New owner problems - windows - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-20-2014, 02:27 PM   #1
Krayz_tom
Fan#: 150042
What I Drive: 2013 Black 1.6 Zetec
FF Reputation: 1 Krayz_tom Good Standing Member
Unhappy New owner problems - windows
Is it normal that my drivers side window will go all the way down with one touch but not come up with one touch? I've tried resetting it using the 3 second tip from another thread but still no luck! And also is there meant to be a passenger side one touch feature as well as this is non existent at the moment?
Also I've been told that there isn't an engine cover for the 1.6 petrol version of the focus does anyone know if this is true or where I can find one?
Many thanks
Newb
Krayz_tom is offline
Old 03-20-2014, 03:21 PM   #2
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Points 7,557, Level 58
Points: 7,557, Level: 58 Points: 7,557, Level: 58 Points: 7,557, Level: 58
Level Up 4% Completed
Forum Activity 9%
In the U.S. it's one-touch down AND up. All 4 windows on the higher trim levels. Make sure you're following the reset procedure from the manual. I had to reset them every time the battery was disconnected.
kam327 is offline
Old 03-20-2014, 03:35 PM   #3
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
Points 8,102, Level 60
Points: 8,102, Level: 60 Points: 8,102, Level: 60 Points: 8,102, Level: 60
Level Up 76% Completed
Forum Activity 6%
Maybe on a '14. My '12 only goes down one touch.
Hatch Nation #29
Joeywhat is offline
Old 03-20-2014, 03:50 PM   #4
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 9%
Oh really? My bad. I was talking about my '12. SEL though. All four windows went up and down one touch.
kam327 is offline
Old 03-20-2014, 07:02 PM   #5
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,400, Level 29
Points: 2,400, Level: 29 Points: 2,400, Level: 29 Points: 2,400, Level: 29
Level Up 67% Completed
FF Reputation: 6 CunFFS13 Good Standing Member
My '13 only goes down one touch.... No up
CunFFS13 is offline
Old 03-20-2014, 07:24 PM   #6
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,740, Level 53
Points: 6,740, Level: 53 Points: 6,740, Level: 53 Points: 6,740, Level: 53
Level Up 95% Completed
FF Reputation: 9 SilverPony2001 Good Standing Member
All model year S and SE's do not have door modules, and only have one touch down on the driver side.
SEL, Ti, and ST have modules in all the doors and have 4 window one touch UP/DOWN.
This is for US cars. I have no idea on cars in other countries.
EDIT: The physical buttons are different between door module cars and non modules as well.
SilverPony2001 is online now
Old 03-20-2014, 07:29 PM   #7
goingtoscotland
goingtoscotland's Avatar
Fan#: 132001
What I Drive: '14 Tuxedo Black HB, 05 Kawi ZX-10R
Points 1,954, Level 26
Points: 1,954, Level: 26 Points: 1,954, Level: 26 Points: 1,954, Level: 26
Level Up 54% Completed
FF Reputation: 6 goingtoscotland Good Standing Member
Only down on the 14 SE, not up.
Dawkins....Dennett....Harris....Hitchens
Hatch Nation #46
goingtoscotland is offline
Old 03-21-2014, 10:11 AM   #8
GhiaFan
GhiaFan's Avatar
Fan#: 50498
What I Drive: 2007 Panther Black Focus 1.6 Ti-VCT
Points 15,197, Level 79
Points: 15,197, Level: 79 Points: 15,197, Level: 79 Points: 15,197, Level: 79
Level Up 70% Completed
FF Reputation: 13 GhiaFan Great Standing Member
Many thanks
Newb
UK Zetec spec Focus is equipped with drivers window one touch down only.
All other windows do not have this function.
Titanium spec is equipped with one touch up/down on all 4 windows.
GhiaFan is online now
Old 03-21-2014, 02:44 PM   #9
Krayz_tom
Fan#: 150042
Thanks for the guys!
Is there anyway I can swap the window modules to make mine go up and down with one touch?
Old 03-21-2014, 03:35 PM   #10
SilverPony2001
Fan#: 27073
I'm not sure if that's even possible. The cars with door modules, the switches and the module itself are controlled by the BCM. The switches only have 3 wires, power, ground and a data wire. You would probably have to re-wire a bunch of stuff, then have the BCM programmed to tell it you now have door modules.
The cheapest/easiest way IMO to add one touch UP/DOWN would be to install an Autoloc module, or something similar. I did this to my SE.
See here:
http://www.focusfanatics.com/forum/showthread.php?t=324298
