2004 Focus Rally Build - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-22-2014, 04:42 PM   #91
MaxAtk
Fan#: 118232
What I Drive: 2004 White Focus Rally
Points 592, Level 11
Points: 592, Level: 11 Points: 592, Level: 11 Points: 592, Level: 11
Level Up 84% Completed
FF Reputation: 1 MaxAtk Good Standing Member
Work continues on the transmission. After two hot baths this is what the housing looks like. Plan on painting it up with some silver VHT.
Now onto switching out the gears for the final drive. Those gears and bits need to go onto the other shaft...
Time to get to it.... a little over a third of the way there... need a press for the rest of the job. Updates soon:
MaxAtk is offline
Old 03-22-2014, 05:17 PM   #92
msperber
Fan#: 80053
What I Drive: 05 ST Focus 2014 SE Champion
Points 301, Level 6
Points: 301, Level: 6 Points: 301, Level: 6 Points: 301, Level: 6
Level Up 2% Completed
FF Reputation: 3 msperber Good Standing Member
Love rally builds, they are flying tanks and the drivers are more talented than most road racers
msperber is offline
Old 03-30-2014, 09:00 PM   #93
fclevelandwrx
fclevelandwrx's Avatar
Fan#: 118803
What I Drive: 2001 Red ZX3 Stage rally car
FF Reputation: 1 fclevelandwrx Good Standing Member
How did you remove your axle seals? I've been trying to beat mine out with a hammer and screwdriver but they just don't want to come out.
Foard C.
RM-Autosports.com
Blue Branch Rally Team
fclevelandwrx is offline
Old 03-31-2014, 08:15 AM   #94
MaxAtk
Fan#: 118232
I used a hammer and big old screwdriver as well. Mine were pretty stubborn too and took quite a bit of force. Seems like these thing a built for a tank. I got stuck at removing the second gear from the shaft. Could not even get it off with a 20-ton press. Bringing it over to a specialty transmission place this morning so they can get it off for me, lol...
MaxAtk is offline
Old 04-01-2014, 08:58 PM   #95
fclevelandwrx
Fan#: 118803
Borrowed a tool and got both of the seals out in less than 2 minutes, I'm going to get one of these suckers for my box because these transmissions break axles and changing axles wears out the seals.
http://www.summitracing.com/parts/ot...Fafm7AodHFwAow
If you talk to Andrew Frick he can probably help you with building your trans at home.
Foard C.
RM-Autosports.com
Old 04-09-2014, 12:20 PM   #96
MaxAtk
Fan#: 118232
Time for some transmission fun updates:
5th and 4th Gears came off the shaft quite easy.
Hit a brick wall getting off 2nd and 3rd gear. I love the manual: "Using the special tool, remove the second and third gear wheel". Tried everything. Massive heat, multiple presses. It easily was bending a 20-ton press and was not coming off. Took it to a transmission specialty shop to get it off. They gave up after an hour and refused to charge anything as they cursed the damn thing. In the end, I purchased everything new from 3rd gear downward.
Here is a photo of me getting revenge on it after a week of wrestling with it
Dismantling it did come in handy for reassembly as the Ford manual and Ford parts diagrams had discrepancies.
MaxAtk is offline
Old 04-09-2014, 01:45 PM   #97
MaxAtk
Fan#: 118232
Here is the build up:
MaxAtk is offline
Old 04-09-2014, 01:46 PM   #98
MaxAtk
Fan#: 118232
MaxAtk is offline
Old 04-09-2014, 01:50 PM   #99
MaxAtk
Fan#: 118232
So, to get 3rd and 4th gear on to spec it took some heat and 44,000 tons of pressure according to the load meter on the press I was able to use.
and the final product...
MaxAtk is offline
Old 04-09-2014, 01:53 PM   #100
MaxAtk
Fan#: 118232
All going back together now
The shift selector cleaned up good. Still had the Ford sticker on it
MaxAtk is offline
