2004 rebuilt spi with tick - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-30-2014, 05:38 PM   #1
Zimmer
Fan#: 33757
FF Reputation: 1 Zimmer Good Standing Member
I had the motor rebuilt/bored .010 over, new head, new oil pump, new water pump, new timing belt/tensioner, all new sensors, all new gaskets. BUT I have these noises...a chugging noise and a ticking noise (around the 19 second mark). I am sure some of the squealing is from my tensioner.
http://youtu.be/eEtABNnrlx8
Zimmer is offline
Old 05-30-2014, 05:55 PM   #2
poppop
poppop's Avatar
Fan#: 59702
What I Drive: 2001,Red,LX
Points 274, Level 5
Points: 274, Level: 5 Points: 274, Level: 5 Points: 274, Level: 5
Level Up 48% Completed
FF Reputation: 2 poppop Good Standing Member
Take the valve cover off and look for a loose lifter.
poppop is offline
Old 06-15-2014, 08:13 AM   #3
Mandroid
Mandroid's Avatar
Fan#: 150610
What I Drive: 2003 light tundra metalic SE 5spd
Points 1,108, Level 18
Points: 1,108, Level: 18 Points: 1,108, Level: 18 Points: 1,108, Level: 18
Level Up 8% Completed
FF Reputation: 1 Mandroid Good Standing Member
I think you mean loose rocker arm? not sure what you mean by a loose lifter.
Mandroid is offline
Old 06-15-2014, 08:18 AM   #4
Mandroid
Mandroid's Avatar
Fan#: 150610
Just listened to it. That ain't no lifter. I'm just not sure what it is. My guess is either multiple loose rocker arms (not torqued to anywhere near spec) or a wrist pin? I wouldn't rule out bottom end either. Get a long screw driver or a mechanic's stethoscope and see where it's loudest on the motor. That way we can narrow it down
Mandroid is offline
Old 06-15-2014, 08:18 PM   #5
poppop
poppop's Avatar
Fan#: 59702
Points 274, Level 5
IF the arm is loose so is the lifter.Had that sound in my first focus.
poppop is offline
Old 06-15-2014, 08:24 PM   #6
Mandroid
Mandroid's Avatar
Fan#: 150610
I see what you mean. I thought you meant it was lifter tick
Mandroid is offline
Old 06-17-2014, 12:25 AM   #7
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
Rocker arms get loose when lifter collapses or simply too much room in there, anything that makes airspace between parts so that they can begin to impact each other, where the noise comes from.
That engine there has far more than lifter/rocker issues........................motor will most likely be junk shortly.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is offline
Old 07-09-2014, 12:12 AM   #8
LineC
Fan#: 118298
What I Drive: 2004 SVT EAP
Points 188, Level 3
Points: 188, Level: 3 Points: 188, Level: 3 Points: 188, Level: 3
Level Up 76% Completed
FF Reputation: 1 LineC Good Standing Member
When you swap over all that rocker stuff to your new head the lifters have little holes that should be positioned in one direction and the retainers are only suppose to go one way. But it is possible to put them in 180 out. After you torque it you should also run the cam over a couple times, (with engine lube on the bearings) and retorque but only if the head is off the block
LineC is offline
Old 07-09-2014, 12:13 AM   #9
Mandroid
Mandroid's Avatar
Fan#: 150610
That is true. My friend did that with his spi escort
Mandroid is offline
Old 07-09-2014, 12:13 AM   #10
Mandroid
Mandroid's Avatar
Fan#: 150610
But that noise isn't in the head
Mandroid is offline
