Low Budget Homemade ZX3 Turbo Setup (On and Spooling!!!!!) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-05-2006, 10:22 PM   #1
bluballer
bluballer's Avatar
Fan#: 22553
What I Drive: 2000 Candy Red ZX3 5sp Turbo soon?
FF Reputation: 2 bluballer Good Standing Member
Talking Low Budget Homemade ZX3 Turbo Setup (On and Spooling!!!!!)
I saw this thread and said to myself basically I 'm doing this too (~$500 turbo kit). I'm doin' it a little different though ....Got it mounted and spooling going to the muffler shop this week ( down pipe :-) ). I will post pics and price list soon... P.S. mine is a T-3 setup using the GET THIS .....STOCK MANIFOLD MODIFIED ...To mount the T-3. I am going for mild boost 8lb w/no lag using a RELIABLE internally gated SAAB Turbo (oil and water cooled), a Volvo intercooler with a volumetrically matched electric cooling fan (for reducing idle related heat soak), To feed it I am using 42lb injectors and a matched 70mm Pro Mass unit.... Its a slick simple low cost setup that if it works correctly will push the envelope for DIY turbo setups for the ZX3 FOCUS!!! No disrespect TOM I LOVE YOUR (S_ IT) This is just so I can learn for myself. NEXT time you get my money ....engineering asystem that works correctly and low cost is hard work (respect)!!!! LOL and Tom, I'mma need some tuning too please so HALLA @ a BLU-BALLA!!! Can we work together on this thing?
I'm sacrificing my Focus so that yours may live
Interested in my low budget homemade turbo settup In development? Check this thread... http://www.focusfanatics.com/forum/s...threadid=77086
bluballer is offline
Old 03-05-2006, 10:34 PM   #2
dwdgsi03
dwdgsi03's Avatar
Fan#: 2298
What I Drive: 2000 Midship Runabout
FF Reputation: 1 dwdgsi03 Good Standing Member
Wow, from what I see, looks like pretty deent work. Did you do all of this yourself, the custom fabrication and stuff?
(\_/) Copy this bunny to your sig because he`s better than the "other bunny"
(O.o)
dwdgsi03 is offline
Old 03-05-2006, 11:09 PM   #3
R1ck 22
R1ck 22's Avatar
Fan#: 26054
What I Drive: 2002 fort knox zts
FF Reputation: 1 R1ck 22 Good Standing Member
if you get it working write up a how too that would be awsome for us on a budget
ZETEC Crew # 78
mods: spectre cai kamakize hedder mbrp exhaust enki 17's kenwood ddx 7015 kac 7202 and 10'' mtx 5500s c/f oem style hood poison body kit 1.25 drop springs
R1ck 22 is offline
Old 03-06-2006, 12:10 AM   #4
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
I will give credit for getting this far. Do you have gear to measure AFR and EGT? If not, don't boost it at all till you get a tune. You have no idea what its doing.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 03-06-2006, 12:50 AM   #5
rockthezx3
rockthezx3's Avatar
Fan#: 2116
What I Drive: 05 Silver WRX Wagon
FF Reputation: 1 rockthezx3 Good Standing Member
Never seen a top mount intercooler in a focus (minues the WRC car). I'd like to see a write up on it also.
First - 03 Egg Yolk Yellow ZX3
Second - 02 Infra Red SVT
Now - 05 Platinum Silver Metallic WRX Wagon
...now with dyno tuned stage 2
rockthezx3 is offline
Old 03-06-2006, 01:27 AM   #6
f00t
Fan#: 25867
What I Drive: the old batmobile
FF Reputation: 1 f00t Good Standing Member
awesome, budget turbo systems are taking off. i bet were gonna see alot more of these in the future
Light Weight Baby ! ! !
f00t is offline
Old 03-06-2006, 02:02 AM   #7
bluballer
bluballer's Avatar
Fan#: 22553
dwdgsi03 believe it or not there is not much fabrication to it.....the greatest of which what the manifold mod. Im not a welder... but a decent one can do it relatively inexpensive.
I did design/manufacture the brackets (very reasonable) and engineer the system. Because of the intercooler location the pipes are straight line (straight pipes). The blow off valve fits on a preformed pipe so no special molding there. It's connected with silicon elbows and connectors.
viney266 I do have all the required gauges and will try not to boost unless I know whats going on. I agree with you I really need to know whats going on ....LOL I'm lazy I dont wanna swap to a built engine yet!!!! And TOM (if you help me I Love you man!!!!! ) on that tune!!!
And rockthezx3 You are right I hadnt seen top mounted intercooler before that much either but I did see some Wide bodied Foci (red and yellow) that had an air to water intercooler in the same spot. Looked so sweet to me so I had to have it. Some like'm great big but for the boost amount Im trying to achieve, that intercooler came off a car with the A. same size engine using B. the same size turbo running C. the same about of boost. so for me that was a no brainer....if it works reliably and efficiently on Volvo's and SAAB's it for 100's of thousand of miles it should work for my meager application here too. The only thing I had to do to put it there was to relocate the battery to the rear "boot" where it belongs (as on many european cars)
I've also gone through the additional detail of putting a electric fan on the bottom side that will flow the maximum required volume of air through it at idle. ( I used the intercooler core size/flow calculations to find my correct fan.
Speaking of European ..... I've got a WRC style front clip (Ibherdesign) special ordered from EUROPE along with other European Body Mods (Portugal, England, Germany) that I'm going to incorporate into this one of a kind EuR-A-FoCuS!!! and the A is for American!!!!
Much more on the way but thank you all for support so far.....I was glad to hear it spool and see no smoke!!!! Keep ya fingaz crossed for me on the downpipe... gonna be a tight fit....
HALLA@ a BLU-BALLA!!!!
Old 03-06-2006, 08:05 AM   #8
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
How are you getting outside air to the intercooler???
Seriously it needs ALOT of fresh air blowing through it.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 03-06-2006, 09:04 AM   #9
lg03focus
Fan#: 22162
What I Drive: 2003 liquid grey sedan
FF Reputation: 1 lg03focus Good Standing Member
actuallyonly running only 8 lbs he doesnt need an intercooler at all. 9 lbs is teh common threshold for intercooled or not. and if i read right he said he is putting a fan on the intercooler kinda like a b+m tranny cooler setup
lg03focus is offline
Old 03-06-2006, 11:09 AM   #10
bluballer
bluballer's Avatar
Fan#: 22553
Egggggggggggzactly lg03focus additionally Im going to have a vented (EVO I think its called) hood that will provide a flow through location close if not exactly atop where my intercooler is located (a lot of thought and research went into my concept before I bought the first piece)..... This is not going to be some 500 hp, eat a Vette Monster.... (If I keep the car till I want a rip snorting monster I'll build an engine and go with a Tom's or equivalent setup )..... I just want something that suprises (stealthy and compact) and is commensurate with the eventual styling of the vehicle, and that I can use my otherwise stock (might add LSD to make it stickier and a stronger clutch when I burn this one up) drivetrain with .... plus im going to get the air from the same place that a volvo or a saab would get it .....and I dont think either has a huge front mout ic on 8lbs of boost either.
In fact my 84 SAAB turbo (with the original engine, factory APC tunning and turbo 186,000 miles no leaking or burning oil ) runs like a BULL reliably with NO Intercooler.....I'm convinced and will say it again though it's been said many, many, many, many times before .....for this car "It's all in the tuning" ....the physics is there and has been done and tested......everyone can achieve boost...... but the technology is definately in the tuning...... If I can achieve ~200 whp reliably with a low cost (hoping for less than a $1000) per smiles technology ....My Job is DONE!
O and if anyone is interested..... This link shows the first tuner car I poured everything into 1990 Acura integra.... she got totalled when an idiot ran a red light and caved into my side.... The focus is replacing it for now http://www.cardomain.com/ride/339883 not bad for a piece of crap I had to have towed home initially!!!! some of my other build ups are linked in the favorite links portion of that page....
