The tube on the Valve cover - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-17-2014, 05:12 PM   #101
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 378, Level 7
Points: 378, Level: 7 Points: 378, Level: 7 Points: 378, Level: 7
Level Up 56% Completed
Forum Activity 9%
FF Reputation: 1 GhostTribute Good Standing Member
Originally Posted by 1turbofocus View Post
They should do it right and eliminate the other half ( PCV ) and stop sucking hot oily contaminated air into there intake manifold that settles to the bottom and stays there and that also causes carbon build up on the valves which in turn lowers MPG and Performance
Here is a pic of my intake valves with 100k running a short ram with PCV connected to the intake and a small filter on the valve cover....
there was a light coating of oil at the bottom of the intake. Not enough that it was going to make it's way back up into the cylinders though...... Honda's have a really bad setup. The PCV is on the top of the intake manifold and the oil runs straight into the runners.... bad design. Guessing that is why they have the new design that actually has it at the lowest point of the manifold.
I do agree that the running no intake filter was a stretch.....
GhostTribute is online now
Old 08-17-2014, 08:04 PM   #102
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,564, Level 100
Points: 52,564, Level: 100 Points: 52,564, Level: 100 Points: 52,564, Level: 100
Forum Activity 58%
Activity: 58% Activity: 58% Activity: 58%
Buy-Sell-Trade Rating: (28)
Jeeeees , there you go , keep up the good work ! Im sure every Zetec out there is that clean thanks for sharing
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 08-17-2014, 10:39 PM   #103
Pirela
Fan#: 96649
What I Drive: 2003 Pitch Black zx3
Points 316, Level 6
Points: 316, Level: 6 Points: 316, Level: 6 Points: 316, Level: 6
Level Up 32% Completed
FF Reputation: 1 Pirela Good Standing Member
Shows a picture tom
Pirela is offline
Old 08-17-2014, 11:33 PM   #104
Elder
Points 13,436, Level 75
Points: 13,436, Level: 75 Points: 13,436, Level: 75 Points: 13,436, Level: 75
Level Up 47% Completed
This was an OLD thread before nboyles had a question...
Whatever your decision about venting to atmosphere, keeping in mind the air flow of the zetec PCV system vs. duratec for example helps keep it running well.
Zetec PCV intake air is un-metered (from before the MAF) while the duratec uses metered air from after the MAF in the intake design.
This can affect tuning & your decisions on plumbing the system.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Similar Threads
"How To" - Replace Valve Cover Gasket and VCT Solenoid JohnMichael General Technical Chat 45 03-10-2013 09:06 AM
Turbo: PCV and Valve Cover Breather tube- Darth Focus Focus-Power Tuning 22 10-20-2009 06:33 PM
Valve cover question jayspikes82 SVT Performance (2002-2004) 7 09-19-2006 05:20 PM
Low end stumble / miss....valve cover drain hole Titan1969 General Technical Chat 7 09-14-2006 09:50 PM
Valve cover gasket blck01zx3 ZETEC Performance (2000-2004) 12 08-06-2005 08:13 PM
