Replace the egr valve w/ Massive's delete plate & no heat - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-11-2014, 10:26 PM   #11
dooor
Fan#: 51395
What I Drive: 2007 se stick
Points 926, Level 16
Points: 926, Level: 16 Points: 926, Level: 16 Points: 926, Level: 16
Level Up 26% Completed
FF Reputation: 1 dooor Good Standing Member
Suggest using a garden water hose, low pressure, to burp the heater hose and core. Good luck
dooor is offline
Old 03-12-2014, 12:00 AM   #12
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Originally Posted by Phestezio View Post
Yeah, I talked to KDog about it and he hasn't had that issue but he also says it sounds like air in the system. Air in fluid can be tricky to get out sometimes I really think its that, especially since you told me you drove it that it didn't overheat except for once when it went up to 3/4 on the gauge and went back down after 60 seconds. It seems like air got caught on the thermostat and wouldn't open soon enough because of the air pocket. From all the symptoms it really seems like its just some pesky air.
Now if we could just figure out a good way to bleed it that ensures that ALL air is out of the system.
Well, I went over to my buddy's shop after work & he put the cooling system under a vacuum & wow, a big air pocket, & I thought awesome now I have heat. But no heat, so I'll figure it out tomorrow. I already went thru 2 gallons of that motorcraft Gold coolant at 16.00 a gallon.
felixthecat is offline
Old 03-12-2014, 12:37 PM   #13
Phestezio
Phestezio's Avatar
Fan#: 97562
What I Drive: 2007 Oxford White ZX3
Points 1,268, Level 19
Points: 1,268, Level: 19 Points: 1,268, Level: 19 Points: 1,268, Level: 19
Level Up 68% Completed
Forum Activity 7%
FF Reputation: 4 Phestezio Good Standing Member
Hmmm so you did have a big air pocket in there, i'm glad my thoughts on putting it under vacuum worked but its still strange you don't have heat, maybe there is still air in the heater core? I would use some cheaper coolant that will get expensive quick.
'07 Ford Focus ZX3
'90 Nissan 240SX Hatch
Phestezio is offline
Old 03-26-2014, 09:03 PM   #14
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Update on my no heat/defrost. I Took the car to a shop that my work uses, to change out the pcv hose & add a egr delete plate. Picked it up monday afternoon & no heat, so they said bring it back wed or thursday. I dropped it off thursday morning & they replaced the t-stat on saturday morning & couldn't figure it out, so monday my buddy to it to ford. ford replaced the t-stat, cause they didn't know what brand or temp went in. Still nothing w/ the motor up to temp & not over heating. Found the heater hoses weren't hot, so removed all the hoses & found a cap in the plastic T right after the t-stat. Removed the cap & now have heat/defrost= yipee. I cause me $450.93 for that & the 1st shop charged me $200. So I'm going down to the 1st shop tomorrow & see what they say. I asume the rubber cap was used to cap off the heater hose to keep it from spewing all over the floor & they forgot about it & reinstalled the heater hose & the rubber cap went down the hose to the T section & got stuck.
Old 03-26-2014, 09:09 PM   #15
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
that would have been hard to guess
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 03-26-2014, 09:53 PM   #16
Phestezio
Phestezio's Avatar
Fan#: 97562
Forum Activity 7%
I agree, that would have been hard to figure out without just tearing into it. The kind of things that happen at shops sometimes amazes me. Glad it got fixed though
'07 Ford Focus ZX3
Old 03-28-2014, 12:32 AM   #17
Gherkin
Gherkin's Avatar
Fan#: 126530
What I Drive: 2010 Isotope Green Birkin (Lotus 7)
Points 195, Level 3
Points: 195, Level: 3 Points: 195, Level: 3 Points: 195, Level: 3
Level Up 90% Completed
FF Reputation: 1 Gherkin Good Standing Member
An old roommate of mine helped a friend of his install a fresh pro-built high performance engine in his VW bus. The bus owner went all out with a bigger oil cooler, all new hoses and electrical components. The busses are pretty simple so the install took a few hours and the guys drove his new hopped up ride out to lunch and the engine seized on the way home! The owner went to the builder and tore him a new one, after a lot of yelling the builder warrantied another engine but it took him a few days to build it. The bus owner started tearing out the bad engine only to find that my roommate had left the plugs in the new oil cooler and just shoved the new hoses on and clamped them up, no oil flow in an air cooled engine.
The bus owner came clean to the engine builder and ended up getting a good deal on the replacement engine, my roommate didn't chip in a dime...
Gherkin is offline
Old 03-28-2014, 06:45 AM   #18
badazz2010focus
Fan#: 78166
Points 19,226, Level 87
Points: 19,226, Level: 87 Points: 19,226, Level: 87 Points: 19,226, Level: 87
Level Up 76% Completed
Forum Activity 9%
Good to know felix I'm going to find my egr delete kit and take that damn plug off right now.........you said it was the "t" fitting?
badazz2010focus is offline
Old 03-28-2014, 07:16 AM   #19
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
HEY, there's no plug for the egr plate. My issues were caused by a shop that put a rubber cap into the end of a heater hose & forgot about it & reinstalled the hose & the rubber cap slid down to the T section & pluged off the heater.
Old 03-28-2014, 11:34 AM   #20
Phestezio
Phestezio's Avatar
Fan#: 97562
Forum Activity 7%
Yeah his issue was caused by the shop that installed it, the massive kit does not come with any kind of plug like that. If you follow my write up on how to install it you shouldn't have any real issues. Just don't plug something thats not supposed to be plugged and forget about it haha.
'07 Ford Focus ZX3
