Does anyone know of someone or has anyone taken apart their engine for any reason? - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > DURATEC Ti-VCT Performance (2012-Current)
Old 03-28-2014, 10:03 PM   #11
nobleblake
Fan#: 120882
What I Drive: 2012 Tuxedo Black Titanium HB
FF Reputation: 1 nobleblake Good Standing Member
Originally Posted by Jburks View Post
Where do you enter for the induction service? i have always gone through the pcv but i dont see one on these engines. I see the hose that goes off the valve cover to the air filter inlet, is that where you went? i always thought you were supposed to go through the exhaust manifold but i dont see a line into it.
It depends on the type of service you are performing. At my dealership, we use BG products. So, I've got a dual tank (fuel rail and high pressure spray nozzle) and spray it at the throttle body. I take the intake tube loose just before the throttle body, insert the nozzle and reattach the tube. Then, I let the vehicle warm up before I start spraying.
As for using a can with a tap or "seafoam," you could take the vacuum line off the brake booster and run it that way. You won't have much vacuum at the breather hose connection since it's before the throttle body. If you can find a vacuum line after the throttle body, then that should do the trick. I haven't heard of anything involving the exhaust manifold.
nobleblake is offline
Old 03-28-2014, 10:20 PM   #12
Jburks
Jburks's Avatar
Fan#: 145009
What I Drive: 2014 Ford Focus Hatchback SE RR DCT
FF Reputation: 1 Jburks Good Standing Member
Well i had a mini cooper and it had a vacume line that ran from the valve cover to the intake manifold. it was part of the PCV system. anyway you could disconect it from the valve cover and then you had a vacume line going into the intake manifold you could use. Pretty much the same thing as you going in through the throtle body i bypassed the TB and went straight into the intake manifold. I meant to say intake manifold in my other post not exhaust manifold, my bad. i'll edit that.
2014 Focus SE DCT RR. "Fiona"
Mods- Green Drop in-Snorkel Delete-plastidip-RokBlokz
Instagram- _jburks_
Build thread-http://www.focusfanatics.com/forum/showthread.php?t=382642
Jburks is offline
