New Monroe quick struts making creaking noise - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-28-2014, 11:00 PM   #21
FreeFocus
SPI Not Dropped Club
FreeFocus's Avatar
Fan#: 112674
What I Drive: 2002 SPI Focus
Points 17,658, Level 84
Points: 17,658, Level: 84 Points: 17,658, Level: 84 Points: 17,658, Level: 84
Level Up 62% Completed
Forum Activity 100%
FF Reputation: 3 FreeFocus Good Standing Member
Originally Posted by felixthecat View Post
Try this= Undue then & then your noise should disappear.
Where is the fun in that at?
If old struts were bad then why put them back on? But I see what you are saying.
MY FOCUS HAS A HEMI IN IT
Focus TakeOver#001 Co-Founder
Sedan Revolution #289
FOCUS XTREME
FreeFocus is online now
Old 04-28-2014, 11:24 PM   #22
focusETSzx4
Fan#: 120097
What I Drive: 2005 zx4 & 2012 se
Points 413, Level 8
Points: 413, Level: 8 Points: 413, Level: 8 Points: 413, Level: 8
Level Up 26% Completed
FF Reputation: 1 focusETSzx4 Good Standing Member
Well when I replaced stock struts they weren't really bad but I definitely wanted to upgrade my suspension. I bought this car used so I'm putting some work into it
"I hate to be the one to atodaso, but you know what? Atodaso, I freaking atodaso"
focusETSzx4 is offline
Old 04-29-2014, 01:31 AM   #23
Elder
Points 12,825, Level 73
Points: 12,825, Level: 73 Points: 12,825, Level: 73 Points: 12,825, Level: 73
Level Up 94% Completed
He meant detach the sway bar links to see if the noise comes from them I would guess.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-29-2014, 06:46 AM   #24
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
This^^^^^^^^^^^^
felixthecat is online now
Old 04-29-2014, 06:51 AM   #25
felixthecat
w/ my magic bag
Fan#: 80663
Originally Posted by FreeFocus View Post
Well I don't know how many miles are on your car but I read OEM front sway bar links tend to go bad after 40,000-45,000 miles. Mine broke around 48,000. It is just a thought.
Originally Posted by focusETSzx4 View Post
Well right now I'm about at 110,000. My buddy told me my end links are fairly new but I got to playing around with them and they seem to have some play in the upper bushing, so they can't be that new or at all. I'll look into it further. I'm just tired of all these noises they drive me nuts lol
Mine was totally snapped, it wiggled around like a loose tooth. Had to heat it up to get it off. Are they OEM? Grease fittings on them? I HATE a noisy car! Its real easy to do it yourself, I'm not technically inclined at all.
Good Luck!
Not sure if they're OEM but they do have grease fittings
And I know they're easy we actually took them off when i replaced the struts. A lot of this stuff is easy it's just finding the time to do it all lol
Everone is talking about the sway bar end links, FreeFocus.
Old 05-02-2014, 12:42 PM   #26
focusETSzx4
Fan#: 120097
Points 413, Level 8
Well, played around with it today for a little bit while I was at work earlier. Can't seem to find the source of my problem, but I am for sure going to go ahead and put new shocks on the rear and end links on the front end. I just had a set of MOOGs ordered so they should be there tomorrow.
Everything with my struts seem to be seated properly. I'm going to have a buddy drive it tomorrow while I walk alongside it to see if I can hear the noise better.
Old 05-13-2014, 02:29 PM   #27
nelson914
Fan#: 53037
What I Drive: 2002 Black Svt Focus
FF Reputation: 1 nelson914 Good Standing Member
I am just gonna guess that you are installing the end links with the vehicle jacked up and having some creaking because of it. While jacked up on the front, just attach the top portion and leave the bottom unattached. Then make sure the weight is on the tires, not jacked up, then attach the bottom portion of the end link. As for the rear just install the whole portion with the car weight on the tires. This should eliminate your noise.
nelson914 is offline
Old 05-13-2014, 09:03 PM   #28
focusETSzx4
Fan#: 120097
Points 413, Level 8
I figured it out. The strut I purchased was defective. I just took it out, and used my warranty to replace it. Put the new one in and all is good now. Thanks for the response
