SVT Focus Rear End Link Install question - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 05-11-2014, 11:29 AM   #1
nelson914
Fan#: 53037
What I Drive: 2002 Black Svt Focus
FF Reputation: 1 nelson914 Good Standing Member
Just have a question about installing the sway bar rear end link,
do you install this with weight on wheels or do you do it with the car jacked up?
its rather hard to install it jacked up and get all the rubber bushings to fit on the bolt.
nelson914 is offline
Old 05-11-2014, 05:38 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 48 iminhell Great Standing Member
With weight on the tires, on the ground.
If you can't fit under the car, drive both front and rear on ramps.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 05-11-2014, 10:41 PM   #3
"Elder"
FF Reputation: 60 sailor Excellent Standing Member
Moved to "Brakes, Suspension & Chassis".
Backing onto ramps sounds good for easier access.
"Rubber Side Down"
S.R. #275
sailor is offline
Old 05-12-2014, 11:37 AM   #4
nelson914
Fan#: 53037
Thank you for your reply
Old 05-12-2014, 08:11 PM   #5
ShadowFocus603
ShadowFocus603's Avatar
Fan#: 118448
What I Drive: 2004 Pitch Black SVT EAP 2Dr #1878
FF Reputation: 1 ShadowFocus603 Good Standing Member
I did mine by jacking each side up and using jack stands to hold the car up. I did the links with no weight on them at all and haven't had an issue at all in over 2 months. I agree though that ramps would be the best bet. When you do them you will have to undo both sides, swing the bar down, install them in the arms then swing the bar back up over them both at the same time. I found that if I completely installed one side and tightened it down there wasn't enough space to get the other side in.
2004 Ford Focus SVT #1878
ShadowFocus603 is offline
