Replaced front pads and rotors, now no pedal! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-07-2014, 10:39 PM   #1
Billh1959
Fan#: 161738
What I Drive: 2004 tan Focus SE
FF Reputation: 1 Billh1959 Good Standing Member
Angry Replaced front pads and rotors, now no pedal!
I just finished replacing the front rotors and pads on my fiances 2004 Focus Se. Now there is no pedal, goes almost all the way to the floor. It's better if we pump the brakes once or twice before trying to stop. I had to compress the piston back into the caliper to get the new pads in. I have been doing brakes for over 30 years and this is the first time this has happened. Any help will be greatly appreciated! She's threatening to divorce me before the wedding on May 17th. HELP!!!
Billh1959 is offline
Old 05-08-2014, 12:17 AM   #2
Elder
Points 12,763, Level 73
Points: 12,763, Level: 73 Points: 12,763, Level: 73 Points: 12,763, Level: 73
Level Up 79% Completed
Shucks, that's usually such a simple job too...
Any issues with the fluid that pumped back into the reservoir? Did you have to suck any out or add some again later? Hose from the master back up to the reservoir still look OK? Did you happen to do one at a time & pump it up between or was it all at once.
Pumping it up again when done is normal, as I'm sure you're familiar with. Staying "soft" is rather unusual.
Take a look at the calipers as someone presses the pedal to look for excessive movement - that's sometimes a problem if everything didn't go back together quite right or the new pieces aren't proper. (I actually had a set of pads cut at an angle not long ago on one job, bad enough to be obvious fortunately or it might have driven me nuts)
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 05-08-2014, 11:44 AM   #3
Billh1959
Fan#: 161738
Question Replaced front pads and rotors, now no pedal
Yes, I did both sides then checked the pedal. There was south fluid forced back to the reservoir it made a puddle on the ground. I have removed the master cylinder and checked that, bled the entire system with new fluid and checked all the fuses for the ABS system. I'm still at a loss!
Old 05-08-2014, 11:50 AM   #4
mnewxcv
Fan#: 161898
What I Drive: n/a
Points 289, Level 5
Points: 289, Level: 5 Points: 289, Level: 5 Points: 289, Level: 5
Level Up 78% Completed
FF Reputation: 1 mnewxcv Good Standing Member
so there are no leaks now? and they were properly bled? sounds like theres air in there or a leak.... or low on fluid. pedal goes close to floor with car on and off?
mnewxcv is offline
Old 05-08-2014, 08:59 PM   #5
Billh1959
Fan#: 161738
No, the pedal is fine, perfectly fine, when the engine is off. Only when the engine is running does the pedal go to the floor. It pumps up a little if you step on it a couple times when stopping but nothing like its supposed to be. I bled the system with a brand new vacuum bleeder and new fluid and bled it until the new clear fluid was coming out. What about the ABS system? All the brake lines go into a metal box with what looks like a motor in the front. Is that the booster and ABS system? Does that have to be bled separately? I'm still confused
Old 05-08-2014, 09:28 PM   #6
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
FF Reputation: 10 Paladin Great Standing Member
that metal box is the solenoid system for the abs. its where all the pulsing happens when abs is activated. its also where all of the air bubbles love to get trapped when bleeding the brakes the old fashioned way. your only option is to take it to ford so they can finish bleeding properly. (they have a very advanced tool called a modis its like 3 grand to purchase one it can cycle the solenoids in the abs pump housing as well as extremely in depth diagnostic work. )
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 05-08-2014, 09:43 PM   #7
thenorm
thenorm's Avatar
Fan#: 14947
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
maybe this is redneck, but could u get the pedal pumped up and try an ABS stop. jar those bubbles loose?
May 2014 ROTM
for street: '02 Infrared SVT
thenorm is offline
Old 05-08-2014, 09:49 PM   #8
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
maybe. the solenoids just need to get the air up and out. if you feel confident enough to try this do it on a country road that isnt well traveled.
Paladin is offline
Old 05-08-2014, 10:29 PM   #9
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,750, Level 58
Points: 7,750, Level: 58 Points: 7,750, Level: 58 Points: 7,750, Level: 58
Forum Activity 21%
FF Reputation: 9 ViperThreat Good Standing Member
bleed the lines again, and make sure to top off the reservoir multiple times after every pump.
Use some surgical hose on the bleeder nipple so that you can see if any bubbles come out.
Also, i never trust those vacuum-based bleeder systems, they have failed me before. Get a friend in the car pumping while you release/tighten the bleeder.
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is online now
Old 05-08-2014, 10:53 PM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,331, Level 100
Points: 138,331, Level: 100 Points: 138,331, Level: 100 Points: 138,331, Level: 100
Forum Activity 53%
Buy-Sell-Trade Rating: (11)
You must have air still trapped some where. Being that you opened the system completely when you took the master cylinder off there will definitely be air in the system after that. Try getting a helper to pump the pedal while you bleed it. I have had to do this a few times even after using a brake bleeder pump.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
