"How To" Replacing High Beams in HID Housing - Focus Fanatics
Go Back   Focus Fanatics > Model Specific Discussions > MK1 Focus
View Poll Results: Is this thread helpful?
Hell yeah man!! Thanks! 5 71.43%
Why would you replace highbeams if you have HID's? 2 28.57%
Voters: 7. You may not vote on this poll
Old 08-24-2005, 05:12 PM   #1
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Memberscrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
How-To Replacing High Beams in SVT HID Housing
Time Required:
15 minutes per housing
Tools Needed:
10mm socket and ratchet (to remove housing)
T-20 torx bit
needle-nose pliers (unless your infant is going to to this install)
Before we begin, you must have 1 pair of H7 highbeam bulbs. Also the knowledge on how to remove your headlight housing. In this thread are attached 3 detailed pics to ease your comprehension.
If you dont know how, you must first remove the uppergrill. 4 screws hold it in place along with 2 marker lights that must be removed.
For the headlight housing, there is 1 screw attaching it to the fender. 1 screw that is on the core support. The last screw is underneath the car behind the bumber placed horizontally. Then pull the housing at an upward angle. Then remove the wiring harness from the rear.
NOW on the back of the housing, there is a large cover held in by 4 tabs. CARFULLY pull the outer tabs away from the cover and pull cover off.
This will reveal a mess of wires and stuff that you really shouldn't play around with.
Holding the housing horizontal, look into the housing to the left. This is your highbeam bulb socket. There are 2 screws that hold down the socket. DO NOT attempt to remove either screw. I found it is near impossible to remove the screw that is furthest inside the housing. and it will just make it a PITA to re-install the other screw.
Taking your t-20 star bit with whatever tool you are using with it, loosen the retainer screw on the right of the socket about 1-2 turns. Just do not completely remove it.
Take your needle-nose pliers and CAREFULLY grasp the socket harness and turn counter-clockwise. Now bring the light near the opening of the housing making it able to be removed.
DO NOT remove the metal piece that is tabbed on the harness. ONLY remove the bulb. I found that an easy rocking motion works well.
Now take your new H7 highbeam bulb (i used silverstars), and CAREFULLY install it into the socket. DO NOT touch the freakin bulb!!!! The oil from your clean hands will ultimately heat up on the bulb and cause it to shatter. You dont want to attempt the clean-up on that one.
You will notice, on the metal piece of the socket, the "top" is bent over. This obviously must be re-installed being on top.
Take your needle-nose again, or your infant fingers, and grasp the socket and replace it into the housing. The side tabs on the metal socket MUST fit underneath both mounting screws. Once the socket is in, it should stay. Tighten down the screw that you loosened earlier.
Replace the cover on the back and be sure all 4 tabs are locked back in place.
Reconnect the vehicle wiring harness to housing.
CAREFULLY re-install headlight housing into car being sure to take your time and not to scratch anything.
Turn on headlights and check highbeams.
If they worked, replace screws and reinstall upper grill and shut the hood. Now your already bright OEM bulbs are replaced with uber-bright ones. ENJOY
Sean Crammer
this better get stickyed
scrammer is offline
Old 08-24-2005, 05:16 PM   #2
scrammer
scrammer's Avatar
Fan#: 26570
rear of the headlight housing. this is also a great time to upgrade your city-lights if you are planning to do so.
scrammer is offline
Old 08-24-2005, 05:17 PM   #3
scrammer
scrammer's Avatar
Fan#: 26570
this points out the high-beam socket
scrammer is offline
Old 08-24-2005, 05:20 PM   #4
scrammer
scrammer's Avatar
Fan#: 26570
points out the retainer screw, socket tabs
scrammer is offline
Old 08-24-2005, 08:47 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
FF Reputation: 138 WD40 Excellent Standing MemberWD40 Excellent Standing Member
Nice job.
We just might have to "sticky" this.
WD40 is offline
Old 11-09-2005, 09:13 PM   #6
Toolman00
Toolman00's Avatar
Fan#: 2744
What I Drive: 2000 Ford Expedition XLT 4x4
FF Reputation: 3 Toolman00 Good Standing Member
Good bit of info. Love the "Why would you replace highbeams if you have HID's?" choice. Seriously, the highbeam bulb really doesn't do much other than help a little with illuminating up front. The HID's light up the rest and do a damn good job!
Give the toughest job to the laziest man and he'll find the easiest way to get it done.
Toolman00 is offline
Old 12-06-2005, 12:47 PM   #7
scrammer
scrammer's Avatar
Fan#: 26570
slap a pair of silverstar H7's in your HID housings. then come back and tell me that the higbeams dont do that much. ill try to post pics tomarrow
scrammer is offline
Old 12-06-2005, 08:06 PM   #8
hkysk8r07
hkysk8r07's Avatar
Fan#: 5957
What I Drive: 00 I-R ZX3/ 07 Reflex Silver GTI
FF Reputation: 1 hkysk8r07 Good Standing Member
Buy-Sell-Trade Rating: (11)
it's not that complicated. pretty straight foward if you ask me. i've takem my HID's completely apart and now need to remove the high beam to replace it. but my lights are hardwired and don't have the time this week to screw around with it.
thats alot of steps as well
1 remmove back
2 loosen torx
3 shake bulb holder until it comes out
4 replace bulb
5 put in and retighten torx
6, replace backing
7 connect wires/ bolt in housing
8 start up and go
00 focus zx3
07 VW GTI
hkysk8r07 is offline
Old 12-07-2005, 04:31 PM   #9
TM3
Fan#: 16784
What I Drive: 2004 EAP SVTF
FF Reputation: 3 TM3 Good Standing Member
Buy-Sell-Trade Rating: (17)
Good info. I've been wanting to change my high-beams for some time now.
TM3 is offline
Old 01-26-2006, 06:38 PM   #10
texassvt
texassvt's Avatar
Fan#: 18366
What I Drive: 04 cd silver svt
FF Reputation: 1 texassvt Good Standing Member
Question bulb ?
so what about replacing the HID's with some aftermarket bulbs for more illumination? do you have to replace the starter thingy on top of the bulb? or just replace the HID bulb only? thanks
you want to play you got to pay.
mods: modified exhaust
wayne's tune Xcal1 unit
MSD coil & wires copper plugs, RT cat, FR STS
VF rear trans mount
redline mats, viper alarm, tyc tails
kyowa 17" gunmetal rims with BFG KDW's hoen hid match foglight bulbs
SVT SQUAD #117
texassvt is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
