Car stalling in park and neutral - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2014, 09:14 PM   #1
toyotaco02
Fan#: 157490
Points 14, Level 1
Points: 14, Level: 1 Points: 14, Level: 1 Points: 14, Level: 1
Level Up 27% Completed
FF Reputation: 1 toyotaco02 Good Standing Member
First post here, my wife has a 2002 focus se with the spi. After she started having some engine noise I found out that this engine drops valve seats like they are going out of style. Well guess what ours did two weeks ago.
After having everything fixed and buttoned back up she runs like a top. The problem we are having now is after starting it it does not hold an idle and wants to stall, which at first start it doesn't. After driving it awhile she will pull into a parking spot put it into park and it will die. The same thing happens if she puts it in neutral. The car acts great and drives great if left in drive or reverse. In park or neutral it will stall.
Anyone have any ideas?? I'm at a lost. Thanks
using FF Mobile
toyotaco02 is offline
Old 04-20-2014, 09:23 PM   #2
Elder
Points 12,818, Level 73
Points: 12,818, Level: 73 Points: 12,818, Level: 73 Points: 12,818, Level: 73
Level Up 92% Completed
Helpful description!
NOT stalling when cold, and being OK in gear should indicate the IAC (idle air control) is working to bump up the idle as it should under load & when cold.
Checking the PCV hose for leaks/softness/swelling & looking for any vacuum leaks from bad or disconnected hoses would be a good first step. Particularly since it was just repaired, something loose/disconnected is the most likely cause.
That includes checking the intake plumbing, another area that could easily not be connected properly so it came loose.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 04-20-2014, 09:47 PM   #3
toyotaco02
Fan#: 157490
Points 14, Level 1
Thanks for the quick reply. I have checked the pcv hose because I knew of this issue. I just replaced it before the tear down of the engine.
I was thinking iac but I thought this would be a problem all of the time whether it's under load or not. Could it need cleaning or actually replaced? I was also wondering about the tps? I'm just trying to figure this thing out as when it left the mechanic all was well until we drove it quite a but this weekend. Thanks again
using FF Mobile
Old 04-20-2014, 10:06 PM   #4
Elder
Yeah, the IAC would be more of a suspect if it stalled when put in gear, or didn't idle up cold then settle down as it warms up.
Loose intake between MAF & throttle body is a suspect, a bit of unmetered air won't help.
Looking for simple answers since it was just apart & with so many pieces handled it would be easy for one to have come loose.
If it's only been a few days since repair, run it by the mechanic for a quick look if you don't find it yourself.
"Rubber Side Down"
sailor is offline
Old 04-20-2014, 11:35 PM   #5
toyotaco02
Fan#: 157490
Points 14, Level 1
Just went out and checked everything. It all seems together. What would a bad tps do?
using FF Mobile
Old 04-20-2014, 11:45 PM   #6
Elder
From some recent ones, stumble & stutter when using the throttle.
"Rubber Side Down"
sailor is offline
