p0352 code after coil,plugs, and wires - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2014, 12:14 PM   #1
oderus1671
Fan#: 107936
What I Drive: 2003 silver 4 door focus
FF Reputation: 1 oderus1671 Good Standing Member
Hey all, I have a 2003 Focus SE with a 2.0 vin "p", 230K miles. It was running rough, bucking at low rpms while driving at highway speed, so I did a tune up. New coil pack, new wires, and plugs. Gapped the plugs to the spec on the sticker in the engine compartment. Now, it barely runs without stalling, and is kicking up p0352 code, and cylinder 1 misfire code. It was just running rough at first, but then kicked up a cylinder 1 misfire code, nothing else, so i figured it to be ignition. Ive triple checked the wires are on the correct coil post. The plug harness going into the coil appears fine, no cracked or loose wires. Im at a loss here. Any ideas?
oderus1671 is offline
Old 02-15-2014, 03:47 PM   #2
oderus1671
Fan#: 107936
ok so I just went to advance auto and picked up a cheap in-line spark tester, and it only has spark on cylinders 1 and 4 (standing in front of the motor, going from left to right.) 2 and 3 have no spark going to the plugs. Guess I got a crappy coilpack. Gonna try swapping it out tomorrow.
Old 02-16-2014, 03:14 AM   #3
Elder
Points 13,380, Level 75
Points: 13,380, Level: 75 Points: 13,380, Level: 75 Points: 13,380, Level: 75
Level Up 33% Completed
Might have mentioned the connector, but you're looking at that already.
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-16-2014, 03:35 AM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Forum Activity 50%
Buy-Sell-Trade Rating: (11)
Moved to the technical chat area
I'd replace the wire pigtail since that's the only thing left to do and it most likely causing your problem. The wires can look good but they get pulled out inside the plug.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
