbones00SE's Avatar
Fan#: 9982
What I Drive: 2000 Toreador Red SE
Points 1,367, Level 20
Points: 1,367, Level: 20 Points: 1,367, Level: 20 Points: 1,367, Level: 20
Level Up 67% Completed
FF Reputation: 10 Tbones00SE Great Standing Member
Buy-Sell-Trade Rating: (7)
Almost, from what I can tell in the first pic, the pcv hose was disconnected from the pcv valve. One hose from the seperator was connected to the pcv valve and the other was connected to the pcv hose. It doesn't look like the seperator hose connects to the intake manifold directly.
Zetec Crew #73
ATX Faction #24
Mods: Volant CAI, 65mm TB, CFM Lower Mount, VF Passenger Mount, SVT Header, SVT Cat, SVT Flex, and Trubendz 2.5" exhaust, Roush Suspension, Tune and CarPC.
Tbones00SE is offline
Old 04-06-2008, 09:28 AM   #9
BlkMamba03
BlkMamba03's Avatar
Fan#: 37662
The intake manifold has a connector that routes to the PCV valve under the ignition coil. There is a curved hose that went from the PCV valve to the intake from under the coil. The separator kit comes with plastic routers that i used to go from the old hose from the intake, metal rod under the coil. I curved the old hose upwards away from the PCV to hook up to the intake side of the separator.
Old 09-29-2010, 03:53 PM   #10
djvo6
Fan#: 79044
What I Drive: 2002 black svt
FF Reputation: 1 djvo6 Good Standing Member
is it legal?
is your set up a street legal set up? i just tried to pass a smog and i didnt pass the visual inspection because i have a breather valve where you have a hose connecting to the intake hose.
djvo6 is offline
