What have you done to increase MPG? - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-21-2014, 11:54 AM   #91
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,077, Level 34
Points: 3,077, Level: 34 Points: 3,077, Level: 34 Points: 3,077, Level: 34
Level Up 18% Completed
Originally Posted by NickCornell View Post
place pizza pans over wheel spokes
Just kidding, but seriously.
Those 15" LRR tires with the moon caps and 0W-20 oil was getting me +42mpg combined last winter back when I was driving the speed limit and not warming my car up.
This winter... I said screw it. I want to be warm, I already lost 2 hubcaps so I just took them off and I already drive 100 miles a day so it's really not worth it to me to drive the speed limit. I was also getting free oil changes (5W-20) because of all of my DCT troubles.
Ooh, and keeping her clean and waxed helps with aerodynamics just a tiny bit!
PratoN is online now
Old 03-21-2014, 04:50 PM   #92
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,720, Level 78
Points: 14,720, Level: 78 Points: 14,720, Level: 78 Points: 14,720, Level: 78
Level Up 68% Completed
Forum Activity 11%
I want some stainless steel moons like those in the pic above for my 17" wheels.
I would liketo have small holes drilled so the moons would bolt to the alloy wheel.
Only small machine screws would be needed.
Also a comment on the higher inflated front tires: if you do a test to find the 'perfect' patch (the shape of the contact patch on the ground) You will find nearly always the right patch is only when the front tires are about 5 to 8 PSI over the rear.
The right size tire/ground contact patch is TOTALLY dependent on psi in the tire and on the weight each tire is carrying.(so in a front engine car, no way can an equal front and rear PSI be 'correct' from a performance/tire wear point of view, the equal tire pressure is for stupid people. Pretty much exclusively.)(feel free to quote me on that)
The front in a front engine car obviously carries a lot more weight than the rear tires.
So for a four banger the difference is usually 4/6PSI more in the front tires than the rear, and a six cylinder would need about 6/8 PSI more than the rear tires for a perfect contact patch.
The perfect part means the tire wears perfectly evenly.
Fo most folks the front tires edges wear out faster anyway.
I realized higher PSI did not mean bad front wear. It actually means BETTER, more even front tire wear.
So I am always at 44/43 PSI front 39 PSI rear. (39 seems to be the rear limit for good ride. 40PSI starts to cause too much harshness in the ride.
Plus typically the PSI manufacturers suggest/use is ALWAYS for 'good ride' which means the smoothest ride. With near zero concern for 'best handling' or best tire wear.
(look at the Ford Firestone/Explorer fiasco. where Ford said use a below safe air pressure for a nice ride. And to compensate for a poor suspension design)
and sorry to highjack the thread about MPG to blather about tire air pressure..
Elizabeth is online now
Old 03-21-2014, 05:06 PM   #93
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,027, Level 96
Points: 26,027, Level: 96 Points: 26,027, Level: 96 Points: 26,027, Level: 96
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
^This x2
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 03-22-2014, 09:40 AM   #94
bshin352
bshin352's Avatar
Fan#: 114147
What I Drive: 2013 Tux Black Ti Sedan, DCT
FF Reputation: 1 bshin352 Good Standing Member
Has anyone considered vortex generators? Or has anyone done their own underside mid plate and rear diffuser?
#teamdct
bshin352 is offline
Old 03-22-2014, 03:32 PM   #95
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,400, Level 29
Points: 2,400, Level: 29 Points: 2,400, Level: 29 Points: 2,400, Level: 29
Level Up 67% Completed
FF Reputation: 6 CunFFS13 Good Standing Member
I got a gas cap lock, and it worked! I'm getting better MPG
CunFFS13 is offline
Old 03-22-2014, 03:53 PM   #96
bshin352
bshin352's Avatar
Fan#: 114147
Are you being serious or are you joking? -confused-
#teamdct
bshin352 is offline
Old 03-23-2014, 08:29 PM   #97
raptor1956
Fan#: 97725
Points 4,355, Level 42
Points: 4,355, Level: 42 Points: 4,355, Level: 42 Points: 4,355, Level: 42
Level Up 3% Completed
Originally Posted by sailor View Post
Hey Doc - FWIW your engine is a Duratec, not a Zetec. And since you posted in a section for cars '12 and newer with a different engine design.... Just doesn't apply.
'Fraid the variations can get confusing, for our divisions here (just to keep 'em separate) yours would be considered a "Mk1.5", the first variant on the original.
Yeah, I missed the discrepancy in engine type. For a lower compression engine there should be no significant advantage to higher octane gas whereas the 12:1 compression ratio of the Mk3 Duratec engine will benefit from higher octane gas.
Brian
raptor1956 is online now
