Need Gasket Part Number - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-16-2005, 09:28 PM   #1
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,049, Level 33
Points: 3,049, Level: 33 Points: 3,049, Level: 33 Points: 3,049, Level: 33
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 11 hEaT Great Standing Member
Does anyone have or know where to get the Ford part number for the gasket that goes from the flex pipe to the exhaust system? I need the #'s for the SVT system (unless a new flex from McNews comes with it which I doubt) and the regular Zetec system. Thanks.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 10-16-2005, 11:21 PM   #2
vanace
Fan#: 350
What I Drive: 2005 ST
FF Reputation: 1 vanace Good Standing Member
go to your local parts store and they will tell you....if not, then the dealer will tell you also.
ST crew #18
vanace is offline
Old 10-16-2005, 11:29 PM   #3
mr.squatch
mr.squatch's Avatar
Fan#: 4112
What I Drive: 02 zx3
FF Reputation: 1 mr.squatch Good Standing Member
Factory gaskets are usually metal and can be reused multiple times. If you get a bigger pipe you can cut out the gasket with scissors too. I'm on my 2nd flex, 4th header and 2nd exhaust, and I'm still using the gaskets that came on the car. haha
g
mr.squatch is offline
Old 10-16-2005, 11:35 PM   #4
hEaT
Fan#: 20699
Haha. Mine is leaking right now from my flex to my exhaust system on my Borla. AutoZone doesn't have it and neither does Advanced Auto. Do I have to bore out the gasket so it fits the size of the 2.5" Borla piping? Right now the gasket hole is the same size as the flex pipe, but the hole in the middle is smaller than exhaust tubing.
ZETEC Crew #49
hEaT is offline
Old 10-17-2005, 12:01 AM   #5
mr.squatch
mr.squatch's Avatar
Fan#: 4112
if you have a stock flex it doesn't matter. you gotta make the center bore as big as the smallest pipe fitted to it or it will block flow. If its leaking just get some orange silicone at autozone, the high temp stuff with copper in it works well in that application. Just take out the gasket, cut it if you need to, goop it on both sides with the silicone and put it back in. No more leaks. Good luck
g
Old 10-17-2005, 11:42 AM   #6
hEaT
Fan#: 20699
Awesome, thanks. I'll have to give it a shot.
ZETEC Crew #49
hEaT is offline
Old 10-17-2005, 11:49 AM   #7
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
SVT is 2M5Z-9450-AA and BA, and there are two different ones for the zetec and they are YS4Z-9450-FA which is identifyed by 57.5mm spacing on the mounting ears and the other is 1S4Z-9450-AA and is 52.5mm spacing .
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Old 10-17-2005, 12:20 PM   #8
hEaT
Fan#: 20699
What would be the cause of the different sizes in the mounting ears? Would the smaller one happen to be the SPI?
Thanks a bunch though. If that high-temp silicone doesn't work I'll be getting a new gasket. When I take it out, I'll just measure the ears and see which one is right.
Just wondering, where did you get the #'s from?
ZETEC Crew #49
hEaT is offline
Old 10-17-2005, 04:58 PM   #9
hEaT
Fan#: 20699
I had my Dad take some measurements on the stock exhaust flange and the only measurement that comes close is from the center of the pipe to the center of the bolt hole which is 52mm. I'll probably try reseating the gasket first, if it still leaks, try the silicone, and then if that doesn't work, go down to a dealer and have them get me the right part.
ZETEC Crew #49
hEaT is offline
Old 10-17-2005, 07:02 PM   #10
ampedout
ampedout's Avatar
Fan#: 16956
What I Drive: White 00 SE Sedan Zetec
Points 5,085, Level 45
Points: 5,085, Level: 45 Points: 5,085, Level: 45 Points: 5,085, Level: 45
Level Up 68% Completed
FF Reputation: 1 ampedout Good Standing Member
Buy-Sell-Trade Rating: (8)
Where can you get some graphite gasket material? Ive made my own out of those before and they work wonders. But cant find out where to purchase more. The first of wich was given to me by a friend.
Roush Turbo kit
ampedout is offline
